Old 08-09-2009, 02:53 PM   #61
edeher OP
Oddometer: 129
my mistake they do both have main and pilot jets. ....but there is an extra jet in the first carb.....maybe a coasting enrichener that someone told me about
edeher is offline   Reply With Quote
Old 08-09-2009, 03:09 PM   #62
edeher OP
Oddometer: 129
Here is the plan.... i checked all the jet sizes....the pilot jets were (2) 22.5 and the main jets were (1) 145 and (1) 150. And the extra jet only in one of the carbs that i think was a coasting enrichener was a 55.
I think i will go with two 155 mains and pilots at 27.5 which is two sizes up from stock. Then i will add the enrichener up to 60 and enrichen the needle by one clip to start then two if nessecary.
I am ordering tonight....any imput from people experienced in jetting would be much appriciated.
Old 08-10-2009, 04:46 PM   #63
edeher OP
Oddometer: 129
and im going with these filters....forget the rain!!!
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old 08-10-2009, 08:51 PM   #64
spacewalker
Oddometer: 14
did you get the jetting right? i just picked up a set of raptor carbs to replace the leaky carbs on my 85 xt. this thread has great information on what to expect, keep it up.
spacewalker is offline   Reply With Quote
Old 08-11-2009, 06:36 PM   #65
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
Eh?
Keep it out of the dirt if you use them K&N styled filter.
Be better off with Foam uni filters and good heavy oil, the oil will repel most of the water, and keep out dirt.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 08-11-2009, 06:37 PM   #66
edeher OP
Oddometer: 129
i have ordered the jets and air filters...when i get them installed and test it out i will let you know how it did. should be close though.... i hope
Old 08-11-2009, 06:38 PM   #67
edeher OP
Oddometer: 129
yea that would save my engine, but i will use it soley in the city to go to work and come home...should be fine.
Old 08-11-2009, 06:39 PM   #68
edeher OP
Oddometer: 129
https://www.phatperformanceparts.com
this site has all the jets you could need at any size
Old 08-11-2009, 06:39 PM   #69
edeher OP
Oddometer: 129
better price than a dyno jet kit...those kits are way too much
Old 08-14-2009, 04:03 PM   #70
edeher OP
Oddometer: 129
Got the filters on and ready...just waiting on the jets and hopefully it will be good to go. Got these filters on ebay for @ 20 bucks. Foam would have filtered better but im using this bike on the road so i think this should filter out just fine. There seems to be a foam layer inside the steel mesh anyways.
Old 08-14-2009, 04:10 PM   #71
edeher OP
Oddometer: 129
The extra jet in the main carb is the starting jet...helps the bike start by richening the fuel mixture i guess, this is what the choke does anywaz...so i want this very rich to give my bike an easy start, i went up two sizes on this jet
Old 08-14-2009, 05:44 PM   #72
Northern Dog
Gnarled up Northerner
Northern Dog's Avatar
Oddometer: 710
Nice filters!
... but beware, you're going to be running REALLY lean with a setup like that unless you have some bigassed jets installed.
~You don't stop riding because you get old, you get old because you stop riding~
Northern Dog is offline   Reply With Quote
Old 08-14-2009, 05:46 PM   #73
edeher OP
Oddometer: 129
Originally Posted by Northern Dog
Nice filters!
tru!! The jets will be in soon and ill try em out...if noy ill order some others
Old 08-15-2009, 05:21 AM   #74
edeher OP
Oddometer: 129
When i tested it with no filters on it was very lean but also cut out on me. When i was coming to a stop and it was going to idle it just died. I was thinking it could be because the main jet is too small...this happend on my kx85 when i bored it out and a bigger main solved the problem...what do you think?
Old 08-15-2009, 07:41 AM   #75
spacewalker
Oddometer: 14
there is a spot on the top of each carb for what looks like a vacuum hose. what did you do here? is it vacuum? do i just cap it?
Times are GMT -7.   It's 10:38 PM.
