Go Back   ADVrider > Riding > Regional Forums > Tejas and the Gulf States
Old 01-28-2013, 04:59 PM   #11791
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Any of y'all going to the Arkansas 500?
http://www.advrider.com/forums/showthread.php?t=858410
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 01-30-2013, 07:00 AM   #11792
backwoodsKLR
backwoodsKLR's Avatar
Oddometer: 9,735
Since Switch loves to talk 4wheelers on the 2wheeler forum, I figured I'd chime in... Finally started my overhaul project with a lotta help from Rev Jeffrides of the Church Of Preventive Maintenance...
Rev said these are probably the worst carbs he's ever seen! One has green crud in it that had eaten the diaphragm.
11 years of mud and muck packed under the fenders and in the radiator grill...
2013 Tiger 800XC
Explore: Backwoods, MS
MS Tag-O-Rama Map / Jackson, MS Local Tag-O-Rama Map
backwoodsKLR is online now   Reply With Quote
Old 01-30-2013, 07:27 AM   #11793
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,849
Anticyclone is offline   Reply With Quote
Old 01-30-2013, 07:56 AM   #11794
backwoodsKLR
Oddometer: 9,735
Originally Posted by Anticyclone View Post
I wish it was that easy. My 4wheeler has little nooks and crannies that you can't get to with out partial dis assembly. This is the first time I've stripped it down like this. I always hosed it off, but that just gets the top side and fenders. Not the radiator, engine, under seat, etc.
2013 Tiger 800XC
Old 01-30-2013, 09:38 AM   #11795
Switchblade315
Switchblade315's Avatar
Oddometer: 5,936
dealt with that issue before. that's one of two reasions I dont like newer quads, the other is they have got to big, and hey yes it has 4 wheels but when it comes to working on the motors info is info right.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is online now   Reply With Quote
Old 01-30-2013, 10:33 AM   #11796
Supahflid
Wheelieless
Oddometer: 3,794
I want to, but like last year, it falls on my sons birthday. No way could I stand the hell I would be put through for missing that! Well, I wouldn't want to anyway (although I did try to talk the family into turning that weekend into a fun for me, fun for Supahkids birthday last year).
Supahflid is offline   Reply With Quote
Old 01-30-2013, 10:36 AM   #11797
Anticyclone
Oddometer: 5,849
Ain't that the truth. I grew up on 125's and 250's. They were 2wd and I never remember getting one so stuck it took more than some pushing or maybe a shovel to get it out. They went anywhere we needed to go and when they rolled they weren't so heavy that they would kill you (unless you really screwed up).
Last one I rode was a Can-Am 800(?). Felt like a squishy Suzuki Samurai, but with more power and less roll cage for when things got squirrley.
Old 01-30-2013, 01:06 PM   #11798
Kingsized
Kingsized Adventurer
Kingsized's Avatar
Oddometer: 792
I cut off the cigarette plug off my Airman pump and am wiring in an SAE plug so I can plug it in the SAE that I'm using for my Battery Tender. Is there a rule of thumb for which wire is positive in wiring? Both has white lettering on the cord and I didn't know if that was used on the + or - side consistently. The pump works either way but I don't know if it would hurt the pump if I reverse the polarity.
Everything's better in retrospect.
My ride through Bourbon county http://advrider.com/forums/showthrea...7#post22154447
Two Wheels Good, a journey out west http://twowheelsgood3.blogspot.com/
Kingsized is offline   Reply With Quote
Old 01-30-2013, 01:37 PM   #11799
BradH
BradH's Avatar
Oddometer: 272
Can you see the motor to see which way it's turning?
BradH is offline   Reply With Quote
Old 01-30-2013, 01:49 PM   #11800
BradH
BradH's Avatar
Oddometer: 272
Without seeing it its hard to say... If its a series or shunt wound motor, shouldn't make any difference unless there are electronics involved... If its a permanent magnet motor, the direction will reverse and then it will depend how it's connected to the pump.
Old 01-30-2013, 02:00 PM   #11801
Kingsized
Kingsized's Avatar
Oddometer: 792
I can't see the motor at all. It's encased. I don't know much about the motor is in there so I guess I'll try it one way and see. I've got a 50/50 chance of getting it right. That's better than most times I work on something.
Old 01-30-2013, 02:08 PM   #11802
backwoodsKLR
Oddometer: 9,735
Can you feel which way the air is moving? If it is like my 12v pump, it has a nozzle pointing out and a side opening where it draws air in. Twist wires together and feel the air flow. if it is backward, reverse wiring and seal it up.
2013 Tiger 800XC
Old 01-30-2013, 02:13 PM   #11803
BradH
BradH's Avatar
Oddometer: 272
Yep, if its a corkscrew type compressor and the motor turns backwards, it's gonna suck... Lol. However, if its a piston type, the motor could still run backwards and pump air.
Old 01-30-2013, 02:18 PM   #11804
backwoodsKLR
Oddometer: 9,735
True... Kingsize? Which is it? Airman makes many different kinds. Is this a compressor or just a air pump?
2013 Tiger 800XC
Old 01-30-2013, 02:18 PM   #11805
Kingsized
Kingsized's Avatar
Oddometer: 792
Gotcha, I hooked it up and it blows regardless of the polarity. Looks like I can't screw this up even if I try.
EDITED, the Tour BW. It's a compressor.
Times are GMT -7.   It's 08:00 PM.
