Old 06-17-2009, 04:39 PM   #61
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 25,819
iPhone 3.0 software is out for all you iPhone geeks.
Connect to iTunes, click your phone, click Check for Updates.
Cut & Paste.. FINALLY!
www.motogeek.com
Old 06-17-2009, 04:39 PM   #62
vmabuck
Clutch Killah
vmabuck's Avatar
Oddometer: 441
I'm with you on that idea man!
I would have to buy internal bags for the 100% waterproof bags anyway, it would either be that or take the saddlebags off to store your stuff in the tent/room etc... and I don't want to be doing that.
Plus the rack system is so simple...
05 DR650
azbuck
Together We Served
vmabuck is offline   Reply With Quote
Old 06-17-2009, 04:41 PM   #63
vmabuck
Clutch Killah
vmabuck's Avatar
Oddometer: 441
Oh shit! What about txt pics? I heard a rumor this next upgrade will have this?
Going in now!
05 DR650
azbuck
Together We Served
Old 06-17-2009, 04:53 PM   #64
vmabuck
Clutch Killah
vmabuck's Avatar
Oddometer: 441
Nice!
Landscape keyboard for all applications, txt and movie mms. Those are the two big ones for me.
I do like the enhanced calender though, much better and syncing of notes will be nice...
05 DR650
azbuck
Together We Served
Old 06-17-2009, 05:51 PM   #65
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 25,819
So I jinxed myself by saying itunes sucked on this thread yesterday.
Connected my iphone.
clicked "check for updates"
itunes said "you need to update to itunes 8.2 before you can upgrade your phone to 3.0"
I said ok.
Downloaded and installed itunes 8.2
Now iphone doesn't appear anywhere in the system. Can't detect it.
Restarted the apple mobile service, confirmed the usb drivers, uninstalled, downloaded and reinstallled itunes completely. Nada.
It worked an hour ago so I know its itunes fault as nothing else has changed.
Argh.
www.motogeek.com
Old 06-17-2009, 06:30 PM   #66
vmabuck
Clutch Killah
vmabuck's Avatar
Oddometer: 441
I am also having issues. It saidl I needed to update as well, tried it but it failed. Then downloaded iTunes frm the site and on install bonjour service would not activate and the install rolls back and quits.
I am now uninstalling everything and installing all components separately.
This is bullshit...
05 DR650
azbuck
Together We Served
Old 06-17-2009, 06:36 PM   #67
BikePilot
BikePilot's Avatar
Oddometer: 10,901
Good stuff. I built a new machine last winter. Amazing how low the prices are for quality hardware these days - also amazing how well the 45nm chips OC. I just got the cheap E5200 dual core and OC'd it to 3.6 on air with no problems and voltages that don't even exceed Intel's conservative limits
I put windows 7 build 7000 on it. I might have caused myself some trouble though as I'm not sure I'll be home before it expires. Shouldn't be too much of an issue if it has though as I stuck it on its own partition on my raid array. I have everything backed up (more or less), but don't want to re-build the array if I don't have to. Will definitely put RC on it when I get back home.
My build is more or less:
Asus P5K Deluxe Wifi
E5200 @ 3.6ghz
Zaleman 9500 cooler (already had it)
4gb OZC Fatal1ty 800mhz ram
3x WD5000YX drives in RAID-0
1x F1 Green drive as backup
CM690 case and bundled 550W PSU
HD4830 GPU (OC'd past 4850 specs, amazing gpu for the cost)
W7 Build 7000 (need to update to RC, but have been away from home for a while now).
I don't game except for a little bit of FSX, otherwise its a school work and photo editing/storage box.
pics
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot screwed with this post 06-18-2009 at 11:02 AM
BikePilot is offline   Reply With Quote
Old 06-18-2009, 09:15 AM   #68
Milhaus
Made in Denmark
Milhaus's Avatar
Oddometer: 3,003
Send a message via AIM to Milhaus Send a message via MSN to Milhaus
I said ok.
Argh.
I got 3.0 downloaded and installed this morning! Woot! Nice features. I am scheduled to get the 3Gs tomorrow a.m. so that should be cool! I don't think I will activate it until Sunday though. Too much riding coming up that I can't afford any hiccups in the activation sequence.
| 2006 KTM 450EXC |
www.mypersonaldefense.com
Milhaus is offline   Reply With Quote
Old 06-18-2009, 10:40 AM   #69
james t kirk
james t kirk's Avatar
Oddometer: 267
i've used these system building guides for a few years. usually i follow the 'hot rod' build.
http://www.arstechnica.com/hardware/...09-edition.ars
but my 'hot rod' build of a few years ago, blew up!
this is a Gigabyte GA K8NS ultra 939:
to replace this i just went with the 'budget' build. i'm happy enough with the ASUS M3A78-EM. on board everything! after all, in a couple years all of the top of the line stuff is obsolete anyway...i need the $ for motorcycle parts! the machine is back up and running great! with new MOBO, AMD Athlon x2, 4GB memory and a new Pioneer DVD burner.
my question is: what is this that blew? it was plugged into a surge protector.
kirk out
james t kirk is offline   Reply With Quote
Old 06-18-2009, 10:56 AM   #70
BikePilot
BikePilot's Avatar
Oddometer: 10,901
That's an impressive failure! Its hard for me to tell what was there before it blew - is a capacitor missing?
Old 06-18-2009, 11:44 AM   #71
Milhaus
Made in Denmark
Milhaus's Avatar
Oddometer: 3,003
kirk out
Chances are pretty good that is was a ceramic capacitor. There doesn't seem to be any residue to indicate an electrolytic cap blew. The ceramic caps are brittle and their coefficient of thermal expansion don't match that of the substrate PCB and when the board heats and expands it will tend to crack the ceramic cap and KABLOOIE!!
| 2006 KTM 450EXC |
Old 06-18-2009, 12:13 PM   #72
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,022
Just got my new motorcycle-approved handheld
John
http://rerax.net/index.html
jet123 is offline   Reply With Quote
Old 06-18-2009, 12:57 PM   #73
doc_ricketts
Thumper jockey
doc_ricketts's Avatar
Oddometer: 4,024
And it all started with this:
"Get yourself to the hills and be uplifted, assuming you got some good knobbies"
doc_ricketts is offline   Reply With Quote
Old 06-18-2009, 02:07 PM   #74
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 25,819
My current machine I'm running a RAID 5 array but was going to change it up for the new machine.... originally I was considering doing RAID-0 with my four 10,000rpm Raptors since everyone raves about the bench marks of 4 drive stripping... and then I was actually going to run a RAID 10 (which is a RAID 1 Array of two RAID 0 arrays) and get "the speed of RAID 0 with the redundancy of RAID 1).
But then I read this about real world usage:
http://www.anandtech.com/storage/showdoc.aspx?i=2969
and this article from a couple of years before:
http://www.anandtech.com/storage/showdoc.aspx?i=2101
...and the more I read, the sadder I got
Considering you end up with multiple times the failure points (if one drive goes down you lose the data on all of them) and the real-world performance gain is around 2-3% - not 30+% that "benchmarks" claim... I decided to go for Raid 5 and get the data redundancy instead.
YMMV.
www.motogeek.com
Old 06-18-2009, 02:15 PM   #75
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 25,819
"I think there is a world market for maybe five computers".
- Thomas J. Watson Snr., IBM Chairman, 1943
"640K ought to be enough for anybody."
—Bill Gates on Computer Science 1981
"Your most unhappy customers are your greatest source of learning."
- also Bill Gates
www.motogeek.com
Times are GMT -7.   It's 07:58 PM.
