Old 10-18-2011, 02:09 PM   #1186
toowheels
on a mission...
toowheels's Avatar
Oddometer: 850
Originally Posted by johngil View Post
I'm no badass. I'm a 43 year old dude with a hot wife and a 10 year old boy who barely likes me. Self employed in the worst economy since the Great Depression.
Nothing to prove and just out to ride and have a good time.
BMW under engineered this bike. Plain and simple.
I do still love her and will be sad to see her gone. That's the truth.
Not that sad, though. She has been replaced!
I can't help it...I like your summary Sounds like you have at least a couple of things going for you!
I know you're going to have a ton of fun throwing the TE630 around!! From some of your pics I'd say it's gonna be a great bike for you.
Looks like the special naked MOD parts will have a new home.
Back on topic...I'm afraid to look at all the back end susp. bits on my bike
I'm light so that helps but I don't always ride softly...
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
& Giant Loop for Canada
www.motooverland.com
toowheels is offline   Reply With Quote
Old 10-18-2011, 02:52 PM   #1187
worthydog
Shosholoza
worthydog's Avatar
Oddometer: 451
where do I get the Indy Kit you speak of?
worthydog is offline   Reply With Quote
Old 10-18-2011, 03:18 PM   #1188
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,259
Click the LINKY
-Scott-
Semper Fi
'04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC
No Pride and Even Less Sense - A Ride Report
YetiGS is offline   Reply With Quote
Old 10-18-2011, 06:26 PM   #1189
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,137
PM me for details on the Indy kit shock mount shown here:
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 10-18-2011, 09:28 PM   #1190
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,502
I will give another shameless plug for the Indy kit.
Without Dan's fix installed I wouldn't even consider riding my bike off road.
I wish I kept better track of things, but I think I've got 15,000 miles total and at least 6,000 off road miles with this setup.
Thanks Dan.
johngil is online now   Reply With Quote
Old 10-18-2011, 10:10 PM   #1191
Apostolos
Oddometer: 389
Thanks Dan.
Since this thread reemerged I decided (yesterday) to pull my upper shock bolt out again just to see how it looked, and thankfully, it was still straight.
I ride quite a bit off-road and probably more aggressively than what the bike was designed for.
I have a stock suspension. I weigh about 185lbs wlth all my riding gear on and my top case with contents usually weighs about 10 pounds. I keep my preload adjusted at 10 full rotations (I believe there are 20 total). I hit washboards, I get air, my bike gets thrashed around and takes the occasional dirt nap, and my shock bolt is unaffected.
When I do ride with a full-load (panniers) I take it real easy and I try to stay on the pavement.
John, I don't know if you're comfortable sharing your weight load information, but I'm wondering if there are any lightweight guys like me bending shock bolts or is it mostly the heavyweight guys who tend to carry full loads off road as well?
God Bless,
David
Apostolos is offline   Reply With Quote
Old 10-18-2011, 10:29 PM   #1192
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,502
I'm heavier than the targeted rider, I'm sure. About 230 pounds. I have a bit of a belly, but I'm no sperm whale either. I have heard of several bent bolts from riders closer to the intended weight of the bike, though. One of the differences may be total dirt miles. I'm guessing my bike has around 8,000. Hard to say exactly. When I do hit the trail, it is generally for extended lengths of time.
While I don't jump, I do occasionally ride at fairly high speeds for miles and miles on some pretty shitty roads. Is that the answer? Who knows?
I don't know.
I could go out with a stock bike and bend the top and bottom bolts in a couple of hundred miles.
I'm very happy to know your hardware is still all straight.
Old 10-18-2011, 10:43 PM   #1193
Apostolos
Oddometer: 389
So 230lbs (is that with your riding gear on?), long stretches of miles in the dirt... Are you loading the bike up as well (panniers, etc.)?
God bless,
David
Old 10-18-2011, 10:49 PM   #1194
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,502
I take it pretty slow when loaded up. Most of the damage has been with just little old me and a well stocked tool bag.
Old 10-18-2011, 11:11 PM   #1195
Apostolos
Oddometer: 389
Maybe we need to encourage Indy to create a swing-arm bolt modification.
I wonder what would be next in the lineup to bend or break once those two areas are better engineered?
God Bless,
David
Old 10-18-2011, 11:22 PM   #1196
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,502
In my electrician that has ridden and owned motorcycles most of his life general opinion....
The bolt diameters are simply too small.
Old 10-19-2011, 01:25 AM   #1197
trustme
trustme's Avatar
Oddometer: 818
Nope. too long & lacking support , if they were to small in diameter they would be more prone to shear.
Good guess for a sparkie though
I wish you well , you have been more patient & tried harder than most.
trustme is offline   Reply With Quote
Old 10-19-2011, 11:06 PM   #1198
Snowy
Oddometer: 1,145
Fitted my Ohlins rear shock a couple of days ago and found the top bolt was slightly bent.
Mind you, I've been mountain fire trail riding with my wife on the back, and doing lots of dirt roads at "mid life crisis" speeds with her and camping gear strapped on. A good 430lbs of rider/pillion/gear. Not too bad.
The bolt straightened with a couple of taps with the hammer on a flat anvil. There's a technical term for it that I'd have to ring and ask my father about, but getting a 75 year old retired machinist/metallurgist talking about bolts is about the last thing in the world I want to do to myself right now. I'd sooner do a lobotomy with an electric drill.
I have jumped the F8 a bit, bottomed out horribly a few times, and got some cool air with the wife on the back. So it isn't really a surprise.
The solution is to get a better grade of bolt, methinks. I may well weld a brace against the right side of the shock to better prevent the bending. Or make a clamp style brace to save welding the frame. I'm inventive, but lazy.
Snowy is offline   Reply With Quote
Old 10-20-2011, 03:21 AM   #1199
Snowy
Oddometer: 1,145
That's one way of putting things.
BWAAAAHAHAHAHAHAHAHA
I know sometimes shit just happens, but I do have some minor concern over a bent bolt with the treatment it's had. It hasn't been abused. For the type of bike it is supposed to be I'd expect it would take a fair pounding without bending or breaking.
I mean people talk about how unbreakable a DR650 is, and I broke mine heaps. So much so that by the time I got rid of everything about it that didn't work there isn't actually any DR left (some of the frame and the engine is all that is original, apart from the plastics). Are they a solid bike? Yeah, sure. But there are some things you just shouldn't do on a wanna be trail bike.
Doesn't stop me from wanting to do them.
The F800 is no trail bike. But with some Ohlins suspension and some knobbies on it that's kind of hard to remember when the blood gets hot.
First time it falls on you it comes flooding back.
Oh, and I've put 18000km on it in 6 months. Evenly spread between commuting, freeway, back roads (dirt and tar), and forest tracks. Love it. Just bought some new Andy Straps soft panniers to compliment the Ohlins. Weekends away!! Giggity Giggity.
Old 10-20-2011, 10:44 AM   #1200
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,259
Originally Posted by DonHS View Post
Only room for one on that pedestal, eh Finn?
Have you seen Finn?? He's a frickin' needle. Turn him sideways and he disappears.
-Scott-
Semper Fi
Times are GMT -7.   It's 05:51 PM.
