Old 08-20-2009, 10:47 AM   #46
AKTroy
BE AWARE OF TRAINS
AKTroy's Avatar
Oddometer: 2,228
Originally Posted by johngil
I couldn't sell the bike w/ any home made repair job w/o full disclosure. Signed, disappointed
Good luck with this and good for you for that kind of stand up character.
Team Pterodactyl, Hooligan Division. R.I.P Harry
Mythical Riders, boy are they movin'. Thru dust, rocks & mud..............they're FUKENGRUVEN!
As I look back through the decades, theres a thought that prevails. We are born without a road map and a choice of many trails...........
AKTroy is offline   Reply With Quote
Old 08-20-2009, 11:03 AM   #47
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
"My guess is not worth that much since I have not had my own hands and eyes on your bike but for the little it is worth, I think that a part was defective or the mount bolt was left too loose and one or more parts of the frame bent and or the spacers were deformed. Once this happened no amount of replacing the bolt will do any good because quite honestly the bolt is not there to resist flexing, it is there to apply tension and the spacers and frame carry all of the sheer and flex load."
I think this sums it up.
johngil is offline   Reply With Quote
Old 08-20-2009, 11:39 AM   #48
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Originally Posted by JoelWisman
Thank you, I think, unless it is "my guess not being worth much" that you are agreeing with.
That's your wife's job.
Old 08-20-2009, 12:19 PM   #49
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,962
I'm with John on the weak mount design theory. I'm no engineer, so i'm far from having any hard data to confirm my suspicion, but the span just looks too great to offer enough strength to the mount.
I also opine that the split (wimpy) bushing in the Ohlins shock exacerbates the tendency for the bolt to bend. If the bushing were stronger, it would aid in keeping the bolt from flexing.
EDIT - It would be interesting to me if someone could do some stress analysis on that bolt/mount. How much force does it take to bend the bolt and ears in the mounting configuration of the 800 GS ? Is it an acceptable figure ?
Bruno T . screwed with this post 08-20-2009 at 12:31 PM
Bruno T . is offline   Reply With Quote
Old 08-20-2009, 12:37 PM   #50
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I think I will contact my Ohlins rep. on this situation as well.
Old 08-20-2009, 12:43 PM   #51
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,962
I recommend you speak with Matt Sage directly, at Ohlins USA.
Old 08-20-2009, 12:55 PM   #52
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 932
Matt's work number is:
828-692-4525 x308
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike screwed with this post 08-20-2009 at 01:13 PM
CrazyMike is offline   Reply With Quote
Old 08-20-2009, 01:17 PM   #53
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I have previously dealt w/ Jerry.
I will keep this # as well.
Old 08-22-2009, 09:19 AM   #54
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,843
John, I just checked mine, well at least I eyeballed it. Its straight. To my eye anyway.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-22-2009, 09:30 AM   #55
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Do you have any photos of the top shock area of your aftermarket shock?
I'm interested in something Bruno T mentioned about the Ohlins spacer/bushings.
Old 08-22-2009, 09:45 AM   #56
DockingPilot
Oddometer: 9,843
Ill tell ya what, since your a good guy, Ill go down and take off the cover again and take one.
Standby.........
Frank Reinbold
Old 08-22-2009, 10:05 AM   #57
DockingPilot
Oddometer: 9,843
John,
This is the HyperPro shock. Does this shed any light for you ?
Frank Reinbold
Old 08-22-2009, 10:47 AM   #58
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Is there a heim joint or some sort of swivel bushing on the shock mounts?
I'll post a couple of photos of the Ohlins setup later.
Old 08-22-2009, 10:59 AM   #59
kmueller_gs12
Oddometer: 18
@dockinpilot
hi my name is klaus from germany.
my daughter ride a 2008 f658gs original sock lowered.
this week i change the shock to an normal high wilbers shock.
in the reprom bmw wrote tighten the bolts with 100nm.
the bold at the swingarm is ok, but at the upper bold i cant tighten to 100nm. i can turn it further.
how do you did it when you change the shock
sorry for my english.
thanks and best regards
klaus müller
kmueller_gs12 is offline   Reply With Quote
Old 08-22-2009, 11:18 AM   #60
DockingPilot
Oddometer: 9,843
John, well, it's a one solid piece bushing if thats what you mean. ?
Frank Reinbold
Times are GMT -7.   It's 09:18 PM.
