Old 11-14-2009, 03:52 PM   #301
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,437
Originally Posted by Indy Unlimited
Yes I think we can run a single 21mm 0.D. x 12mm I.D. x 70 mm long custom bronze oilite bushing! It just happens that the rubber bushing is on a stock 21 mm diameter steel spacer and the Hyperpro shock has an eye bearing with a 21mm O.D. so it looks like we a potential solution for the Hyperpro shock.
And of course you have me on the very top of the list eh ?
Let tell you guys what kind of guy Indy is. We both had or have, TE610's and were on the 610 board. Other than that he didnt know me from adam. I needed to buy a flywheel puller. He spotted my post and pm'd me saying he'll fed-ex me his to use, then just send it back. He did just that. That's the kinda guy he is. I still owe ya brother.
Now, let me tell what kinda fella I am. I kept the flippin thing and screwed him.
No, I didn't........
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is offline   Reply With Quote
Old 11-14-2009, 03:53 PM   #302
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,120
Good one Frank thanks for the character reference! I still love my TE610 but it really has a tough time with adventure loads. You will get a bushing shipped to you as soon as I get the prototype installed and working correctly.
I have a supplier that made me a batch of small custom bushings for the famous clutch bell wear issue on the Husky TE610. I will call him on Monday and see what a run of custom bushings will run per bushing for a group buy.
Does anyone know if the spherical bearing on the Ohlins shock is also 26mm O.D. as well. Then we can get the same solution for Hyperpro and Ohlins.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 11-14-2009 at 04:41 PM
Indy Unlimited is offline   Reply With Quote
Old 11-14-2009, 04:41 PM   #303
tmex
tmex's Avatar
Oddometer: 2,039
Originally Posted by DockingPilot
Now thats really interesting stuff.
Tmex, you have the oem shock in ?
Yes DP. My upper bolt was slightly bent with the stock shock. I am switching to the Hyperpro progressive shock spring (still stock shock) next install along with 12.9 McMaster bolts. I rode the Yellow Bitch pretty hard, but I do not recall bottoming the suspension, but in the heat of battle who knows? I think if the shock bottoms there is no place for the energy to go except into bending the bolt. Not sure the bushing thing is on the right track based on my bending with the stocker. BTW, I had the prelaod cranked up pretty high. It will be interesting to see if the Hyperpro spring and better bolt are the answer. I'll put 1000 miles on it and tear it down.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 11-14-2009, 04:46 PM   #304
Indy Unlimited
Oddometer: 1,120
Take it easy on that ankle TMEX. No rough riding for a while.
Current Stable:
Old 11-14-2009, 05:08 PM   #305
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,164
Good point. Maybe he should send that spring and bolt down to me and I'll test my shock bolt. I weigh a fair bit more than tmex too, so it'll be a better test.
-Scott-
Semper Fi
'04 BMW R1150GSA, '97 BMW R1100GS, '08 KTM 450EXC-R, '04 KTM 625 SXC
"A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
YetiGS is offline   Reply With Quote
Old 11-14-2009, 05:49 PM   #306
cisco
old fat guy
cisco's Avatar
Oddometer: 270
Now you guys are scaren' me! Might as well pull the shock bolt while I'm waiting for my seat.
Cisco
cisco is offline   Reply With Quote
Old 11-14-2009, 08:52 PM   #307
RedHawk47
RedHawk47's Avatar
Oddometer: 354
16mm shoulder bolt, etc
The 16mm shoulder bolt is an excellent idea. It has considerably greater bend strength. There are several factors to consider before making the change. I haven't taken my bike apart to measure things so I need your input.
1. How much material is there around the holes in the frame tabs/mounts? If you drill the hole larger is there risk of failure at the holes?
2. I believe it was stated that the bushing in the OEM shock had enough material that you could drill it out to 16mm. Even if the wall thickness was only 1mm after drilling that would be enough.
3. The bushing/sleeve to the right of the shock has to be there. What is it's OD? If you drill it out to 16mm it's wall thickness should be at least 2mm.
4. Check the length of the shoulder (90mm) versus the length of the bushing stack. Add washers - I suggest plain or hard - so that you clamp the bushing stack solid.
For the Olin and Hyperpro shocks I recommend a custom bushing set, particularly if you are using the 12mm bolt:
A sleeve that is the length of the two provided bushings, ID of 12mm or 16mm, depending on the bolt used, and OD the same as the small OD on the supplied bushings.
