Old 06-10-2009, 10:58 PM   #1
Pezza OP
Stop sookin, just ride it
Pezza's Avatar
Oddometer: 339
Across Aus on a 625
The alarm went off at 4.30 am, it didn’t matter as I was already in the kitchen making coffee. I find it a little hard to sleep when about to embark on an adventure of the sort I had planned.
I had 2 months and a credit card so figured what better way to make the most of both than to go for a ride !
The decision of ‘where’ was quickly made, I rode to Cape York last time, there is a lot of central and west Australia I haven’t seen yet so a ride to the other side through the middle, keeping to as many dirt roads and tracks, sounded good to me !
After a few last minute details I had the front wheel pointing down the road at 6.00 am on a beautiful autumn morning with the thoughts of what lay ahead causing a massive grin under my helmet, even if it was only 4 deg c.
After negotiating the Gatton – Clifton rd I pulled over in Clifton to try and rub some feeling back into my summer dirt glove shod hands and check that everything on the bike was the way I had put it, I was using different gear and a different bike to my last trip so figured it was gonna take me a little while before I found the best configuration.
Half hr later I was tearing down the first of many dirt roads on the way to Goondiwindi.
I had spoken to Ozmick a couple days earlier and we figured that after putting the 625 back to normal gearing and riding sensibly (that part could be a problem for me ! ) that I should get similar economy to his 640 adv, approx 17 km/lt.
Well after having to tip the bike on it’s side 4 times to drain what little fuel was left in the 21 ltr tank to the tap side I rolled into the caltex G’windi exactly 320 km later to realize that maybe I had overestimated my fuel economy, either that or I was having way too much fun on the dirt !
So after filling both the tank and the 5 ltr drum in my side saddle, which I had left empty until this time, thinking I wouldn’t need it, I made my way towards Mungindi via Boomi.
100 km’s west of G’windi I stopped to water some trees that looked a little dry and glanced over the bike to discover oil splatter all over the swingarm and rear end.
Thinking I’d done a countershaft seal I remembered reading something about a similar incident happening to Ozmicks and Evildingoes 640 adv’s some months earlier, I figured a quick call to Mick was in order, “ Nah, she’ll be right mate, just nip it up and it’ll be all good” was the response I got. I knew the countershaft sprocket on the LC4’s is a bit dodgey, we ascertained this after a few of them came loose on the last wild boar ride, including mine, apparently there is a rubber o ring type seal behind the sprocket that can leak a little if the sprocket isn’t done up 100 % tight. I checked it 50 km later and Mick was right, all was good.
This is the only “servo” in Boomi, credit/key card or no fuel. At least it’s 24 hrs.
About 50 k’s after Mungindi I turn right to follow the dirt into Lightning ridge from the east.
Upon entering Lightning Ridge, which is an opal mining town, there is what is called a “hot bore bath” that is fed from the Great Artesian Basin, which is like a massive underground ocean that supplies water for the majority of central Australia, this water comes to the surface at approximately 30 – 40 deg c and makes for a great hot bath that also has therapeutic qualities derived from the mineral content of the water.
So after soaking for an hour or so I made my way another 30 km towards Narran Lakes to set up my first of many bush camps about 500 mtrs down a little used track for the end of day 1.
"Everyone is good at something, but no-one is good at everything."
My ride across oz http://www.advrider.com/forums/showthread.php?t=473814
Pezza screwed with this post 06-11-2009 at 02:05 AM
Pezza is offline   Reply With Quote
Old 06-10-2009, 11:06 PM   #2
rickjames
RIP rickjames.
Oddometer: 322
rickjames is offline   Reply With Quote
Old 06-11-2009, 12:14 AM   #3
Pezza OP
Pezza's Avatar
Oddometer: 339
Ok, hang on a minute people, the pics on photobucket are a bit big for here, am in the process of reducing the size so it makes for easier viewing on here.
Was halfway through doing this when Photobucket shut up shop for "site maintanance", good timing fella's.
Will continue as soon as I can get back in and have done the next few.
Pezza screwed with this post 06-11-2009 at 12:20 AM
Old 06-11-2009, 02:38 AM   #4
Pezza OP
Pezza's Avatar
Oddometer: 339
Day 2.
Awoke to the sort of day that you dream about, cloudless sky, perfect temperature, time to go for a ride !
20km later I was back on the dirt.
A few km later, after counting 19 kangaroo’s within a 2 km stretch I decided it was time to slow down to about 80 kph purely for self preservation reasons.
The next couple of hrs was a pleasant ride through the Narren Lakes nature reserve towards Brewarrina.
