Old 10-12-2009, 11:00 AM   #31
stupot
stupot's Avatar
Oddometer: 115
Originally Posted by DeeGee
Did you replace the washer that goes with the oil switch? It has a separate part number.
sure did!
stupot is offline   Reply With Quote
Old 10-12-2009, 04:38 PM   #32
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 19,871
What year and model? Mileage?
I don't have to be right to argue.
NICO
unaweep is offline   Reply With Quote
Old 10-13-2009, 11:13 AM   #33
stupot
stupot's Avatar
Oddometer: 115
04 54 plate 35k
Old 10-13-2009, 11:37 AM   #34
MORT666
MORT666's Avatar
Oddometer: 214
Oil pressure switch?
MORT666 is offline   Reply With Quote
Old 10-13-2009, 12:45 PM   #35
stupot
stupot's Avatar
Oddometer: 115
done that!
Old 10-13-2009, 12:56 PM   #36
DeeGee OP
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,882
Originally Posted by stupot
04 54 plate 35k
S'funny that as mine did the same approaching 35k miles 04 950 too. I changed the switch and have had no problems PITA to do, have you got any pics? You could clean the engine up and douse in talc like I did and you'll get an idea from whereits coming from.
DeeGee is offline   Reply With Quote
Old 10-13-2009, 01:10 PM   #37
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,423
My '04 did it at 25k.
Be sure that it isn't oil that has settled in the crevices of the engine from the pressure sender leak.
I did my base gasket and although no evidence of it leaking oil,it did leak coolant around the studs cos they were corroded....unless it was from something else.
BLUE(UK) is offline   Reply With Quote
Old 10-13-2009, 01:56 PM   #38
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
Low oil will not necesarily turn on the low oil pressure light. If you are reading oil on the dipstick then the oil is not low...its just low for the normal fill amount. If yout dipstick is dry they you are approaching a low oil condition. If the oil pressure light comes on then odds are bad things are imminent.
Seth S
Seth S is offline   Reply With Quote
Old 10-13-2009, 02:16 PM   #39
stupot
stupot's Avatar
Oddometer: 115
Yeah i did that too looks actually like the pics Deegee posted, When i replaced the pressure switch it was corroded but no oil around it. I took the bike to my local ktm dealer to speak to their mechanic. He has worked on the bike from new and has done every service and all the engine recalls, he reckons its not anything to worry about and as long as i keep an eye on the oil level it shouldn't be a problem, just annoying me!
Looks like there maybe some oil coming from around the rubber seal one the left hand casing, anybody had leakage from here? ps its an old picture its alot cleaner now!
Old 11-08-2010, 06:32 PM   #40
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Question Pix Of OP Sensor Replacement?
I've got an 04 with about 20K and an oil leak that also seems to point to the sensor. Or put it this way... I know IT'S leaking, once I change it I'll know if that's ALL that's leaking. I love this bike, but have done nothing but chase oil leaks since I got it.
Does anyone have any pix, or sage advice? This looks like it's about to be a lot of hours for a small job. Just did the valves, too, so no multitasking.
erappaport is offline   Reply With Quote
Old 11-10-2010, 02:11 AM   #41
Steverino
Arrogant Horse's Ass #1
Oddometer: 36,667
I chased leaks until to replaced the check valve on the crank case vent tube. Then no more leaks.
Well except for that seep at the cracked case, but that is another story.
Steverino is offline   Reply With Quote
Old 11-10-2010, 05:40 AM   #42
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Are you referring to the valve at the inlet, on top of the airbox?
Old 11-10-2010, 06:08 PM   #43
Steverino
Oddometer: 36,667
No I am referring to the valve that is about 1/2 way down the hose that attaches to the air box and at the motor.
Old 11-12-2010, 04:19 PM   #44
erappaport
pray for rain
erappaport's Avatar
Oddometer: 292
Yeah, don't seem to have a check valve. It's an early '04, so I'll guess either it never had one or the PO took it out. Can any veterans of the OP switch replacement job tell me if it can be done without pulling off the air box & carbs?
Thanks, ER
Old 11-12-2010, 08:55 PM   #45
DeeGee OP
DeeGee's Avatar
Oddometer: 1,882
Afraid so my friend, PITA to get to for such a simple job. Fuel tank, airbox and carbs to get to the pressure switch. Don't forget to order a new copper washer too as it's got it's own part number
I'm sure the dealer will know which one it is when you order the switch.
HTH
DG
Times are GMT -7.   It's 10:54 AM.
