Go Back   ADVrider > Riding > Regional forums > Tejas and the Gulf States
Old 12-22-2012, 05:30 AM   #11446
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,632
Originally Posted by carabnsol View Post
Sounds like someone needs to sing a Christmas carol.
I was thinking maybe he'd gotten into the egg-nog.
Anticyclone is offline   Reply With Quote
Old 12-22-2012, 06:44 AM   #11447
RoyQ
RoyQ's Avatar
Oddometer: 2,184
I am working today so you can all kiss my ass or was that not nice enough
Backwoods it's just the Internet let it go....until tomorrow
2012 YAMAHA Super Ténéré
'11 GSXR750
'11 GSXR1000 racebike
WERA Expert #826
RoyQ is offline   Reply With Quote
Old 12-22-2012, 06:57 AM   #11448
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,537
Bah!!! Humbug! Humbug I tell you!
sent from my Galaxy S3 using Tapatalk 2
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is offline   Reply With Quote
Old 12-22-2012, 08:39 AM   #11449
Switchblade315
Switchblade315's Avatar
Oddometer: 5,631
hey Roy want to barrow my sig for the day.
I have had to use a impact once on one of those, the dumb ass before me put it on that way. had someone stand on the rear brake and turned the sprocket so it was hitting the chain insted of putting the trans in gear, but that was just a have to. but the one one on my Raptor when i knocked the lock back I turned the nut off with my hand
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 12-22-2012, 09:09 AM   #11450
Anticyclone
Oddometer: 5,632
I've had to do the same. I could NOT break the DRZ sprocket originally. Had a breaker bar turning the engine over and it wouldn't budge. I only ask the wife to the garage when I really need to, and this was one of those times. "Honey, could you stand on that lever there, it's about to get loud in here!"
Old 12-22-2012, 09:50 AM   #11451
RoyQ
RoyQ's Avatar
Oddometer: 2,184
Did y'all miss the part where I said "heat" it up? A heat gun goes a long way in loosening up the loctite that is typically found on that nut. In fact you had better use it putting it back on. GSXRs especially the 600 can't/won't keep a tight sprocket nut. I have resorted to drilling the edge of the nut and safety wiring it to the sprocket. And even then I've had then pop the wire and still be loose. Never had one come completely off.
Anyway a heat gun used in moderation of course since you can screw up a seal with too much heat down there. That nut will come loose fairly easy after heated. Just sit on the thing holding rear brake as you normally do and pull up, it's that easy.
'11 GSXR750
WERA Expert #826
Old 12-22-2012, 10:28 AM   #11452
Anticyclone
Oddometer: 5,632
I would argue that there is less chance of an idiot screwing up something with an impact wrench, the transmission in neutral and the rear brake on than putting heat in close proximity to a rubber seal that keeps engine oil in.
But hey, what do I know.
Old 12-22-2012, 10:48 AM   #11453
RoyQ
RoyQ's Avatar
Oddometer: 2,184
You are missing the point it gets hot down there to begin with. But hey if you can't operate a heat gun correctly then you shouldn't be doing the job to begin with IMO. And by all means go rattle those gears with a jack hammer and next up will be "what's the procedure for splitting the cases to repair gears".
And I don't know anything and from now on I'll be that guy who observes the blunders of motorcycle mechanics on ADV. Should be a up and coming good show. Carry on....
'11 GSXR750
WERA Expert #826
Old 12-22-2012, 11:57 AM   #11454
Anticyclone
Oddometer: 5,632
I'll believe that when I see it
Old 12-22-2012, 12:54 PM   #11455
backwoodsKLR
Oddometer: 9,537
Let's wait until the sprocket actually gets here before we start fighting over how to remove it... Or we can start arguing over how to remove the sprocket cover first... It may fall off in my hand when I actually TRY to remove it...
2013 Tiger 800XC
Old 12-22-2012, 01:08 PM   #11456
Anticyclone
Oddometer: 5,632
What fun is that?
I've got access to a 1" drive impact wrench and trailer mounted compressor that delivers 825CFM at 150psi. Also can get a hold of an oxy/acetylene rig. We'll get that sprocket loose!
Old 12-22-2012, 01:19 PM   #11457
backwoodsKLR
Oddometer: 9,537
But I'm installing my frown mud guard first.....
2013 Tiger 800XC
Old 12-22-2012, 01:29 PM   #11458
Anticyclone
Oddometer: 5,632
Well there's your problem, you need a smile mud guard.
Old 12-22-2012, 01:35 PM   #11459
backwoodsKLR
Oddometer: 9,537
Front mud guard came with plastic rivets and I don't have a "suitable riveting tool" think a heat gun will work? Super glue? Testors modeling cement? I'm so lost.....
2013 Tiger 800XC
Old 12-22-2012, 01:56 PM   #11460
Anticyclone
Oddometer: 5,632
Elmers
Times are GMT -7.   It's 01:18 AM.
