Old 06-01-2009, 08:30 PM   #16
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,795
I'm not asking for your price, just what normal retail would be in the US.
Any help?
johngil is offline   Reply With Quote
Old 06-01-2009, 09:17 PM   #17
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,923
From Carpimoto in Italy = $586.00 US plus shipping from Italy. Don't know the amount yet.
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 06-01-2009, 10:52 PM   #18
DockingPilot OP
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,471
yup, thats them. they also own a bmw dealership.
Originally Posted by Pomo
Googling the phone number comes up with http://www.herdan.com/.
Looks like they are a Bitubo dealer.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 06-01-2009, 10:53 PM   #19
DockingPilot OP
Oddometer: 9,471
you fellas interested should call for a price. i think youll be pleasantly surprised.
Frank Reinbold
Old 06-02-2009, 08:51 PM   #20
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,895
Tag for curiousity
Jimmy the Heater is offline   Reply With Quote
Old 06-02-2009, 09:39 PM   #21
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,795
Were there any options for spring rates?
Good suspension w/ the wrong springs could be a waste.
Javier (trailtrick) says he may have an answer for me.
johngil screwed with this post 06-02-2009 at 09:55 PM
Old 06-02-2009, 11:55 PM   #22
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
No, and they are linear rate springs. But that is also why they have a preload adjustment. To suit a wide range of weights.
Old 06-03-2009, 02:45 AM   #23
Bigem
Bigem's Avatar
Oddometer: 2,549
Not available in Australia yet so I'm sticking in a set of Progressive springs and gonna play around with oil weights. If it makes a noticable difference I will let you know.
"I'm a thousand miles from nowhere,
Time don't matter to me,
Cause I'm a thousand miles from nowhere,
And there's no place I'd rather be!!
Bigem is offline   Reply With Quote
Old 06-03-2009, 04:03 AM   #24
RAD800
RAD800's Avatar
Oddometer: 895
I might try giving them a call and see if they'll ship, no point waiting for them to be distrubuted here or being spoke to like a muppet by local retailers.
RAD800 is offline   Reply With Quote
Old 06-03-2009, 06:05 AM   #25
DockingPilot OP
Oddometer: 9,471
In all honesty though, I rode the stock suspension pretty hard this weekend at a dual sport event and Ill tell ya, it wasn't bad! Much better than my TE610 stock forks and on par with my 950A. I was able to ride the bike very fast through some rocky sections. I was surprised. not perfect by any means, but certainly as bad as I expected. It didnt warrent a thread "800GS good bike but poor suspension" imho.
If I hadnt already bought a shock and fork kit, I just might have considered leaving it alone. Maybe.
The shock anyway.
Frank Reinbold
Old 06-03-2009, 09:17 AM   #26
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
The shock anyway.
+2 I've ridden my F800GS offroad numerous times now, and have not been "disgusted" by the suspension as others have. For me it works just fine, but maybe that's because I weigh 185 lbs. This bike is set up from the factory for a 187 lb rider. States it in the manual as well. The most I think I'm going to do is put on that Hyperpro rising rate spring set.
Old 06-03-2009, 11:23 AM   #27
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,148
You're kidding? Why make a high end, adjustable cartridge and leave out the most critical part of suspension. Preload does not sufficiently compensate for weight. Proper spring rate is just as important. With inadequate spring rate, you'll bottom out much easier when sag is properly set.
Maybe I'll just get the front resprung and replace the rear shock (I don't think it can be resprung?)
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 06-03-2009, 11:46 AM   #28
Desert Dave
Enjoying the moment
Desert Dave's Avatar
Oddometer: 2,735
What critical part is left out?
Are you referring to the fact that it's a linear spring? (or did I misread your post?)
Of course you're correct in needing proper spring rate, and preload is important for setting sag in either linear or progressive.
See what I've been up to! Ongoing Ride Report
Desert Dave is offline   Reply With Quote
Old 06-03-2009, 11:49 AM   #29
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Actually, the fact that the Bitubo Cartridge Kit utilizes linear rate springs is not such a huge deal. Preload in fact does cover a somewhat wide weight range. And when it comes to the cartridges themselves in this kit, they are also very beefy in design and will handle damping well for a wide range of weights. If you want a system that is exactly tuned to you, then you'll be paying $2000 for a custom design instead of $525 for this Bitubo kit.
And yes, the rear shock on the F800GS can be resprung. That's what you do with this kit:
http://www.touratech-usa.com/shop/sh...3FB7IJx22EFA1F
The Griz screwed with this post 06-03-2009 at 06:33 PM
Old 06-03-2009, 11:51 AM   #30
Desert Dave
Enjoying the moment
Oddometer: 2,735
In all honesty though, I rode the stock suspension pretty hard this weekend at a dual sport event and Ill tell ya, it wasn't bad!.... I was able to ride the bike very fast through some rocky sections.
Really? Everytime I do that I hit the front so hard I think I'm going to bend a rim.
How about some more info on the enduro....did I miss the ride report?
Times are GMT -7.   It's 01:32 PM.
