Old 02-06-2012, 08:07 AM   #76
Iron Horse
I Make Shit Up
Iron Horse's Avatar
Oddometer: 9,319
Speaking of the gear selection thingy, that seems to be where mine is leaking from as well. Just lean and support the bike to the right side and replace O ring? Would like to avoid draining all that clean oil I just put in...
TIA
jp
Wandering Wapiti
Iron Horse is offline   Reply With Quote
Old 02-06-2012, 08:24 AM   #77
AdvGa
AdvGa's Avatar
Oddometer: 1,320
When you do this, take out the Gear Position Sensor, Oil may Drip but not gush out.... you should not have a problem.
AdvGa is offline   Reply With Quote
Old 02-06-2012, 08:26 AM   #78
Iron Horse
I Make Shit Up
Iron Horse's Avatar
Oddometer: 9,319
Thank you.
Wandering Wapiti
Old 05-22-2012, 06:49 PM   #79
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Just installed a New GEAR-POSITION SENSOR #60011023100 on the '06 Adventure... the Old One was Leaking Oil out of the potting material and out of the Wires.
The New One has Brass Nurling around the Screw Holes, has better Potting Material, and is made in Japan.
However, it DID NOT COME With an O'Ring...just to let you know.
Old 05-28-2012, 11:22 AM   #80
Gate
Gate's Avatar
Oddometer: 8
Originally Posted by stupot View Post
Yeah i did that too looks actually like the pics Deegee posted, When i replaced the pressure switch it was corroded but no oil around it. I took the bike to my local ktm dealer to speak to their mechanic. He has worked on the bike from new and has done every service and all the engine recalls, he reckons its not anything to worry about and as long as i keep an eye on the oil level it shouldn't be a problem, just annoying me!
Looks like there maybe some oil coming from around the rubber seal one the left hand casing, anybody had leakage from here? ps its an old picture its alot cleaner now!
I got a 950SE '06, that is leaking from that spot also. What sensor is it? Problem to replace?
Gate is offline   Reply With Quote
Old 05-28-2012, 11:41 AM   #81
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Look at this link in the Engine/Lubrication portion:
See #11 #14 or #12 or 21 which is the O'Ring
http://173.74.246.25/munnracing/inde...allas&state=GA
Old 08-26-2012, 10:47 AM   #82
jimmibanke
jimmibanke's Avatar
Oddometer: 102
From what i can see, I too have the problem with the oil pressure switch, its covered in oil, and leaking all over the place
can the oil leak through the oil pressure switch? or is it just leaking around the switch due to a bad washer?
does any of you have some pictures of the switch from the bottom? Im thinking of just fixing the switch i have now...
One word, you are all awesome! without you my hair would have been grey by now! thanks
jimmibanke is offline   Reply With Quote
Old 08-26-2012, 12:11 PM   #83
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Originally Posted by jimmibanke View Post
can the oil leak through the oil pressure switch? ...
I found my Oil Pressure Sensor was leaking through the Plastic where the Wire Sensor connection was attached.... this is most likely your problem too.
Old 08-26-2012, 01:22 PM   #84
jimmibanke
jimmibanke's Avatar
Oddometer: 102
Damn okay, ill buy a new one. Thanks for answer
Old 11-21-2012, 10:05 AM   #85
gav03
Oddometer: 23
Oil pressure sender
Just to add my experience:
My '05 950 Adventure started leaking oil, a little at first, but gradually getting worse. It looked like it was coming from the base gasket of the rear cylinder, but after reading several posts about the oil pressure sender between the cylinders being a likely culprit I stripped the bike down. Although there appeared to be little oil around the sender, it was the highest point where there was any oil. After cleaning everything and replacing the sender unit and the copper crush washer with new items the bike was rebuilt. Result, no further leaks.
The part is less than £7, but you're looking at a good days work to strip and rebuild. I found the fuel lines in the airbox a particular bitch to get back onto the carbs. However, after initially thinking I had a potentially huge bill for an engine rebuild coming, it was a relief to cure the problem with very little expense.
gav03 is offline   Reply With Quote
Old 07-05-2013, 11:45 AM   #86
tacosupreme
tacosupreme's Avatar
Oddometer: 278
Need some help on this one. '12, leaked since new (my local dealer sucks, I'm on my own) and can't figure out from where. All of the usual culprits have been checked and rechecked, all Orings appear to be in like new condition, and at idle it doesn't leak at all that I can find. Seems like it only happens when I really wring it out at high RPM. Kind of hard to replicate those conditions in the shop. With the wind pushing oil all over it's hard to pinpoint. Should I replace the factory hose clamps with plumbers tape? They all seem tight, but that's all I can think of.
'12 990 with some orange stuff on it to make it go faster.
tacosupreme is offline   Reply With Quote
Old 07-05-2013, 11:49 AM   #87
6732cash
6732cash's Avatar
Oddometer: 161
Have you replaced the oil pressure switch
6732cash is offline   Reply With Quote
Old 07-05-2013, 11:59 AM   #88
KaytM
Just a fella.
KaytM's Avatar
Oddometer: 202
I haven't read all the posts but I have just had an oil leak sorted on a 06 adv: it was the 'clutch pusher seal'.
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Old 07-05-2013, 11:59 AM   #89
tacosupreme
Oddometer: 278
No, but it doesn't appear to be coming from that high up. I'll pull the airbox and have a look to be sure though...
Old 07-05-2013, 12:06 PM   #90
6732cash
6732cash's Avatar
Oddometer: 161
Just buy a new one and fit it
Times are GMT -7.   It's 11:47 AM.
