Old 06-22-2009, 06:31 AM   #1
Waco OP
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,972
Old brake fluid
If a partially full bottle of DOT 4 brake fluid has been sitting on the shelf for a few years, with the cap screwed on tight, is it OK to use for brake fluid replacement?
Support the AMA.
Waco is offline   Reply With Quote
Old 06-22-2009, 06:46 AM   #2
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Don't quote me or anything, but everything I've ever read says to toss it and get a new sealed bottle. The problem is that brake fluids absorb water from the atmosphere, and it's unlikely that you've got a true hermetic seal from just the cap.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 06-22-2009, 07:02 AM   #3
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
Any open brake fluid that's been around at least 6 months, I chuck.
I use a Sharpie™ to mark the date opened on the cap so I can keep track of how old it might be.
Don't cheap out on your brake fluid. It doesn't cost much new, but the price of being "thrifty" can be quite expensive.
Old 06-22-2009, 07:44 AM   #4
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,475
you can quote me.
Deep six it.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 06-22-2009, 07:44 AM   #5
VonHelm
soggy doggy
VonHelm's Avatar
Oddometer: 3,994
Toss it out.
http://www.oilandpiston.com/
Well he’s one of those who knows that life
Is just a leap of faith
Spread your arms and hold you breath
And always trust your cape (Guy Clark)
VonHelm is offline   Reply With Quote
Old 06-22-2009, 08:40 AM   #6
2speed
Puching adventurer
2speed's Avatar
Oddometer: 848
I heard that at least the DOT 3 which absorbs more water than 4, takes on 5% a year. So in 5 years it's 25% water in the bottle.
Loud intakes save lives!
2speed is offline   Reply With Quote
Old 06-22-2009, 09:04 AM   #7
JDLuke
JDLuke's Avatar
Oddometer: 8,644
And just think, after 20 years it's ALL WATER!!!!
Old 06-22-2009, 10:18 AM   #8
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,138
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 06-22-2009, 10:33 AM   #9
2speed
Puching adventurer
2speed's Avatar
Oddometer: 848
Well that's what I get for anecdotal evidence. According to this you can use it.
Water absorption and corrosion
The big bugaboo with DOT 3-4 fluids always cited by silicone fluid advocates is water absorption. DOT 3-4 glycol based fluids, just like ethylene glycol antifreezes, are readily miscible with water. Long term brake system water content tends to reach a maximum of about 3%, which is readily handled by the corrosion inhibitors in the brake fluid formulation. Since the inhibitors are gradually depleted as. Since the inhibitors are gradually depleted as they do their job, glycol brake fluid, just like anti-freeze, needs to be changed periodically. DOT 5 fluids, not being water miscible, must rely on the silicone (with some corrosion inhibitors) as a barrier film to control corrosion. Water is not absorbed by silicone as in the case of DOT 3-4 fluids, and will remain as a separate globule sinking to the lowest point in the brake system, since it is more dense.
Old 06-22-2009, 03:27 PM   #10
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,821
Just get new fluid.
I change the fluid in all master cylinders at least once per year. Cars and bikes with this thing:
Home made evacuation device:
Action shot:
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 06-22-2009, 06:09 PM   #11
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,025
Using this as evidence, you could argue that you should never change your brake fluid. Is that the point you were trying to make?
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 06-22-2009, 07:04 PM   #12
GSMark
Just Love Bikes
GSMark's Avatar
Oddometer: 859
You want your brake fluid to absorb water (DOT 5 does not do this). Brake fluid absorbing water is a good thing. If it does not absorb water, think about what happens when the weather gets below freezing. Ice does not make a good brake fluid. The next problem is on the other side of the coin. Too much water absorbed will lower the boiling point of the fluid. Once the brake fluid boils, gas bubbles are introduced into the brake system. These gas bubbles never go back to liquid form. Just like having air trapped in the line. That is why it needs to be replaced often and why you should only use "fresh" brake fluid. If it has been opened for more than 6 months, I don't want to take the chance. It's just not worth it to me.
***** Don't confuse DOT 5 with DOT 5.1. DOT 5.1 is mineral-based just like DOT 3 and DOT 4 and will work in DOT 3 & 4 systems. Why they named this DOT 5.1, I will never know... just adds to the confusion.
Waco Kid, just get some new fluid and dump the old stuff on some weeds. (Oh no! It will end up in our ground water and we will all die!)
AMA Earned Life Member • Iron Butt Association Member
suttoncycleworks.com
Honda XR650L XR600 NX650 Oil Cooler Kit
• KTM 990 Adventure • Honda CRF450 Supermoto • H-D Sportster Streettracker • Honda XR650L
GSMark is offline   Reply With Quote
Old 06-22-2009, 07:15 PM   #13
Waco OP
Waco's Avatar
Oddometer: 14,972
Already bought some, but after reading the instructions, it looks like I need a lot more.
How much do speed bleeders help? I've replaced brake fluid before, but this will be my first attempt on a BMW with ABS.
Support the AMA.
Waco screwed with this post 06-22-2009 at 07:37 PM
Old 06-22-2009, 08:02 PM   #14
GSMark
Just Love Bikes
GSMark's Avatar
Oddometer: 859
I have a BMW with ABS.
I purchased some speed bleeders a while back and I never installed them. Bleeding the brakes is so easy (after I got a mityvac about 10 years ago) I don't know why I bothered wasting the money on speed bleeders. Others may love the speed bleeders though. Also, I have heard tails of people braking them off. Some people are "heavy handed" with their wrenching. I would suggest spending your money on a Mityvac before spending money on speed bleeders. YMMV
BTW, Do you want my speed bleeders?
Old 06-22-2009, 09:17 PM   #15
Waco OP
Waco's Avatar
Oddometer: 14,972
My goal is to do my brakes tomorrow, so I guess not.
Support the AMA.
Times are GMT -7.   It's 07:53 AM.
