Old 06-04-2009, 08:17 PM   #46
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Good to hear you like 'em, man!
Old 06-04-2009, 08:54 PM   #47
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Originally Posted by DockingPilot
Mostly because I've been too lazy to take my forks apart, do the crimps on the damper tube prevent you from removing the damping rod?
bxr140 is offline   Reply With Quote
Old 06-04-2009, 09:01 PM   #48
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,805
Yes, and that's part of the problem.
johngil is offline   Reply With Quote
Old 06-04-2009, 09:35 PM   #49
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,963
INSTALLED AND TESTED........sorta.
These are stupid easy to install fellas and the directions are spot on. The only blank you'll draw is tightening the cartdrige units to the sliders. They of course will spin. Use (lightly) an impact wrench. Done.
So those of us without a compressor/impact wrench won't be able to install ourselves?
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 06-05-2009, 04:32 AM   #50
DockingPilot OP
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,933
bxr,
Yes, thats where the female threads are housed. Crimped to hold it in there I guess.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot screwed with this post 06-05-2009 at 05:13 AM
DockingPilot is offline   Reply With Quote
Old 06-05-2009, 04:41 AM   #51
DockingPilot OP
Oddometer: 9,933
Yea John, but, you can get an electric one from Harbour Frieght for next to nothing. So dont let that stop you. If you bring it to a suspension shop to install, they will do the same thing. Using an impact wrench to loosen and tighten flywheels is also a common practice, because unless you have the special tool, there is no way to stop the shaft from spining.
Again, this is a very easy, quick swap out. Remember to loosen the original fork caps before you loosen the tripples, it will act like a vise for you. Taking the forks off and on the bike was very easy. Remove front wheel, take off calipers, remover front fender, loosen caps, loosen tripples, slide forks out. Instuctions were short and easy to follow.
Frank Reinbold
Old 06-05-2009, 04:43 AM   #52
DockingPilot OP
Oddometer: 9,933
And for you fellas looking for your spring rates, here's the email I just recieved from Bitubo:
Dear Mr Reinbold,
Thank you very much for your e-mail.
Our fork cartridge kit is studied for a “standard” weight between 65Kg and 85 Kg. If your weight does not belong to this standard, you can mention in your order the exact weight and our technicians will study the most proper solution for you.
By the way, where are you writing from? I could give you the address of our importer in your country for getting more details and get your order.
Please let me know,
Export Dept.
Elena Valentini
C.d.a. Bitubo snc
Via A. Volta, 24
35037 Z. I. Teolo (PD)
Tel.: +39 049 9903475 int. 203 or 1
Fax.: +39 049 9903447
E-mail: elena.v@bitubo.com
Web: http://www.bitubo.com
So mine fall into my weight catogory. I'm 168 nude. And I ride nude a lot.
Frank Reinbold
Old 06-05-2009, 05:00 AM   #53
DockingPilot OP
Oddometer: 9,933
Here is the phone # of the US dealer. Super nice guy and BMW dealership owner.
610-562-3155
For under $550, you cant beat it.
Frank Reinbold
Old 06-05-2009, 05:18 AM   #54
DolphinJohn
Caveman
Oddometer: 3,963
Thanks Frank.
My Ride Reports
Old 06-05-2009, 05:39 AM   #55
GB
Mod Squad
GB's Avatar
Oddometer: 57,139
Hey thanks for the feedback and pics! That's the trouble with this site.. I see, and I want!
The installation sounds simple enough, but a step by step pictorial would have been a tremendous help for some of us with a challenged imagination, like where exactly does the impact wrench come into play and how.
If you remove them and reinstall, please keep us in mind.
Old 06-05-2009, 05:48 AM   #56
DockingPilot OP
Oddometer: 9,933
Trust me, you will not be wondering "what do I do next". In any event, if anyone does just pm me.
Herre's the part your asking about GB.
The new gas charged cartdridge, you slip itno the fork tubes and it sits on the bottom of the tube. Well there is a hole down there, because you already removed the hex head bolt to remove the old one. Now you put the bolt back in to hold the new one in place. But when you tighten the bolt the new cartdridge will want to spin with the bolt and you cant hold it to stop it because it's inside your fork tube and your hands wont fit in there. So what you di is use an impact wrench. They spin bolts so fast the cartdridge cant keep up and it will tighten nicely. This is a comon way of tightening things like this, such as flywheels.
Dont be worried about doing this guys, I promise its super easy and if I can do it, so can your daughter.
Frank Reinbold
Old 06-05-2009, 06:14 AM   #57
GB
Mod Squad
GB's Avatar
Oddometer: 57,139
Thanks for 'splainin'.. I do have a compressor and impact wrench! Any specific torque setting for that bolt?
Old 06-05-2009, 06:17 AM   #58
DockingPilot OP
Oddometer: 9,933
It wont take much torque to tighten them. Look under your forks now and you will see the hex head bolt I am referring to. That is what holds the present and new cartdriges in place. The cartdridge is shorter than the fork tube, so it's impossible to hold it will you tighten the bolt back up. An impact wrench will do the trick. First finger tighten the bolt though of course. No locktite !
Frank Reinbold
Old 06-05-2009, 06:26 AM   #59
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,484
Damper unit to slider tube
M10 x 25 - 10.9
with sealing ring
50 Nm
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 06-05-2009, 06:30 AM   #60
DockingPilot OP
Oddometer: 9,933
Yes, but your not going to know using an impact gun, so dont worry. It simply holds the cartdridge in place and the washer prevents oil seepage. Its not criticle. Again, even if you bring your forks to a shop, they will do the excact same thing.
Frank Reinbold
Times are GMT -7.   It's 12:47 AM.
