06-15-2009, 02:32 AM
#1 |
Oddometer: 1,075
BMW R80 G/S Fork setings ?
Hello
my G/S fork seems to had something like a too soft spring ? When I put my weight on the bike, the fork go down of 5 centimeters (2 inches), I've set the rear Olhins for 2 centimeters (a litel more than 1 inche) Oil is 10w the previous owner had changed fork springs for new BMW. Any draw back about some progressive springs ? I want to stay with this fork, his dual disc and BMW fork brace ![]() ![]() The entire bike ![]() Thanks in advance for all reply |
06-15-2009, 04:03 AM
#2 |
Oddometer: 3,733
I keep trying progressive springs in various bikes but cannot get on with them. Most folks seem to like them though.
I've got similar issues to yours with my G/s since fittng a Wilbers rear shock a few months ago. I'm going to try fitting preload spacers to see if it helps. |
06-15-2009, 04:12 AM
#3 |
Dutch fool
Oddometer: 679
Give these guys a call;
http://www.hobbyist.nl/ They make their own set of springs, 46,50€ with 6 months return garanty. I've fitted them on several older airheads with good results. Paul. |
06-15-2009, 04:14 AM
#4 | |
Oddometer: 1,075
Apologizes for my poor english |
06-15-2009, 04:50 AM
#5 |
Dutch fool
Oddometer: 679
Shortening the spring will make it stiffer.
Just cut-off, say 2-3 cm and add a spacer of similar lenght, testride. Repeat if neccessary. Paul. |
06-15-2009, 07:34 AM
#6 |
Beemerholics Anonymous
Oddometer: 7,354
Springs too soft and too much sag are two entirely different things.
If the forks don't bottom out, then I'd think they're stiff enough. Sag is handled with pre-load spacers. The travel on these forks is supposed to be close to 8 inches, so 2" of sag should be about right. Why are you using 10wt oil? Spec is something like 5 or 7.5 - if you are using stiffer springs, stiffer oil would be necessary, but otherwise it would make for a harsher ride.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
06-15-2009, 08:30 AM
#7 | |
Oddometer: 1,075
Oil, I've put 10W because it was stiffer and in my storage The fork doesn't botom out but act lik if I was having 2.5W oil and weak springs |
06-15-2009, 08:47 AM
#8 |
G(/)S ... what else!
So, it is bouncy (bouncing)?
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net |
06-15-2009, 08:55 AM
#9 |
Oddometer: 1,075
Not really bouncy but for me terribly not enough "brake" on botoming (or going down) the fork never botom on normal use.
Afrer reading reply and wrinting my feeling I suspect a bad oil, it was in closed botle in my storage but I suspect it to be out of order |
06-15-2009, 09:54 AM
#10 |
This is a linear not progressive spring, so the "braking" when getting closer to the bottom doesn't happen. Before you open it up, try 15W or even 20W oil to see what happens. I had the same problem with my G/S and made a very successful experiment. Read here:
http://www.stephenbottcher.net/BMW/springrates.htm Maybe that helps. I still got a couple of pieces of springs left over. You are welcome to it. I still owe you for the KTM tacho (which I never got to work right). A bientot.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me] ... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake] Stephen Bottcher Ontario, Canada '72 R75/5 The Blues www.stephenbottcher.net StephenB screwed with this post 06-15-2009 at 10:07 AM |
06-15-2009, 10:42 AM
#11 |
Oddometer: 1,075
Thanks Stephen
In first I'm going to drain the fork oil and to put some Bel Ray in it and see whats hapends. After that progressive springs could be an interesting try |
06-15-2009, 10:43 AM
#12 |
Motor Sickle Addict
Oddometer: 1,076
some say a good rule of thumb is that the springs are correct if when in the real rough stuff you bottom out every now and then but not often.
i like my suspension to have sort of a plush ride, i have noticed that when on a real rough jeep road or single track with steep areas with ruts etc that it does bottom out sometimes. |
06-15-2009, 03:29 PM
#13 |
OH.THAT'S GONNA HURT
Oddometer: 3,814
Caddy-looks like you've been spraying some paint on the old girl. Looks good.
2004 BMW R1150RS 1984 BMW R80G/S (wrenching index) 2003 Suzuki DRZ 400S (TAT Prep) One More DRZ does the TAT (Ride Report) |
06-15-2009, 03:57 PM
#14 |
Chronic Noob
Oddometer: 2,292
Volume
Try increrasing the volume to 225ml or even slightly more but not past 250ml as this is where hydraulic lock willl start to happen.
Spacers and spring amputation work well but this is a no cost reversible modification. The effect of more oil is to increase the compression damping mainly at the compressed end of the stroke without effecting the rebound. ATF (auto tans fluid) about 7.5 wt depending on brand and type works well for me and is cheap. |
06-15-2009, 04:12 PM
#15 | |
Dutch fool
Oddometer: 679
By adding more oil, you reduce the volume of air above the oil and by doing so the trapped air will act like a spring. Adding too much oil will eventually push that airpressure op to a level the forks will not compress anymore and feel rockhard. (like your hydraulic lock) Paul. |
