Old 07-05-2009, 08:36 PM   #1
nitsuj OP
Oddometer: 347
1200GS leaking final drive
Ok, so I'm working on my friends 2005 1200GS. I replaced the final drive fluid, following the instructions on r1200gs.info, to the letter. Now there is a small amount of fluid leaking out of the black circular cover on the right side of the final drive. It's a tiny leak. I don't think anything I did changing the FD fluid could have caused it, but since I'm the last guy who touched the bike, I feel somewhat responsible. What would cause a small leak from that cover? Is there a seal behind it? Easy fix by chance?
nitsuj is offline   Reply With Quote
Old 07-05-2009, 09:21 PM   #2
gregseto
Oddometer: 28
There should be an o-ring between the fd and the sensor. Did you wipe the fd clean after you filled it? It could just be some residual fluid.
gregseto is offline   Reply With Quote
Old 07-05-2009, 09:24 PM   #3
nitsuj OP
Oddometer: 347
I did clean the o-ring. But that isn't where the leak is. It's on the right side of the bike. Coming from the black circular cover on the outside of the FD case.
Old 07-05-2009, 10:02 PM   #4
jabandsnort
a mighty fly dancer
jabandsnort's Avatar
Oddometer: 192
Blown seal? How much fluid did you put in? What viscosity?
This happened to mine after my fisrt fluid change, I got freaked and took it to the dealer. They told me I had a bad seal and replaced it under warrantee. Now I just ride with my fingers crossed....
jabandsnort is offline   Reply With Quote
Old 07-05-2009, 10:26 PM   #5
nitsuj OP
Oddometer: 347
I put in 180 ML. Carefully measured. The oil was Amsoil. Don't remember the weight, but it's the right stuff.
I assumed I had a leaky seal. What I'm trying to figure out now is if it's an easy fix from the outside, or a "Take the whole damn thing apart" type fix.
Old 07-06-2009, 09:07 AM   #6
drdata
R1200GS
drdata's Avatar
Oddometer: 1,914
Send a message via Yahoo to drdata
Pics?
When I did mine, I cleand up all the surfaces with a degreaser. Later after a ride in the dirt it was clear that some new oil seepage had attracted more dirt, but not what I would call a leak. No drips on the floor. Before the swap there was a simmilar level of greasy dirt, so In my mind no real change.
Regards
Have router, will split lanes for food.
drdata is offline   Reply With Quote
Old 07-06-2009, 09:23 AM   #7
nitsuj OP
Oddometer: 347
I didn't take pics of the leak, sorry. It's easy to imagine though. You have that ring on the right side of the final drive case. Imagine a very small amount of oil seeping out from under it. If you wipe it off, in 30 miles, its back. No puddles, no drips. Just a light weeping. If it were my bike, it probably wouldn't be sever enough that I'd mess with it yet. But the bike belongs to someone else, and I was the last person to touch it. I think I'm going to replace the seal under that little black cover.
Below is a picture of the Final drive case (Picture not of actual bike). You can see the circular cover I'm talking about. On the end of the axle. Small amount of fluid leaking there. I'd draw arrows to it, but I'm a newer Mac user and can't find a built in program to do it.
Old 07-06-2009, 09:32 AM   #8
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,487
It is a pretty easy user friendly repair.
Pry off the black cover, remove the clip and carefully pry out the seal. Use the old seal to tap in the new one, install clip and cover, and make sure the fluid level is good.
Jim
Old 07-06-2009, 09:58 AM   #9
nitsuj OP
Oddometer: 347
Excellent, that's that I suspected, thanks Jim. Let me ask you this, do I need to drain the fluid again to replace it, or is the level of the fluid below the bottom of the seal?
Old 07-06-2009, 11:59 AM   #10
JimVonBaden
"Cool" Aid!
Oddometer: 41,487
Depends on how much you lost, but count on losing some fluid as the level at the bottom of the seal is above the 9:00 drain bolt which is 180ml at the bottom of the threads give or take 5ml.
Jim
Old 07-06-2009, 01:06 PM   #11
drdata
R1200GS
drdata's Avatar
Oddometer: 1,914
Ah, OK. I was refering to the inside flange. Where the silver outer case mates with the darker wheel falnge or such. I've not noticed any wetness on the outside platsic cover as you describe.
Old 12-17-2009, 10:32 PM   #12
bonjing
Oddometer: 10
Jim
hI Jim,
Do you know the part number of the seal ? I live in a very remote are and I like to have the new seal on hand before i remove the old seal. Btw, my bike is 07 r12gs. Thanks
bonjing is offline   Reply With Quote
Old 12-18-2009, 06:13 AM   #13
leahyz
Gigantic Tool
leahyz's Avatar
Oddometer: 472
Check for play.
I had the same seal leak. Since I had an extended warranty it went to the dealer.
It came home with a whole new FD. Apparently there was some small amount of wobble perceptable in the bearings. Fortunately for me the warranty covered it all.
Z
Zach
Ft Wayne IN - Where the roads suck.
2006 Pacific Northwest Trip - Gone Wanderin...
2008 Trans-Am Trail Ride - TN & MS
leahyz is offline   Reply With Quote
Old 12-18-2009, 07:27 AM   #14
JetSpeed
ATAC Kfir Hack
JetSpeed's Avatar
Oddometer: 450
Originally Posted by bonjing
hI Jim,
Seal Part # 33117679862
Good Judgment Comes From Experience, Experience Comes From Bad Judgment.
JetSpeed is offline   Reply With Quote
Old 12-18-2009, 08:30 AM   #15
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 12,654
That is about as easy as it gets.
DELTATANGO is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