Plus, two rings, ID equal to small OD, OD equal to large OD, and thickness equal to the width of the shoulder on the supplied bushing.
This bushing will reduce the chance of bending a 12mm bolt, but if you have bent the bolt when using the OEM shock all bets are off.
Dan
It's never too late to have a happy childhood. -- Tom Robbins
How I spent my summer vacation - Alaska
09 BMW F800GS
99 KLR 650 A13
RedHawk47 is offline   Reply With Quote
Old 11-14-2009, 09:55 PM   #308
Indy Unlimited
Oddometer: 1,120
Once you take it apart you will notice that the stock shock has a rigid bushing that is 21mm O.D. and 40 mm long. The spacer with the rubber bushing is 21mm O.D. and 30 mm long. The issue is it should be a continous 70 mm long bushing to support the 12 mm bolt over that span without a bending load in the middle. The frame has plenty of metal and if we went bigger it requires only drilling a larger hole on the outside frame plate where the head of the bolt goes up against it.
That is why I feel we need a larger 16 mm bolt or one full length single bushing to take the bending load off of the bolt. The female nut side is 20 mm O.D. at the threads and one could machine it for a 16 mm shoulder bolt to seat up to the threads which dont start until you are 1/2" deep inside the hole.
Right now I am leaning to a 2 bushing design. a single steel bushing 70 mm long either 21 or 22 mm O.D. / 12mm I.D. and a 40 mm single 26mm O.D. / 21 or 22mm I.D. oil impregnated bronze bushing. This will give us the spanning strength for the bolt and a replaceable bearing for wear. There is a standard oilite bearing with a 26 mm O.D. and 22 mm. I.D x 20 mm long and for the sake of easy replacement we could put 2 of those over the custom steel bushing as well. That is why we may want 22 mm O.D on the steel bushing for the Ohlins and Hyperpro.
Any better ideas would be appreciated. I am still reviewing the best design concept over the next few days before moving forward.
Current Stable:
Indy Unlimited screwed with this post 11-15-2009 at 06:03 AM
Old 11-15-2009, 05:59 AM   #309
tmex
tmex's Avatar
Oddometer: 2,039
The worst part is having to take a cage to work. About five hours of extra commute time a week tossed right in the toilet relative to a bike.
BTW, changing the spring require a spring compressor. Springs always scare me.
Old 11-15-2009, 06:35 AM   #310
cisco
old fat guy
cisco's Avatar
Oddometer: 270
Laugh
Just think how much better it will feel........... when it quits hurting.
Cisco
Old 11-15-2009, 06:41 AM   #311
DockingPilot
Oddometer: 7,437
Ankles are highly over rated T., I say chop it off and move on.
Frank Reinbold
*2010 FOREVER WEST*
TRANS AM TRAIL WEST
Old 11-15-2009, 07:51 AM   #312
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,164
There's a dude around here who rides a plated CRF450X supermoto. He's got a prosthetic lower right leg. Seems to ride just fine.
I'm with DP on this one.
-Scott-
Semper Fi
Old 11-15-2009, 08:53 AM   #313
tmex
tmex's Avatar
Oddometer: 2,039
photgraphic evidence
Stock shock - stock bolt ~7000 miles. Bolt is backlit in the jaws of the drill press vise. It is hard to capture a small bend photographically. It is actually pretty obvious to the eye when you have the bolt in your hand.
I am going to keep my ankle. I have become attached to it over the years.
Old 11-15-2009, 09:07 AM   #314
never.ride
never.ride's Avatar
Oddometer: 315
That's exactly what my bent bolts looked like, both the stock one and the higher grade one.
Oh, and I'm 150 lbs with all my gear....
never.ride is offline   Reply With Quote
Old 11-15-2009, 09:17 AM   #315
LaPorte
LaPorte's Avatar
Oddometer: 402
I get my 2010 f 800 GS next week, so I was thinking. I'll put the new bike on my old bike trailer and just tow it where ever I want to go adventure riding. That way the forks woun't feel harsh, the rear wheel bearings woun't disintegrate, the shock bolt woun't bend, chain woun't snap. Woun't need knobb tires and the gearing is perfect. Woun't need gas so it woun't splash all over. Let's see did I miss anything. Then when I sell the bike, the phrase "like new" will really mean something.
LaPorte
If you don't know where your going don't lead!
LaPorte screwed with this post 11-15-2009 at 09:42 AM
LaPorte is offline   Reply With Quote
Times are GMT -7.   It's 10:43 PM.
