Go Back   ADVrider > Riding > Regional forums > Canada
Old 04-10-2013, 11:18 AM   #8731
PiffleMaster
PiffleMaster's Avatar
Oddometer: 2,243
Mel's KLR...
Sorry I haven't been around to help out with the KLR issues, but it sounds like things are under control.
Currently working at St Andrews, but will be available next week if needed.
Cheers, Brian
"He never met a stranger." Drif10 re DRCool
Have Sporadic Spot, will travel sporadically...
And a picture outside my window... Sometimes...
PiffleMaster is offline   Reply With Quote
Old 04-10-2013, 02:40 PM   #8732
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 3,647
Well, the DR is up and running.
Lyle
skysailor is offline   Reply With Quote
Old 04-10-2013, 02:47 PM   #8733
Lappeman
He's Down Again!
Lappeman's Avatar
Location: Lappe, ON Coldest, wettest place...well not quite!
Oddometer: 2,421
Ktm 530's battery appears too weak to start the brute, so on the charger it goes! Doesn't seem to matter anyway, as the temps are dropping again and crappy weather seems to be the norm for the next 5 days or so...when does it end?
Ktm 300 started second kick, 2 strokes gotta love them! Just need a place to ride it now.
Lappeman
Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2003 KLR 650 Alaskan Adventure
2007 YZ250F Blue Death
Lappeman is offline   Reply With Quote
Old 04-10-2013, 02:59 PM   #8734
Hektoglider
One with Life
Hektoglider's Avatar
Oddometer: 2,536
Air filter: I used the product No-Toil on my stock KLR air filter. Maybe the water was too hot, but the end result was the glue holding the foam components together seperated and the filter needed to be replaced. I liked the No-Toil product but no longer use it. Switched back to oil and kerosene
Ride Our World
Hektoglider is offline   Reply With Quote
Old 04-10-2013, 03:06 PM   #8735
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 685
Nice, Lyle! Giv'er a go. Those 5 mins I was able to ride yesterday were fantastic.
Update...
- Oil changed (met another biker at Cdn Tire, he rides a beemer and suggested I use Castrol GTX or whatever it is, 10W40.
- Air filter cleaned, dried, lubed & reinstalled.
- Air box drained
- Carb out!
My bike is peeing! Don't look, you perverts!
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 04-10-2013, 03:37 PM   #8736
Lappeman
He's Down Again!
Lappeman's Avatar
Oddometer: 2,421
Update...
- Air box drained
- Carb out!
Mel, is your rear brake pedal actually making contact with the case? If it is, is could cause a wear issue and should be adjusted so it's not touching. It looks a little high
Lappeman
Old 04-10-2013, 03:46 PM   #8737
KamikazeKLR
Shorty on the 650
Oddometer: 685
Nope, it's actually fine. I don't know why there are scratch mark there, but it doesn't rub. it could have been doing that before and the previous owner rectified the problem.
ALSO.....
Guess what I just found in my carb.
an ant.
an ant? Yes, an ant. I found a small creature inside my carb hahahahahaha
Do you guys think I should keep disassembling my carb or do you think i'm good?
- Mel
Long Way Back
Old 04-10-2013, 04:12 PM   #8738
Hektoglider
One with Life
Oddometer: 2,536
How grubby does it look? If its spotless I say reassemble. The ant is your problem. I have found cellophane like from a cig pack, flecks of paint( almost match head size) and other crunchy gunk. I bet its fine when you start it again. It would not hurt to pop the jets out and inspect the small feeder holes on the flue. Your into it. Carefull not to strip the brass, correct size tool before applying torque.
When the jets are out. Hold them up to the light and inspect the orofice . A good way to gently clean them is take a wire brush, remove one strand of wire from said brush and utilize that wire to carefully open any clogged feeder holes or jet orofice
Ride Our World
Old 04-10-2013, 04:17 PM   #8739
KamikazeKLR
Shorty on the 650
Oddometer: 685
Hi, Hekto,
I should a small amount of sand-type stuff in the bottom of the float bowl and i think it's from the sandblasting job i had done on the tank.
I am going to clean it out with carb cleaner but the rest of the carb looks just fine. ill clean as much as I can.
I want to also put in an inline fuel filter from the fuel tank to the carb in case there's anything else in the tank so it doesn't go back in there and into my engine.
- Mel
Long Way Back
Old 04-10-2013, 04:27 PM   #8740
Mark-II
Turn The Gas On
Mark-II's Avatar
Oddometer: 328
Just got home from picking up the GS, going to Costco, running out to the perimeter, to headingley, back down roblin to shafetesbury to grant to home.
No more buyers remorse
Lovely tractable engine, bags of power without being scary, nice tranny, great ergos.
I think the grin is frozen on my face.
I even got it dirty
I was going to ride to the CMMG meeting tonight at griffin trikes, but I think I've had my fun for the day
Mark-II is offline   Reply With Quote
Old 04-10-2013, 04:28 PM   #8741
skysailor
Rat Rider
skysailor's Avatar
Oddometer: 3,647
They're calling for +5 here tomorrow, so the DR is headed out on the road. Head into town and buy her a fresh tank of gas, then out and about the town. Lunch and then back to her cave till warmer weather arrives. Think I'll just leave the Bandit till spring? They're calling for 0 on Friday, rain Sunday.....Where the F is spring???
Lyle
Old 04-10-2013, 04:59 PM   #8742
KamikazeKLR
Shorty on the 650
Oddometer: 685
I even got it dirty
Congrats!!!
pics please!
- Mel
Long Way Back
Old 04-10-2013, 05:26 PM   #8743
Old Fart At Play
Mad about thumpers
Oddometer: 168
No-Toil is a good product. However, it can attack some glues as Hekto describes above. It is designed to be used with their line of "No-Toil" filters as well. Made the same mistake myself.
Steve
Old Fart At Play is offline   Reply With Quote
Old 04-10-2013, 05:40 PM   #8744
BackRoader
Heading There Next
Oddometer: 5,065
Mark, good to hear you got the GS out and you have the happy face.
Put a new windshield on my GS today and popped in the battery...fired up right away. I wished the rest of the fleet was like that...fuel injection has it's advantages.
The KLX is moving to a new home across the street tomorrow so things are slowly starting to look like spring here..
Do to a major family event happening today, the Dryden Steak Quest scheduled for this coming weekend will have to wait.
Our first Grandson arrived today
2015 R1200GS, 2009 WR250R, 2006 Super Sherpa, 1978 XS650 Special, 1978 KE100, 1967 CD125A, 2004 BWS. ROKstraps Dealer
BackRoader is online now   Reply With Quote
Old 04-10-2013, 05:52 PM   #8745
stubblejumper
stubblejumper's Avatar
Oddometer: 235
Grandson
Congrats Grandpa Greg
Stubblejumper
`08 KLR 685
`14 XF 8000 SnoPro Ltd.
`11 Ram SLT Hemi 4x4
stubblejumper is offline   Reply With Quote
Times are GMT -7.   It's 07:47 AM.