Upon arriving at brewarrina, which has a population of approx 1200, of which 80 – 90 % is indigenous Australian ( Aboriginal ), you cross a bridge beside which is a lovely park for travelers and locals alike.
Noticing the roofless amenities block I decided to investigate further,
And discovering this upon walking inside.
Luck I didn’t need ‘to go’ !
Seems the locals didn’t appreciate porcelain bowls.
Having been through this town before I planned it so I didn’t have to stop here for fuel, you gotta wonder about stopping in a town where every opening in every building has bars on them that make a goal seem like a holiday village.
100 km later lunch was had at the Bourke bakery.
A little ways out of town towards Wanaaring I see this loaded Dr 650 wobbling towards me, I pull over and have a chat with Peter from Ipswich, he is on his way home after a round trip to Birdsville, Innaminka and Tibooburra, I must have been too busy chatting as I forgot to get a pic of him.
Stopping for fuel at Wanaaring I ended up talking to Ben, the attendant there, for about half hr, he is a big adventure bike fan and has many a story of bikes coming through his part of the world, one of particular interest was of ‘the longest day’ ride and some bloke called Tom Foster who reckoned he would have “come first if he didn’t have to ride sweep”.
After I had my fill of adv bike stories and checked out the TBAM calendar on the wall I headed off down the ‘cut line’ towards Tibooburra.
There’s no complaining about mail boxes being too small out this way.
The tank beside this windmill had a mesh fence around the top of it to stop animals from falling in, unfortunately for the ones that did get in looking for water there was no coming back out.
About 100 km west of T’burra I came across what could possibly be the reason why you don’t see too many BMW’s out this way.
As I was about to enter The Sturt National Park where no fires are allowed I decided to set up camp 50 km before T’burra, therefore just outside the national park.
Old 06-11-2009, 02:41 AM   #5
Steffo
Steffo's Avatar
Oddometer: 211
2009 BMW F800GS.
Steffo is offline   Reply With Quote
Old 06-11-2009, 03:51 AM   #6
Dusty Rhodes
Yowie Chaser
Dusty Rhodes's Avatar
Oddometer: 1,558
I wondered why the frisbee was getting bigger , and then it hit me.
Dusty Rhodes is offline   Reply With Quote
Old 06-11-2009, 03:52 AM   #7
philth
philth
philth's Avatar
Oddometer: 6,198
nice so far you rock chuckin son of a ....
philth is online now   Reply With Quote
Old 06-11-2009, 04:06 AM   #8
gricho
Trust me its this way
gricho's Avatar
Oddometer: 131
Excellent so far Pezza, keep it coming.
http://www.advrider.com/forums/showt...=fraser+island
Growing old is inevitable. Growing up is optional.
gricho is offline   Reply With Quote
Old 06-11-2009, 04:23 AM   #9
kktos
on a bright side of life
kktos's Avatar
Oddometer: 2,345
Thumb
Good stuff in here !
(and I've a bmw)
And thanxs for the informative thread's title. It helps me to pick ur amongst hundred ;)
/thierry
Vita brevis, ars longa, occasio praeceps, experimentum periculosum, iudicium difficile
08 R1200GSA Red 21" woody's
morocco 2006 | morocco 2007 | Traces of Kimangao: An HP2 in France, Spain and Italy | Morocco 2008: a F800GS test ride | where the destination is Anamur - Turkey via Greece...
kktos is offline   Reply With Quote
Old 06-11-2009, 04:32 AM   #10
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,465
Mate,
Thanks for giving me ichy feet.
Gotta get out there some time myself. On BMW's off course.
tmotten is offline   Reply With Quote
Old 06-11-2009, 04:33 AM   #11
pugsley
Little Man
pugsley's Avatar
Oddometer: 639
Keep it comin mate,great so far!
pugsley is offline   Reply With Quote
Old 06-11-2009, 05:02 AM   #12
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
Good shit Pezza
Keep it comming mate
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 06-11-2009, 05:18 AM   #13
monkey
Oddometer: 38
It can become quite spooky out there in the Never-Never, the silence, those strange occurrences.
Weird stuff... like your footprints in the dust...how do you explain their direction....those prints show you walking towards the bike.
Themonk
monkey is offline   Reply With Quote
Old 06-11-2009, 05:41 AM   #14
DRjoe
DRjoe's Avatar
Oddometer: 5,095
nice one pezz, hurry up and post some more pics.
Old 06-11-2009, 06:01 AM   #15
Pezza OP
Pezza's Avatar
Oddometer: 339
Maaaaate, was sorta hopin you'd forgotten bout that by now.
Times are GMT -7.   It's 04:27 PM.
