Old 06-05-2009, 01:27 PM   #76
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Weird, says 5wt on the bottle in this pic. They gave you 2wt instead?
Either way, that's some thin oil! Probably a testament to why the kit is working so well for you. Thinner oil moves through cavities faster. Seems like they designed the springs and cartridges around this lighter oil perfectly. Makes sense.
The Griz screwed with this post 06-05-2009 at 01:36 PM
Old 06-05-2009, 01:45 PM   #77
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Originally Posted by DockingPilot
bxr, they are sealed, so it just lubes the bushings and seals and provides cushion on comprssion. So I have been told.
The "cushion on compression" must be their way of describing the 'air spring'--the compression of the air in the gap between the oil and the top of the fork.
If the units are completely *sealed* though, that begs the question...how do you rebuild them? Fork oil really should be changed every 10-15k miles at most.
bxr140 is offline   Reply With Quote
Old 06-05-2009, 02:34 PM   #78
DockingPilot OP
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,608
Griz, the oil does not flow through any cavities. When I get Ill double check the wt.
bxr, the oil is easy eough to change. The gas inside the units Im not sure what happens there.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 06-05-2009, 03:09 PM   #79
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
I'm talking about the oil inside the cartridges themselves, not the stuff you poured into the fork tubes. The nitrogen charge in there is only to prevent cavitation of the oil that's also in there--similar to a rear shock. The oil is the stuff doing the damping, not the gas charge.
Just thinking out loud, but in addition to the spring tuning mentioned already, the other reason (perhaps the primary reason?) you put oil in the fork tubes is to cool down the cartridges. I'd surmise that the weight of the oil is largely irrelevant.
Old 06-05-2009, 03:50 PM   #80
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
I'd wondered about the unit servicing, too...
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 06-05-2009, 04:17 PM   #81
DockingPilot OP
Oddometer: 9,608
I wonder about the fact that they are sealed has anything to do with the longevity ?
Frank Reinbold
Old 06-05-2009, 06:34 PM   #82
M N B
would rather be riding
M N B's Avatar
Oddometer: 1,202
That's good to hear. It seems to imply that they can set up the damping for rider weight...though only if you're out of their (somewhat large) range.
The stock range is between 143 and 187lbs.
Outside of that, it appears from the email that they can put a stiffer spring in and adjust the damping to compensate (which is excellent news!)
2014 Ducati Multistrada 1200 Pikes Peak MNB Touring Edition
2009 BMW F800GS
2011 Husqvarna TE310 - 2003 Husqvarna TE610e
2007 HD Road King FLHR
1997 BMW K1100LT Special Edition
M N B is offline   Reply With Quote
Old 06-08-2009, 08:46 AM   #83
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Just ordered mine. I'll re-spring if needed.
Great customer service! I gave a shout for Frank. I think they are very appreciative of you, Frank.
BTW, these are going fast! It wasn't clear when another shipment was expected.
johngil screwed with this post 06-08-2009 at 07:55 PM
johngil is offline   Reply With Quote
Old 06-08-2009, 09:37 PM   #84
Bayner
Oddometer: 1,578
Frank, with the new spring rate, have you found it more difficult to bottom the front out, or is it just feeling more compliant but still hits full travel frequently?
Bayner is offline   Reply With Quote
Old 06-09-2009, 06:24 AM   #85
DockingPilot OP
Oddometer: 9,608
Bayner,
Beacause of work and the weather here, I have not been able really push it to the limits. I did take it to work on Sunday. Staten Island NY. The roads are probably not unlike the bombed out roads in Bagdad.
So I noticed, short, quick hits like potholes are sucked up. The impact feeling we normally get is reduced by 80% on most and completely on others. I seeked them out and some I hit hard. The fork never bottomed on this of course. But from what I can tell, I would expect full travel when the bike is g-out. But time will have to tell.
So far, would I buy them again and recomend them ? In a heartbeat. They are a marked improvement.
Frank Reinbold
Old 06-09-2009, 09:25 AM   #86
jeffchri
Oddometer: 132
Yep, they're out of stock now, I'm on the waitlist for some indeterminate amount of time ...
2009 BMW F800GS - the "attack helicopter"
2008 Husqvarna TE510 - loud and proud
2006 BMW R1200S - dedicated track bike now, mostly because of sloppy welds
2010 BMW S1000RR - soooooon, very soooon ...
Recent past: Montesa 4RT (now in the hands of the fiancee), Weestrom, F650GS Dakar, Yammy WR250F, (a scooter), (another scooter)
jeffchri is offline   Reply With Quote
Old 06-09-2009, 09:53 AM   #87
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I guess I got the last one?
Old 06-09-2009, 05:31 PM   #88
jeffchri
Oddometer: 132
No, wait - they just called me back a bit ago, they "found" 2 more at another shop. As of an hour ago, they still had one of those left ...
Old 06-09-2009, 06:22 PM   #89
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,938
I just pulled the trigger on the last set from their first batch.
Ordered them from Kathy by phone. Super nice lady.
Good thing I love ramen noodles.
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 06-09-2009, 06:31 PM   #90
DolphinJohn
Caveman
Oddometer: 3,938
For under $550, you cant beat it.
Frank got the guinea (uh, no pun intended) pig discount I guess.
My Ride Reports
Times are GMT -7.   It's 02:55 AM.
