Old 05-31-2009, 06:40 PM   #1
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Talking Unibiker radiator install on a DRZ400
Here is my install of a Unibiker radiator guard on my DRZ400. Everything looks well made and bolted pretty much right on.
Ghilly is offline   Reply With Quote
Old 05-31-2009, 06:45 PM   #2
Ghilly OP
Ghilly's Avatar
Oddometer: 810
With the parts out and after reading the directions I started to take the stuff off my bike to get to the radiator. The seat, tank horn and stock rad guard had to come off.
Old 05-31-2009, 06:49 PM   #3
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Once all the stuff is off you are ready to start installing the new guard.
Old 06-01-2009, 01:48 PM   #4
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Once I got all the stuff off the bike I needed to take off the stock rad guard. I just pushed in the tabs with my needle nose pliers and pulled them out. Takes only a minute or two for both sides.
Old 06-01-2009, 01:51 PM   #5
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Once the stock guards are off then you have to unbolt the two radiators from the frame. Again, only a few minutes to do both sides.
Old 06-01-2009, 01:54 PM   #6
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Once the two radiators are off then you have to fit the unibiker guards on the proper side. The U in the unibiker is to be on the top outside of the radiator for install.
Left side
Old 06-01-2009, 01:55 PM   #7
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Right side
Old 06-01-2009, 07:38 PM   #8
2degreesout
2degreesout's Avatar
Oddometer: 870
Waiting for the fun part to begin
It's taken years, but I've finally gotten my supply of brain cells down to a manageable size.
2degreesout is offline   Reply With Quote
Old 06-01-2009, 08:36 PM   #9
edgy
edgy's Avatar
Oddometer: 488
Looking good!
Whats the fun part?
www.astonesthrow.co.za
`08 KDX200
`08 SE950R
`11 KTM690
edgy is offline   Reply With Quote
Old 06-02-2009, 06:00 PM   #10
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Now the solid rods are threaded at each end and must be bolted in place once the guard is placed on the radiator. You must leave everything loose till it is all bolted together.
Old 06-02-2009, 06:03 PM   #11
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Once I got the rods started then they could be tightened down but the radiator is still no bolted to the frame yet. There is not much play room and the right side was a touch more touchy than the left.
Old 06-02-2009, 06:06 PM   #12
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Now the left side.
Old 06-03-2009, 08:56 AM   #13
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
Believe me, those things are worth their weight in gold, when you look at the price of a replacement rad.....
alpiv is offline   Reply With Quote
Old 06-03-2009, 08:59 AM   #14
GB
Mod Squad
GB's Avatar
Oddometer: 56,725
Very nicely done, I just did the same job on my KLX250. It's all well designed, and quality materials, fit and finish.
Old 06-04-2009, 06:57 PM   #15
Ghilly OP
Ghilly's Avatar
Oddometer: 810
Now I have to bolt on the radiator to the frame. This is the left side. Just start them both at first with the extensions on the socket. then tighten then up.
Times are GMT -7.   It's 05:13 AM.
