07-14-2009, 10:09 AM
#1 |
Oddometer: 88
I recently purchased a set of OEM BMW engine guards for my 2000 R1150GS and I'm getting conflicting info about maintenance with them installed.
A buddy of mine swears that an oil change can be performed with them installed. But I did a search and some on this site think they need to be removed to perform an oil change. If this is true then WTF were the BMW engineers thinking? Thanks. |
07-14-2009, 10:39 AM
#2 |
'00 R1150GS
Well, an oil change CAN be done with them installed (at least my 2000 1150GS has a access hole in the bashplate for the oil drain). However I need to remove them to remove the bottom bashplate to access the oil filter. This requires me removing the engine guard bars, and thus remove the gas tank!
I hope someone out there has more information that would allow me to get around this horrid setup?! But I doubt it, so I'll continue removing the tank. Cheers Richard
"From the point of ignition To the final drive The point of the journey is not to arrive Anything can happen." ![]() |
07-14-2009, 11:43 AM
#3 | |
Old guy
Oddometer: 1,362
"What could possibly go wrong? " The Jerk2012 TE 250 2010 F 650 GS 1983 R 80 G/S |
07-14-2009, 11:50 AM
#4 | |
'00 R1150GS
lousy Bavarian setup .. argh ...
07-14-2009, 11:55 AM
#5 | |
Old guy
Oddometer: 1,362
07-14-2009, 11:59 AM
#6 |
Oddometer: 88
Actually my 2000 GS does have a skid plate and looking at photos of my crash bars installed they will certainly get in the way of changing the oil. I may drill a hole in the skid plate to access the drain plug and maybe even a larger hole for the filter.
Who knows? On the other hand, anybody want to buy a used set of OEM engine guards? |
07-14-2009, 12:06 PM
#7 |
Oddometer: 178
My advice would be to return or sell them. Get a set of SW-Motech bars. They have a small cross-piece underneath that has to be removed in order to get the skid plate and what not - it's pretty simple.
AE-22 screwed with this post 07-14-2009 at 12:12 PM |
07-14-2009, 12:35 PM
#8 | |
'00 R1150GS
R
"From the point of ignition To the final drive The point of the journey is not to arrive Anything can happen." ![]() rtortore screwed with this post 07-14-2009 at 05:51 PM |
07-14-2009, 04:52 PM
#9 |
steptoe
Oddometer: 2,150
Only the early BMW standard GS crash bars were one piece -the later type have the same set up as ADV bars and you can detach the lowers.
www.gsshop.co.uk |
07-15-2009, 07:34 AM
#10 |
'00 R1150GS
Bump ...
So, what does everyone else do?? REmove the tank each and every oil filter change?
Richard
07-15-2009, 08:26 AM
#11 | |
Oddometer: 88
10-09-2009, 12:34 PM
#12 |
'00 R1150GS
Anyone else have any solutions to this little problem?
R
10-10-2009, 07:37 AM
#13 |
Watch this!
Oddometer: 314
Holy crap dude!!!
Glade I hit this thread I was looking at crash bars not 5 min. ago. I will have to take notes on this one. Any more suggestions one a good set for an 08 1200 GS. I will sit back and watch to see what happens around this one.
10-10-2009, 09:40 AM
#14 |
Live Life
Oddometer: 25
Two words. Hepco and Becker
10-14-2009, 09:36 AM
#15 |
'00 R1150GS
Bump?
I am thinking of drilling out a whole - then bolting a plate over it to cover. I know there won't be that much strength, and the bolts will likely seize, but I cannot keep removing the tank for an oil change!! R
