Old 08-04-2009, 03:58 PM   #16
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Originally Posted by Bayner
John, I'll try to check mine in the next couple of days. I have ridden hard enough to bend the front rim in several spots, and even one in the rear rim. I have bottomed it on several occasions. I'll be a good candidate to see if this is due to riding style or a particular problem with your machine....
You noticed this bolt was bent when first removing your stock shock, correct?
I'll keep you posted.
Yes.
johngil is online now   Reply With Quote
Old 08-04-2009, 04:14 PM   #17
JRWooden
Oddometer: 3,436
Cry
John... I forgot the part about your bent bolt in chapter #1 of this story ...
Perhaps that is the explanation ....
structural member has "buckled" it only retains a fraction of it's former strength.
The simple example is that a person of modest weight can successfully stand on a "perfect" aluminum beer can, yet if there is a small dent in the side of the can .. .you are SOL the can simply collapses. That's not a perfect example, but "whatever"...
Perhaps the explanation is that improper assembly at the factory (woefully inadequate torque) allowed your system to take a slight initial "buckle" and as time goes by ... all hell breaks loose with no real way for you to keep it from happening ....
Jim
Old 08-04-2009, 04:21 PM   #18
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,162
Originally Posted by johngil
The design seems poor considering the intended use of the bike. The bushing that the top shock bolt threads into just floats.
So the shock isn't actually bolted to the bike? Looks like the bolt hole on the right is not threaded, bolt goes through some bushing, through the shock and threads into the bushing on the left. Everything is tightened against the tab on the right and the bushing on the left is just fit into the hole on the left tab but not tightened into it.
Would seem like a better design would be a nut behind the tab on the left so everything got clamped together.
I'm wondering if there is a design/meterial difference between the bushing in BMW shock and your aftermarket shock which would allow the bolt to flex more.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Old 08-04-2009, 04:22 PM   #19
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
"John... I forgot the part about your bent bolt in chapter #1 of this story ...
Perhaps the explanation is that improper assembly at the factory (woefully inadequate torque) allowed your system to take a slight initial "buckle" and as time goes by ... all hell breaks loose with no real way for you to keep it from happening .... "
Jim
I won't be able to prove any of that. I know I need to stay positive, but I'm only positive that I am fucked like a tuna.
My dealer just reamed me a new one for replacing the original bent bolt.
"That's just what you dirt bikers do." She didn't seem too concerned when she ordered it for me. She also mentioned there was only 4 hours allocated to replace the frame based on I don't know what. No profit in getting 4 hours to replace a frame for sure.
Worst case, I will call my insurance provider.
There will be a lot of 800 goodies for sale in the flea market soon enough.
johngil screwed with this post 08-04-2009 at 08:18 PM
Old 08-04-2009, 04:23 PM   #20
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Like any regular bike that I have worked on for the last 30+ years?
Old 08-04-2009, 04:28 PM   #21
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,162
Does the rest of the bushing serve any purpose? From the flats left it looks like it's just hanging there.
In this photo you've got a hose on it?
Old 08-04-2009, 04:29 PM   #22
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
The trouble started w/ the stock shock.
Old 08-04-2009, 04:32 PM   #23
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
The "hose" is from BMW.
The whole setup is meant to mount the seat lock mechanism. Notice the opposite side. They could have lost a couple of inches of fastener if they simply just mounted the shock.
Old 08-04-2009, 05:57 PM   #24
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Originally Posted by PackMule
I checked mine, all straight. About 4500 miles of mixed use including a dualsport event loaded with camping gear and luggage. Bent front rim, but the shock bolt and frame are fine.
What kind of replacement shock do you have?
Ohlins. It will be getting measured compared to stock tomorrow.
Old 08-04-2009, 07:50 PM   #25
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
This is the problem w/ the design in my opinion. The span is just too large.
Old 08-05-2009, 05:42 AM   #26
tmex
tmex's Avatar
Oddometer: 2,039
John, it "appears" to me that the upper mounting flange on the Ohlins is much smaller than the flange on the stock shock. The shorter flange would certainly aggravate if not actually induce the problem since it would be much easier to bend the mounting bolt with a smaller flange. The force would be much more concentrated with the Ohlins.
As it stands, the frame looks severely bent at this point and will probably need to be replaced even if you go back to the stock shock. After looking at your photos I would be reluctant to use the Ohlins as designed, although I am not sure I would have been smart enough to come to that conclusion apriori. I might be inclined to pick a fight with Ohlins if I were you (assuming they designed that shock for the F8). I'll take a look at my F8 this weekend since it is not at my current location.
my favorite bike - R1200GS
tmex screwed with this post 08-05-2009 at 06:11 AM
tmex is offline   Reply With Quote
Old 08-05-2009, 06:17 AM   #27
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Dennis, when comparing the stock shock to the Ohlins there is more surface area w/ the Ohlins shock. The stock shock looks larger, but is mostly just a rubber bushing w/ a smaller steel sleeve.
I will have both shocks compressed to make sure they are of equal length today.
The bolt bending started while running the stock shock. The Ohlins was to be a fix for the frequent bottoming.
After the shocks are compared and everything checks out, I'll start by calling BMW and go from there. I was told that the local rep. is out for injuries right now. That isn't going to help me.
johngil screwed with this post 09-16-2009 at 09:53 PM
Old 08-05-2009, 06:28 AM   #28
v8toilet
Nothing to see here.
v8toilet's Avatar
Oddometer: 1,565
Send a message via MSN to v8toilet
Unless he.she was injured when his rear shock bolt on his F800 let go.... Keep us posted.
v8toilet is online now   Reply With Quote
Old 08-05-2009, 06:54 AM   #29
TwilightZone
Oddometer: 1,949
Wonder if replacing the stocker with a high strength titanium bolt would do the trick. Gotta be available out there somewhere on the internets.
TwilightZone is online now   Reply With Quote
Old 08-05-2009, 08:02 AM   #30
Kawidad
Kawidad's Avatar
Oddometer: 3,809
Ti is cool and all, but it is really brittle. I don't think I would want that, bending is better than snapping for this application.
I have to agree this looks like a silly design. But, if you are frequently bottoming out your shock like you said, that may have been the original source of the problem.
"Deeply flawed people make deeply flawed decisions."
Kawidad is offline   Reply With Quote
Times are GMT -7.   It's 10:51 AM.
