Old 11-24-2012, 10:16 PM   #31
cpuover
Oddometer: 4
I switched out the coolant and coolant sensor last weekend. The immediate cold-start stalls are history!
I also decided to pull the trigger on a GS-911, and here's what it read today:
Code:
#2012-11-24 16:07:25
#GS-911 Android V1.1
#G650 Xcountry
4433: Engine Coolant Temperature Sensor Malfunction, Short-circuit to Positive or Open-circuit. The fault is not present now.
17460: Tank ventilation valve, Open-circuit or output-stage overloaded. The fault is currently present.
I suspect 4433 would've been triggered by starting the bike with sensor disconnected, and not just if the sensor is bad. I regret not having a dealer pull the codes before I began tinkering. The other fault (17460) showing is due to the canister laying on the garage floor, I just need to short the disconnected plug I think.
Reading the real-time values using the GS-911, I'm seeing huge fluctuations from the lambda sensor, and maybe this sensor is malfunctioning. The bike doesn't run perfectly smooth, it kind of struggles, then catches up, then struggles. I need to do some more research and ride some more and see what I can come up with.
cpuover is offline   Reply With Quote
Old 01-22-2013, 06:29 PM   #32
khpossum
poster
Oddometer: 383
another success story. First took off the carbon canister, since it was the easiest. Did maybe make some differnce, hard to say. I then changed the temperature sensor and the problems are 99% gone. Measuring the resistance it was hard to say there was anything wrong with the old one, but no more cold engine stalling.
KP
khpossum is offline   Reply With Quote
Times are GMT -7.   It's 06:24 PM.
