Old 06-18-2009, 12:08 PM   #1
xhaleKLR OP
xhaleKLR's Avatar
Oddometer: 57
ammo can panniers
I have read all kinds of threads on here about how people have used ammo cans as panniers on their bikes. I have an 08 KLR650 that I am thinking of doing this with. I was wondering if anyone had any pictures of the install process. Also, what would be the best racks to use for this application?
xhaleKLR is offline   Reply With Quote
Old 06-18-2009, 12:24 PM   #2
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,955
IIRC, at least one of those threads on here had pics and description of the install process.
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 06-18-2009, 12:46 PM   #3
jgrady1982
jgrady1982's Avatar
Oddometer: 782
I bought 2 20mm ammo cans that are still sitting in my garage. I am currently restoring a 1986 Honda XL600R, and once the bike is done I am going to weld on two tabs to the frame and construct a rack for the cases. I will be sure to post a thread when I do this.
Good luck,
Jack
jgrady1982 is offline   Reply With Quote
Old 06-18-2009, 02:45 PM   #4
Saltbox
WTF is this?
Saltbox's Avatar
Oddometer: 1,343
Cheap ass setup!
Here is my cheap ass ammo can setup, I used the smaller cans (better off road). That and I don't need to lug tons of crap around, thats what the rack and waterproof duffle are for.
Since I can't weld for shit, actually I don't know how I came up with this home brewed solution using electrical conduit, gas piping and a few bolts. They have held up really well, although I did puncture one of the ammo cans last weekend when the bike went down off road. My mounting system held up fine though.
I think ammo cans were made for the KLR.
Saltbox is offline   Reply With Quote
Old 06-18-2009, 02:48 PM   #5
GordMounce
Oddometer: 189
How did we all know that the OP was referencing a KLR for ammo can panniers even though it wasn't in the subject line? lol!
GordMounce is offline   Reply With Quote
Old 06-18-2009, 03:40 PM   #6
xhaleKLR OP
xhaleKLR's Avatar
Oddometer: 57
I wrote in my original post that I have a 08 KLR.
Old 06-21-2009, 11:32 PM   #7
crash50
Idaho Back Country
Oddometer: 191
25MM Bradley ammo cans
I picked up a few of these and although I already have the HT set, I put these on for in the mtns. Smaller means less gear, but the hard plastic, something similiar to Pelicans I think are pretty bombproof.
Unable to post pictures as I have no way of doing it.
The 25MM sases are about $19 a piece.
crash50
McCall,ID.
2006 KLR650
2006 DL1000
crash50 is offline   Reply With Quote
Old 10-18-2010, 06:55 AM   #8
CRio
KLR Obsessed
Oddometer: 13
Ammo can panniers
I just finished mounting my ammo can panniers on my 2008 KLR. I've included a few links to my blog if you want the detailed process and more pics. I hope this helps.
http://klr650reviews.com/2010/10/02/...s-part-1-of-2/
http://klr650reviews.com/2010/10/16/...3-part-2-of-2/
2008 KLR650
www.KLR650Reviews.com
CRio is offline   Reply With Quote
Old 10-18-2010, 07:12 AM   #9
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,962
I did ammo box panniers on my 07 KLR...
...and although they worked just fine, I wouldn't do it again.
Just too damn heavy for me.
I used the boxes that were about 9"W x 18"L x 14"D and they had lots of room, but each box weighed in at over 20 pounds! That's more than double the weight of most aluminum pannier boxes.
I bought the mounting racks from KLR650.com (about $250 with mounting hardware for the boxes) and the ammo cans were about $22 each at a local Army surplus store. Other costs for mine were $25 for four lockset cylinders keyed alike and about $15 for rattlecan pickup bed liner spray paint.
Unfortunately I don't have any photos as they were destroyed when my house burned in early 2007. I will say this, after the fire the ammo boxes were one of the few things in the garage (where the fire started and burned hottest) that were still relatively intact!
IMO, the bottom line on ammo box panniers is that they are probably the most rugged thing you can use but will also be the heaviest. Mine really affected the handling of the bike in a bad way, particularly off road.
Now I use soft bags on both my bikes and am much more satisified. Were I shopping for metal panniers though, I'd go Jesse without hesitation.
My 2
GSBS is offline   Reply With Quote
Old 10-18-2010, 08:40 AM   #10
Fire Escape
Fire Escape's Avatar
Oddometer: 1,588
Talking Yes they are heavy but....
I have had these 20mm cans on my DR for over 2 years now. I was going to put on some nice aluminum boxes so I got SW Motech racks from Twisted Throttle as a first step. Once the racks were in place I recalled having these cans burried in the garage (came from the father of a friend, there were two 50 cal. cans - the things I wanted at the time, packed in each one) so ......after substantial digging I decided to use these as a "trial" and decide where to go from there. Rather than spend more $$ on detachable mounts (only a temporary trial after all) I bolted them in place with enough fender washers between the rack and box to clear the diagonal stiffening rib. The rack itself (with box) comes off the bike with 3 "Dzus" fasteners per side which I do when loading in the camper or contemplating anything approaching "serious" off-road riding.
