Old 10-12-2009, 02:14 PM   #46
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,419
Originally Posted by Big John Sny
Here is what the gears look like
The tensioner pushed back
Here is the wear on the inside of the tensioner
Anyone with a little experience putting their eyes on the inside of the engine be able to give me an idea how bad the wear looks to them?
Yeah, I have had a few people tell me that it will all be ok once I get everything sorted out. I think the bad part was that I just got finished doing a ton of work on the Shadow and traded for this bike that was supposed to not need anything but a bit of oil leak sorted out.
Look good! If you didn't see maintenance records whatever was said about the condition of the bike is irrelevant! Records are everthing when buying an old airhead.Still, I think you have an essentially good bike, that will run trouble free when it is sorted. Mine does.
Go far or stay home.
durtwurm is offline   Reply With Quote
Old 10-12-2009, 02:17 PM   #47
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,419
I note that your oil pan is clean,that is a good sign. Bikes that are parked with dirty oil will have congealed blobby oil in the pan.
Old 10-13-2009, 06:15 AM   #48
Big John Sny OP
Big John Sny's Avatar
Oddometer: 668
If the crank gear doesn't look too worn by those with experience, maybe I should just finish the pushrod tubes and put it back together. So is the concensus that 1/4 inch of overlap is pretty normal or at least not that bad at full advance? Ha, maybe I am too much of a perfectionist.
My Grandfather was having trouble with a lifter in a desiel engine and was consulting one of his friends that did a lot of diesel work on what he could do about the tick, tick, tick noise. His friend told him just to drive it. He said, "pretty soon it will be making a whack , whack , whack noise and you will forget alllll about that light tick, tick, tick, noise."
I guess I should focus on getting rid of the oil leaks, then the steering head bearings, then make sure the tranny splines are lubed. Maybe see if an electronic ignition smooths out the timing some later on down the road.
4 out of 3 people have trouble with fractions.
1999 Ducati Monster, 1979 XS650, 1976 Aermacchi/Harley SS250, 1976 Aermacchi/Harley SS175,1981 R100
Big John Sny is offline   Reply With Quote
Old 10-13-2009, 10:56 AM   #49
mikertoo
Oddometer: 4
Hahaha - I like your Grandpas story. It reminds me of a guy here... he was complaining about the transmission on his Japanese bike. I told him all he had to do was borrow a BMW for a couple days, and after that his tranny would be fine. ;)
Frankly, the transmission is exactly why I wouldn't use my '78 R100/7 as a commuter - too clunky to enjoy riding excepy on the open road. I'm on the lookout for an SV650 now.
miker/too
mikertoo is offline   Reply With Quote
Old 10-13-2009, 01:02 PM   #50
dilandau
dilandau's Avatar
Oddometer: 826
just wear big clunky boots and a big clunky helmet and clunky gauntlets and all the clunking sort of cancels itself out.
so far 2 months in commuting with the r100 and it does the job! but it is mostly highway- about 50miles round trip.
morini 3.5 strada & sport, r75/6, duc 900sd (project)
dilandau is offline   Reply With Quote
Old 10-14-2009, 01:03 PM   #51
Big John Sny OP
Oddometer: 668
I like commuting the bike. Just wish it was back together so I can get back to commuting on it.
Old 10-14-2009, 01:54 PM   #52
Almiscarado
Oddometer: 52
I am working on a R65 to get her on the road and use it for commuting.
Sometimes I wonder if it will be really reliable enough for the job... cracking coils, hall sensor madness, freakin diodes can go bad, ignition module can fry, hmm what else?
But i am still in love with it and learning how to fix her by the side of the road :p
(might be trauma, but my R65 was the first bike that left me on the road and I had to call for help -> bad crack-o-matic coil = no spark)
Almiscarado is offline   Reply With Quote
Old 10-28-2009, 12:04 PM   #53
Big John Sny OP
Oddometer: 668
Been working too much overtime. I finally got the timing cover back on with new seals. The quality department said they would recalibrate my span on dial torque wrench, so I figured that would be a good idea before I start torquing the heads anyways. Also pick up a motorcycle lift over the weekend so maybe I wont even have to do it on the floor.
Old 10-28-2009, 02:07 PM   #54
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,636
You're joking, right?
crazydrummerdude is offline   Reply With Quote
Old 11-30-2009, 11:49 AM   #55
Big John Sny OP
Oddometer: 668
I really did not intend to have my bike apart for this long. I did get a shiney new screw installed in my foot though to hold the bone that wasn't healing together, so I have a bit of an excuse. Here is a pic of my bike paitiently waiting on the new motorcycle lift. At least I got the lift set up in the garage.
Old 11-30-2009, 11:10 PM   #56
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,967
here's a good place for specific r65 stuff if you haven't found it already.
i bought mine from an adv member this summer, and thanks to his efforts in maintenance and light restoration it's been exceedingly reliable and fun to ride.
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 12-11-2009, 05:29 AM   #57
Big John Sny OP
Oddometer: 668
Finally able to stand on my foot some so I got the cylinders done.
The valves looked good. No valve recession.
The carbon looked even across the piston tops
Still plenty of crosshatch in the cylinders
Everything went pretty smooth, but I started to run out of time on the second cylinder. Trying to keep track of all the rubber o-rings and make sure they stayed in place, I nearly left the piston circlip out.
I used a thread file on the exhaust threads, but it still felt like the new nut was dragging a little, so a little more clean up and I should be able to finish the assembly. Then a tune up and hopefully riding this Sunday. At least it looks like it might warm up by then.
Old 12-11-2009, 06:26 AM   #58
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,973
You're gonna love commuting on this bike! I'm in my 16th year of using my R90 as an everyday rider, and it suits the mission just fine. Yeah, there's some fiddling and fettling to be done, but that just enhances the experience, IMHO. There's something to be said for having an "appliance" bike for workaday stuff, but having a mechanical relationship with yours will be something special.
40 degrees and raining today, but the Airhead is still going to carry me to work.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 12-11-2009, 10:55 AM   #59
Claim Jumper
will work for knobbies
Claim Jumper's Avatar
Oddometer: 525
Cool thread! I have a nearly identical bike, except mine is a '77. Same color, same leaking gaskets, same low mileage (mine has 12,000 verified miles). I am treating the gas tank with POR-15 and will try and do the pushrod seals soon (if it gets over 20 degrees at night sometime). I already replaced the floats, rebuilt the petcocks and replaced the pan gasket. It is really uncanny how alike these bikes are, I must post a pic.
ChrisGo
01 DRZ-400S
77 BMW R100/7
Claim Jumper is offline   Reply With Quote
Old 12-15-2009, 07:59 AM   #60
Claim Jumper
Oddometer: 525
ChrisGo
01 DRZ-400S
77 BMW R100/7
Times are GMT -7.   It's 11:08 AM.
