Old 08-28-2009, 03:40 PM   #91
edeher OP
Oddometer: 129
bump....
anyone know what the spacers on the main jets do?
edeher is offline   Reply With Quote
Old 08-28-2009, 06:27 PM   #92
Roarin
Oddometer: 67
At a guess I'd say they drop the jets down into the fuel in the float bowls. So they suck fuel -not air.
Roarin is offline   Reply With Quote
Old 08-28-2009, 06:39 PM   #93
edeher OP
Oddometer: 129
hmmmmm. maybe
Old 08-30-2009, 08:01 AM   #94
spacewalker
Oddometer: 14
any news? did it run without the spacer?
spacewalker is offline   Reply With Quote
Old 08-30-2009, 09:11 AM   #95
edeher OP
Oddometer: 129
Ill be able to tell you once i get my choke assembly so i can start it... my pup ate it. should be in this friday or so, looking forward to it!
Old 08-30-2009, 09:12 AM   #96
edeher OP
Oddometer: 129
I was thinking of putting a washer in between where the spacer went... or should i try it without it first
Old 09-01-2009, 05:09 PM   #97
edeher OP
Oddometer: 129
bump
washer or no washer?
Old 09-10-2009, 05:03 PM   #98
edeher OP
Oddometer: 129
took it for a test drive today and it started popping again so i adjusted the mixture screw to where it doesnt pop at all. I think it may even be a little rich since it has a delay to idle after a rev. So i guess i just have to dial it in now. The carb was leaking from the drain when i was trying to start it though...not sure if this is normal or the float may be getting stuck...
Old 09-11-2009, 04:51 PM   #99
edeher OP
Oddometer: 129
Got it dialed in just about right to where it idles good and doesnt backfire through the pipe or carb....problem is it is not consistant, after a ride it will change and need to be adjusted again...Plus the mixture screw has to be turned out almost all the way, i think its supposed to be around 2.5 to 3 turns out or i need a richer needle? Anyone second this? If how do i tell what needle i have?
Need some ideas here...
Old 09-11-2009, 07:45 PM   #100
edeher OP
Oddometer: 129
bump...i think this is the next thing to do.
Where can i get needles for a raptor carb? Anyone know what size is stock?
Old 09-12-2009, 01:05 PM   #101
JensEskildsen
Oddometer: 841
You need a bigger idle jet if you need to screw your CO-screw (gasscrew) fo far out.
As always, do the adjusment on a warm bike.
JensEskildsen is offline   Reply With Quote
Old 09-12-2009, 03:27 PM   #102
edeher OP
Oddometer: 129
its not the gas screw....its the fuel mixture screw...i put a larger main, pilot, and starter jet in the bike already...i think it may need a richer needle but i cant find what size i have now. should it be written on the needle like the jets?
Old 09-13-2009, 10:32 AM   #103
edeher OP
Oddometer: 129
Got it dialed in almost perfect now...went for a long ride and its riding real nice, sounds good too...just need one size richer on my needles since i am 5 and 1/4 turns out on the mixture screw...
Besides that anyone doing the conversion can put these jets i listed straight in and it should be pretty close, depending on where you live. I am in FL, so right on sea level and HOT.
Old 09-13-2009, 11:03 AM   #104
Northern Dog
Gnarled up Northerner
Northern Dog's Avatar
Oddometer: 710
You should Google "Raptor carb jetting" or something along those lines to see if you can find a Raptor rider's site with information about the jets.
~You don't stop riding because you get old, you get old because you stop riding~
Northern Dog is offline   Reply With Quote
Old 09-13-2009, 11:09 AM   #105
edeher OP
Oddometer: 129
Times are GMT -7.   It's 01:46 AM.