They are indeed heavy, I have to pay attention to where I park because they settle the bike down on it's suspension (I actually need some new springs, not so much for the boxes but because I am fat enough to be 2 people). The bike is my "daily driver" throughout the winter while camping somewhere much warmer that New England, I do all my grocery shopping and errands with it, being careful to load the heavier stuff in the left side and unload that one last so the bike stays upright. I haven't measured the boxes but did learn that a gallon paint can will fit with room to spare.
The only "real" drawback I found (once I got used to the weight) was that with the military markings still in place, cars were reluctant to get very close, arround here that means that I would often sit through several traffic light cycles because the bike alone doesn't trip the signal trigger. Adding a few touristy stickers solved that. and I have no plans to replace them anytime soon. YMMV.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 10-18-2010, 08:55 AM   #11
dlh62c
Oddometer: 1,603
My advice ...Don't do it.
I know their cheap and robust, but their also heavy. I was set to install a couple on my bike, but was talked out of it by an inmate. The money I would have saved would have gone out the window if I had to replace a tweaked or busted sub frame on the bike. I would much rather have a pannier explode like a ripe melon than break the frame.
Touratech now sells a rack for the KLR650. http://www.touratech-usa.com/Store/1134/KLR-650,
So does Happy Trails: http://www.happy-trail.com/KLR650/Al...e-KLR650E.aspx
What ever you do, make them easily removable.
If your still set to use ammo cans, Youtube has a video on it: http://il.youtube.com/watch?v=y7bKLe...eature=related
daryl
dlh62c screwed with this post 10-18-2010 at 09:29 AM
Old 09-13-2012, 03:55 PM   #12
Sak
Oddometer: 10
Wicked 25mm plastic cans
Hi Luggage Fetishists,
I'm about to install some 25mm "plastic" ammo can panniers. These ...cans... sure are beauties! Ebay has them for cheap ($11 +shipping) again. They just arrived last night, and believe me, UPS wasn't kidding when they put the shipping weight at 35 lbs for the three of them!
Here's one with a size 10 (US) boot for comparison:
Internal volume is nothing to write home about. One boot fits inside the can. Unfortunately you'd have to open the other side to put the other boot in. A proper rigid moto boot would never fit. Part of the problem is the many ridges that stiffen the case and kept those 25mm cartridges from knocking around.
The material is some sort of glass-reinforced plastic (aka fiberglass), presumably a thermoplastic. I don't doubt what other inmates have said about these taking a screw thread directly. Because of the rigid material, thickness and the multiple massive internal ribs they make Pelican and Storm cases feel like Tupperware. I filled them up with water to rinse out some of the depleted uranium and they seem to hold water.
I trimmed off one of the ribs, which wasn't too hard with an "oscillating multi-function tool" a.k.a. "manbrator." I think the glass fibers dull the blade quickly though so I'll switch to an angle grinder. At the bottom of the image below you can see a 10mm ridge that I chopped off the middle of the lid. There is some melted plastic burring. The polycarbonate sheet at the top of the image will become a shelf that will conveniently separate the merely dirty things in the top of the case from the really filthy stuff at the bottom :
The Ebay seller that I used also had cheap MOLLE radio pouches ($2, FS) so I ordered a pair as liner bags. They fit like a glove, and the pouches alone are burlier than much of the soft moto luggage that I've seen:
Unfortunately the gov't asshats had to "demilitarize" them before releasing them to the surplus retailers by spray painting over those lovely ammunition specs. Some thinner on a rag sorted that out fairly quickly. Before (right) and after (left; was green):
I'm tempted to try to do some fancy lockable quick-release setup for my Givi Wingrack, but will probably just bolt them straight on. K.I.S.S and svelte.
That diamond-shaped blank area is calling out for some clever sticker. Although I giggled at the Hazmat explosive warning someone had, I worry that this just might attract too much of the wrong kind of attention. Maybe just a reflective Tuareg?
Thanks, all you pioneering inmates who've posted your pannier builds!
Sak is offline   Reply With Quote
Old 09-13-2012, 07:20 PM   #13
Switchblade315
Switchblade315's Avatar
Oddometer: 5,698
this is my set up on my 82 XL500R.
I had a plate welded to them and two one inch square rods welded to that, I have square tubing welded under my rear rack that the rods slide into. and two bolts go through that to hold them on. takes less then 5 minutes to take them off. if i swapped the bolts for pins it would take less then 2 minutes to take them off or put them on.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 09-13-2012, 11:28 PM   #14
Tooltech
Oddometer: 132
Fire away...ammo box wet dream:
http://www.youtube.com/watch?v=Gf1dbdNJMSc
Typical KLR...heavy, slow, cheap and runs forever.
2013 KTM 500 EXC
2012 KTM 990 SMT
6 NOVEMBER 2012 DARK DAY FOR USA
Tooltech is offline   Reply With Quote
Old 09-13-2012, 11:35 PM   #15
_cy_
Oddometer: 6,329
if you are bound to do this... go with aluminum mil surplus cans
much lighter ... all sorts of thread telling you how
_cy_ is online now   Reply With Quote
Times are GMT -7.   It's 11:16 AM.
