Old 06-08-2009, 12:37 PM   #1
Wallowa OP
Oddometer: 5,456
Question Paralever U-Joints: Correct Phase?
Paul Graves wrote a great article in the "BMW ON" May 2009 on "Driveshat Operation and Maintenance". In that article he went into detail of why it is critical to get the U-Joints on driveshaft "in the correct phase" to prevent damage to the joints and shaft. Especially on the GS due to the long suspension travel.
I have read the article several times but can't visualize either the correct orientation or how having the u-joints in the wrong positions will lead to stress and damage.
Can someone please post a photo showing all the U-Joints aligned correctly ['correct phase'] ?
Thanks...
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline   Reply With Quote
Old 06-08-2009, 01:15 PM   #2
sev
sev's Avatar
Oddometer: 22
http://isatis.no-ip.org/K1/Joint_ent...es_decales.JPG
'98 R1100GS
sev is offline   Reply With Quote
Old 06-08-2009, 01:37 PM   #3
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,450
While I haven't pulled mine apart, I think I read here that you can't get the 1200 U-joints out of phase, is this correct?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 06-08-2009, 04:51 PM   #4
Wallowa OP
Oddometer: 5,456
I Believe You Can Get Them "Wrong"
Depending on which splines you align on, the U-joints can be out of phase...Sev, thanks for photo but hard to see even magnified...
Does anyone out there align their u-joints as described by Paul Graves?
"In Wallowas"
Old 06-08-2009, 05:07 PM   #5
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,092
Glad you asked the question, because after the article I was confused too. Maybe Paul will answer on the BMW board.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 06-08-2009, 05:53 PM   #6
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,546
Not on a Hexhead. The driveshaft is ONE piece. That is one of the hexhead advantages. The older bikes had a two piece splined driveshaft that could be assembled out of phase.
marchyman is offline   Reply With Quote
Old 06-08-2009, 06:22 PM   #7
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,489
Jim
Old 06-08-2009, 06:58 PM   #8
Xios
Greco
Xios's Avatar
Oddometer: 200
Bmw On
Sorry, relatively new to the BMW world. What is BMW ON?
02 1150 GS, 03 Fat Boy, 73 CB 750 K3, 74 GT 550, 81 RM 250
Xios is offline   Reply With Quote
Old 06-08-2009, 07:17 PM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 53,489
BMW Owner's News.
http://www.bmwmoa.org/ownersnews/
Jim
Old 06-09-2009, 03:02 AM   #10
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,643
Here's a picture i took of an 1150 with an indexed spline, which means it can only be phased one way. All the drive shafts from 2003 are like this, so it's impossible to set the joints out of phase.
The picture will also get rid of any confusion of what position you need the U/J joints to be in.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 06-09-2009, 08:59 AM   #11
SourKraut
Oddometer: 7,215
I thought both yokes were supposed to be oriented identically.
It actually looks like they are one or two splines out of phase in the picture, doesn't it? Aw jeez, am I adding to the confusion?
SourKraut is offline   Reply With Quote
Old 06-09-2009, 09:12 AM   #12
JimVonBaden
"Cool" Aid!
Oddometer: 53,489
On the older 1150 bikes there was no indexing spline, so you could get them dead on. On the R1200 the shaft is one piece, no worries.
Jim
Old 06-09-2009, 09:17 AM   #13
SourKraut
Oddometer: 7,215
Jim
Thanks.
Old 06-09-2009, 11:42 AM   #14
TonyA
beta tester
TonyA's Avatar
Oddometer: 1,159
About 5 degrees off. On the plus side, it could have been a lot worse.
If you drink, don't index.
"A voyage whose two ends were out of sight - a voyage sufficient in itself."
"Master and Commander", Patrick O'Brian
IBA 31991
TonyA is offline   Reply With Quote
Old 06-09-2009, 01:48 PM   #15
bemiiten
League of Adventures
bemiiten's Avatar
Oddometer: 4,969
Looks a tooth off or possibly 180 off to me too. I'd say this is what you don't want. Factory defect?
bemiiten is offline   Reply With Quote
Times are GMT -7.   It's 07:20 PM.
