Old 06-17-2009, 09:53 AM   #1
Pwnzilla OP
Sexual Tyrannosaurus
Pwnzilla's Avatar
Oddometer: 230
Pro Taper Bars on DR650
Hey guys, I'm looking to get a set of Pro Taper bars for my '09 DR650. I have now bent my second set of OEM bars so it's time to move away from them. I am looking at these:
http://www.motorcycle-superstore.com...Handlebar.aspx
My question is, do I need the different mounts from Pro Taper or can I use my stock mounts?
2009 Honda CRF230F
2013 Yamaha TW200
2014 Harley Iron
Pwnzilla is offline   Reply With Quote
Old 06-17-2009, 10:06 AM   #2
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,125
pro taper se bars
No, not needed. These are 7/8" bars. I am quite sure the stock dr650 bars are 7/8"
I put a set of se's on my xr which is 7/8" too
SE actually stands for Seven Eighths
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 06-17-2009, 10:08 AM   #3
Pwnzilla OP
Pwnzilla's Avatar
Oddometer: 230
Perfect thank you for the info.
Didn't realize SE was 7/8's.
2009 Honda CRF230F
2013 Yamaha TW200
2014 Harley Iron
Old 06-17-2009, 10:16 AM   #4
LukasM
Oddometer: 5,415
If you are going to get new bars, I would spend the extra $$ and get the oversize ones incl. the mounts. Much stronger over all and since you seem to be riding your bike off road it will be cheaper in the long run.
Old 06-17-2009, 10:28 AM   #5
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,949
A friend of mine just mounted some Pro Taper Pastrana fat bars on her DR, and with the adapters, they are a direct fit.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is online now   Reply With Quote
Times are GMT -7.   It's 09:49 PM.
