Old 03-06-2010, 12:22 PM   #616
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,614
WHOA!!!!!
Originally Posted by tmex
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 03-06-2010, 12:37 PM   #617
itsatdm
itsatdm's Avatar
Oddometer: 4,978
That looks ugly . Hope BMW has some more of that goodwill.
Old 03-06-2010, 12:46 PM   #618
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I think that was a stroke of luck. If a certain photo hadn't been found with the initial bent bolt and stock shock, I would have been out of luck.
johngil is offline   Reply With Quote
Old 03-06-2010, 04:05 PM   #619
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Originally Posted by JoelWisman
Same trails, lighter rider, not conclusive but it sure smells like there may be a problem with the ohlins design in this application.
Good luck and best wishes, let me know if I can help.
I wish I could have done a more equal comparison after the new frame, but I can't. I installed the RM brace. Call me a coward.
I just pulled my bolt, and it is totally straight. Not even a hint of wobble. I believe there are about 1500-1800 miles on the bike since the repair. I have not been timid in my riding.
So far so good from a structural point of view.
Just checked the bottom bolt. No problem.
johngil screwed with this post 03-06-2010 at 04:23 PM
Old 03-06-2010, 04:12 PM   #620
Phreaky Phil
Oddometer: 1,885
If you guys are having these problems then whats in this bike. ? It has a fancy Bitobo shock and different forks but unless the shock mount is reinforced it would be "mothered"
Phreaky Phil is offline   Reply With Quote
Old 03-06-2010, 04:35 PM   #621
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Old 03-06-2010, 04:50 PM   #622
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I don't have an answer for you.
But I wonder if the rider actually owns the bike.
I guess if I hadn't already laid out so much money and time for this bike, I really wouldn't care.
Old 03-06-2010, 05:16 PM   #623
cisco
old fat guy
cisco's Avatar
Oddometer: 282
Here is a picture of F8GS's shock (he is a friend, and we rode mostly the same terrain at the same time). My bike has been used quite a bit more than he has used his, and my bolt was only slightly bent - had to look hard to see it. F8GS is also much lighter than me (but I am much better looking). I am beginning to think the Ohlin's shock really aggravates this problem.
I wonder if the shock bushing touch each other. I seem to remember that they didn't on my late '70s Huskys.
cisco is offline   Reply With Quote
Old 03-06-2010, 06:09 PM   #624
F8GS
Oddometer: 19
Good luck and best wishes, let me know if I can help.[/quote]
I took the bike to the dealer today. They are going to submit a warranty claim. Since there is an Ohlins shock, they are not sure whether it will be covered.
They opened up a demo bike to compare with mine. Both shock mounts are noticably bent. Not conclusive if the frame is bent or not. The right side spacer of the Ohlins shock is also cracked radially at the point where the diameters change...enough so that a straight bolt will not go through the spacer.
F8GS is offline   Reply With Quote
Old 03-06-2010, 06:12 PM   #625
F8GS
Oddometer: 19
F8GS ... (but I am much better looking).
After this statement, y'all should start doubting the veracity of ANYTHING tmex says
Old 03-06-2010, 06:29 PM   #626
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
He's either got a lump in his pants, or in his wallet.
Tmex, chick magnet. Who'd a thunk?
Old 03-06-2010, 07:31 PM   #627
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,816
Add me to the list
I've got about 20,000 miles on mine. The last 12,000 or so has been on roads ranging from smooth freeway in the PacNW to rutted washboards in Guatemala. The load in the saddlebags is probably 80 to 100 lbs. I had a look today while I was checking my subframe bolts and found this:
It's not real bad yet, but it's on its way.
I'm going to see if I can find a new, stronger bolt on Monday, but regardless, I'm fixin' to abuse the bike in Baja for a couple of weeks. Let's see how it all turns out. I'll report back
drrags is offline   Reply With Quote
Old 03-06-2010, 10:25 PM   #628
Apostolos
Oddometer: 391
Um, I've got a 2010 F800gs on order and for 15k dollars; this is not something I should have to be worrying about.
I spent four hours reading this entire thread and at first I was not too concerned, but now there are more and more people that are finding bent bolts.
I'll definitely do the washer and re-torque precaution, but I do not like the looks of this at all. I hope I made the right choice with this bike.
God Bless,
David
Apostolos is offline   Reply With Quote
Old 03-07-2010, 12:48 AM   #629
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,949
I've got less than 9,000 miles on my bike, but sometimes ride like this:
accidently of course. Stock rear shock.
Today I took a look and I think maybe there might be a very slight bend inmy upper bolt.
I did not take the bolt out because I didn't have a torque wrench, however I bought a torque wrench and will take it out tomorrow and have a look.
The left edge of the shock is about 1 mm above the mount eye thing.
Nothing too obvious, I am still not sure if the bolt is bent but I will know tomorrow.
My camera was not charged so no pictures.
_________________________________
My Ride Reports
DolphinJohn screwed with this post 10-13-2012 at 02:22 PM Reason: removed naughty language
DolphinJohn is offline   Reply With Quote
Old 03-07-2010, 01:39 AM   #630
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,450
For all you guys replacing the stock shock beware that the stock 72mm span shock mount design is stressed even more by the spherical bearings (floating) on the Ohlins and Hyperpro shocks. The stock BMW shock has a needle bearing in an extended non floating shock mount. So if you upgrade the rear shock I strongly recommend a brace or another mounting design as posted by others.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Times are GMT -7.   It's 12:04 PM.
