Old 04-04-2010, 12:57 PM   #841
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,797
Originally Posted by itsatdm
I understand. I did not realize that the Ohlin bushing were aluminum. I suppose it is possible, under some pounding, for the Ohlin bushing to deform first, then it is all down hill, thanks
After the same pounding, the stock bushing will fail as well.
Spanning the gap w/ one piece of material (of proper strength) seems to make Indy's idea a winner. He has mentioned retrofitting HyperPro and Ohlins shocks and makes mention of installing his assembly in the stock shock as well.
In my initial bend it appears the worst of the bending was where the spacer and the shock came together.
I'm still concerned about the cross tube. Baby steps for now.
johngil is offline   Reply With Quote
Old 04-04-2010, 02:53 PM   #842
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,343
Originally Posted by YetiGS
Indy or never.ride, will your brace/bracket/support bushing dealio work with the RallyeMoto brace?
It can be made to work with the Rallye Moto brace but you would need a 20mm I.D. x 21mm O.D. x 30mm long bushing sleeve to fill the gap difference between the stock spacer under the rubber and the new extended bearing race.
So if you want both solutions it can be done.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 04-04-2010 at 03:04 PM
Indy Unlimited is offline   Reply With Quote
Old 04-04-2010, 04:07 PM   #843
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,797
Originally Posted by Lion BR
While we know stock shocks bend bolts, although not with the same "regularity" as Ohlins. And a RM Brace failed with an Ohlins shock. Those two sentence are facts, right?
Having said that, I may have missed something here on this discussion where someone knows that the RM brace is guaranteed to work with the stock shock. Couldn't it be the case, in a most optimist scenario, that the stock shock is less likely to be bent with the RM Brace?
Indy, your solution is elegant and apply a type of reinforcement that dissipates the force to a larger area, where it counts the most. Hope it works.
Lion
The RM brace helps w/ the Ohlins as well.
It bends less. Lame, yes. Truth, yes. Solution, no.
Lion, I don't think there are any guarantees here.
Old 04-04-2010, 04:35 PM   #844
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,423
Originally Posted by Indy Unlimited
No Paypal account. I really dont want to make more kits but this thread wont die. I hope I can get the kits to the guys that are going with Elka, Ohlins, Hyperpro aftermarket shocks. Check or Cash after you get the kit.
Sounds good to me. I hope to go to a Hyperpro or Elka shock eventually sut am looking to improve the forks more first.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 04-04-2010, 04:44 PM   #845
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,423
No. The RM brace did not fail. A bolt bent on a bike using the brace with an Ohlins shock, but the brace itself did not fail. John also said that he believed the brace kept the frame from bending. To me, that means the brace works. It doesn't solve the problem, but it helps mitigate it.
HOLY SHIT!!! WE JUST GOT HIT BY A HUGE F'ING EARTHQUAKE!!!!
Semper Fi
YetiGS screwed with this post 04-04-2010 at 04:54 PM
Old 04-04-2010, 04:53 PM   #846
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,797
6.9 off of Baja CA
Felt it good here.
Old 04-04-2010, 04:57 PM   #847
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,890
OK, yes, that is better language. The RM Brace did not prevent a bolt from bending, in a bike with an Ohlins shock.
Lion BR is online now   Reply With Quote
Old 04-04-2010, 07:09 PM   #848
Pomo
gonzo
Pomo's Avatar
Oddometer: 611
And so my ignorance marches on:
I can (sort of) understand why the Ohlins bushing may fail, being two pieces. Would it be a problem on the Hyperpro? I thought the collective determined that it used a one piece bushing. I can certainly grant that Indy's solution will be more bullet proof, but is this something us mortals will need?
Stubborn and Stupid
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip
Pomo is offline   Reply With Quote
Old 04-04-2010, 08:22 PM   #849
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
You are correct. Ohlins and Elka use a multi-piece upper shock eyelet. Hyperpro uses a single solid piece upper shock eyelet like stock. A stock shock or Hyperpro shock and and Ralle Moto brace will do just fine.
If you have a Ohlins or Elka, I'd get Indy's setup.
Old 04-04-2010, 08:54 PM   #850
Indy Unlimited
Oddometer: 1,343
Hyper pro is a 2 pc bushing system as well as Elka and Ohlins. They all use the same size spherical bearing.
Current Stable:
Old 04-04-2010, 09:07 PM   #851
Chop Chop
Hector erector
Chop Chop's Avatar
Oddometer: 1,675
I thought it might be without examining it, given that all three shocks look similiar. Just an uninformed observation.
The outside diameter of the Elka bush is 22mm, do you want me to send you a photo for confirmation? or doesn't this matter in the overall scheme of things?
TIA
If you don't want the piss taken, stop giving it away!
Chop Chop is offline   Reply With Quote
Old 04-05-2010, 08:17 AM   #852
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Damn.. good to know.
Old 04-05-2010, 04:23 PM   #853
sturgeon
sturgeon's Avatar
Oddometer: 932
Originally Posted by johngil
6.9 off of Baja CA
Felt it good here.
Yeah, yeah, but did it bend your upper shock bolt?
sturgeon is offline   Reply With Quote
Old 04-05-2010, 04:27 PM   #854
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,797
Maybe that's been the problem all along.
Old 04-05-2010, 04:37 PM   #855
sturgeon
sturgeon's Avatar
Oddometer: 932
Just stay outta the subduction zone!
BTW, I know it can actually be serious business sometimes; even though I'm from eastern Canada, I rode out the '89 Loma Prieta quake at my cousin's place near SF. It was 'interesting'. She's legally blind and has MS, and she got me to a safe place. I'd experienced a couple of other minor ones, but that one was pretty scary for an easterner. It amazes me how nonchalant Californians are about it all.
Times are GMT -7.   It's 07:42 AM.
