Old 07-08-2009, 07:16 PM   #1
oldxr OP
oldxr's Avatar
Oddometer: 1,151
xr650r-install new sleeve or get the bore rechromed
just bought a plated xr650r ,its pretty farkled out .but the top end sounds loose -it noiser than my old xr600.on the 600 i put a new famous name forged piston in after a 3rd gear repair.i didnt measure any thing but it seems like the forged piston fit looser than the oem piston and engine is noiser.my idea for the 650-send the cylinder and a new honda oem piston to us chrome and get the engine restored to as new honda specs.might be a little more expensive this way but i want it at oem specs and i can break it in on the street in town.i basically want a tight uncorked 650r.also does anybody know about xr650r ability to run on pemex in mexico?my old xr600r doesnt like it.
oldxr is offline   Reply With Quote
Old 07-08-2009, 07:21 PM   #2
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,102
My XR650R has 1800 miles on it and is noisy as heck. I think you'll find that most XRR's are real noisy bikes. Mine has a rattle/knock sound to it, you can hear it when it idles and when you are moving, just a slight throttle increase over cruise and you can hear it also especially when standing up. The metal skid plate and large tank amplify the effect.
Every XRR that i've ridden makes these noises, some louder than others. Mine is one of the louder ones. It doesn't use any oil though and runs great.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 07-08-2009, 09:31 PM   #3
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,906
U.S. Chrome could probably replate your cylinder (with original Nikasil, not chrome plating). An iron cylinder liner would be a nasty step backwards. Have you checked compression? Are you burning oil? Wouldn't you feel a little silly if you spent the time and money and effort and it sounded the same when you put it back together?
montesa_vr is offline   Reply With Quote
Old 07-09-2009, 09:23 AM   #4
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
That rocks-in-a-blender sound is pretty normal. I don't know how many hours are on your motor but I would look for a few more indicators besides sound before concluding the top end needs to be re-done.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 07-10-2009, 09:18 AM   #5
oldxr OP
oldxr's Avatar
Oddometer: 1,151
when i take the valve cover off (to check valve clearence) i will have to get a good leak down gauge and check cylinder leak down.i am just not familiar with this particular engine.i think i will go to 15 tooth on front to slow the engine down on the highway.
Times are GMT -7.   It's 09:07 AM.
