Old 07-14-2009, 01:58 PM   #1
Timpo OP
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,108
2.75" rimlock availablity?
Need a rimlock to fit a 2.75" rim, have you any idea what bike uses one of that size as standard?
I don't seem to be able to buy a rimlock of that size from the general parts supplier, so I am hoping that I can find one that is fitted oem to a machine.
Any help will be gratefully received... Thanks.
Timpo.
The Rave Generator......
Timpo is offline   Reply With Quote
Old 07-14-2009, 08:03 PM   #2
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,944
Timpo.
Go to a bike shop that is selling off road bikes, bend down and look on the rims. They will have the size stamped in them somewhere. http://offroad.parts-unlimited.com/16/255/8180513 From what I see you might be in trouble... seems 2.50 is about the biggest.
You could drill the bead and thread in some pins or screws to lock them.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 07-14-2009, 11:25 PM   #3
holycaveman
Oddometer: 14,387
I have a couple 2.75 rim locks. Emgo makes them.
but I will warn you, those things are completely junk!!! And DO NOT work.
Go with the motion pro 2.5 lock. That is if you have a standard 17in wheel.
Banned for the truth.
holycaveman is offline   Reply With Quote
Old 02-18-2013, 02:11 AM   #4
Tomack
Tomack's Avatar
Oddometer: 160
I know this thred is a few years old but...
Im wondering if anyone has any idears for a 17 inch 2.75 rim lock or is the suggestion above my best option
Tomack screwed with this post 02-18-2013 at 03:36 AM
Tomack is offline   Reply With Quote
Old 02-18-2013, 06:00 AM   #5
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,564
I would think it would be simple to widen one of the all aluminum Talon rimlocks. I'd probably drill and tap some holes in the clamping surface and use screws that had a suitable head (not too sharp) to widen the clamp the required amount.
I assume your application is a tube type tire on a rim with a safety bead, if so you could probably use a tubeless tire without a rimlock. If not, what type of rim are you useing?
Beaten paths are for beaten men.
lamotovita screwed with this post 02-18-2013 at 03:41 PM
lamotovita is offline   Reply With Quote
Old 02-18-2013, 01:35 PM   #6
Tomack
Tomack's Avatar
Oddometer: 160
Im using the OEM 17inch rim on the Tenere.
Im starting to see more & more advantages with 18inch rims
Times are GMT -7.   It's 11:43 PM.
