Old 03-21-2012, 04:15 PM   #1246
x-man727
x-man727's Avatar
Oddometer: 10
I will install my indy kit this week end
x-man727 is offline   Reply With Quote
Old 03-22-2012, 01:50 PM   #1247
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,492
Question
where do I get a kit??
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 03-22-2012, 02:16 PM   #1248
picard
engage!
picard's Avatar
Oddometer: 1,284
PM Indy Unlimited. He'll set you up.
"Rumors of my assimilation are greatly exaggerated." (Capt. Picard)
picard is offline   Reply With Quote
Old 03-27-2012, 06:32 AM   #1249
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,393
Yeah PM me for an Indy kit.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is online now   Reply With Quote
Old 03-31-2012, 07:33 PM   #1250
mungus
mungus's Avatar
Oddometer: 113
Question Still not fixed?
So after all these years the F8GS has been sold, BMW has not updated / fixed this problem?
Is there anyone from a BMW agent here who can say if there has been a service bulletin put out on it?
I haven't even checked mine yet, its a 2010 model...
"I did not have sexual relations with that woman"
mungus is offline   Reply With Quote
Old 03-31-2012, 09:05 PM   #1251
picard
engage!
picard's Avatar
Oddometer: 1,284
Mine is an '11 and the bolt was slightly bent after ONE (longer) dual sport ride. Do it before you have permanent damage.
Old 03-31-2012, 10:30 PM   #1252
mungus
mungus's Avatar
Oddometer: 113
Eek Uh oh!
Uh Oh!
It thats the case I better check mine when I get home in a few days. Mine does a bit off road and and its usually carrying a fair bit gear too. So perhaps mine is already bent? I've just ordered an Adventure moto kit as it includes a new 12.9 rated hi tensile bolt with the mount. (As advertised the RM one looks like it's just the block only).
Its a pity that some have found their reinforcing blocks foul an Ohlins aftermarket shock, as I was mulling one over, but given that the Ohlins has no compression adjustment or remote reservoir, I wasn't sure if its any better than getting the OEM Sachs rebuilt and revalved with a decent spring. Poor specs for an Ohlins IMHO! All my other Ohlins have had compression adjustment. But then I see it is listed by Ohlins as being from their "budget" line. However one poster says you can grind out space for the hydraulic preload adjuster and reduce the pin length slightly too, (and also maybe turn it around a bit). Not sure if Wilbers have a decent shock for the F8GS...
Looking back at this whole thing; given that this is a well known issue with the potential for buggering the frame and stranding the bike somewhere nasty, I would have thought BMW would have made up their own little kit to be fitted to all F8GS's via either recall or at the next scheduled maintenance. Selling a bike whose frame can be damaged and shock break loose with normal use in its advertised activity is IMHO selling a product thats not fit for purpose. And doing nothing about fixing it when it has the potential for stranding a customer somewhere inhospitable or perhaps even causing injury (if the shock lets go at the wrong time) might almost be regarded as negligence. Poor show BMW...
mungus screwed with this post 04-01-2012 at 04:24 AM
Old 04-02-2012, 10:31 AM   #1253
stephen.stallebrass
stephen.stallebrass's Avatar
Oddometer: 265
Originally Posted by ebrabaek View Post
So.....Got two Indy Kit's..... and thought we'd mock with the shock in place...rather than remove it.... I know...I know.... But we did.... Tried to attack my '09 first... Had a shock...gold in color... Made this contraption from a M12 with washers and a SS nut........
Installed...ready to begin.....
Half way there......
Done.......
New bearing, and metal sleeve installed and greased......
Do you reckon this will also work on the Ohlins shock?
www.AdventureVagabond.com Mongolia & Siberia 2012: Adventure Moto Madness
stephen.stallebrass is offline   Reply With Quote
Old 04-02-2012, 11:19 AM   #1254
ebrabaek
Oddometer: 4,757
I have never worked on the ohlin's.... But if the mounts are the same..... I would say yes.....
Erling
Old 04-02-2012, 11:43 AM   #1255
stephen.stallebrass
Oddometer: 265
I think it probably would but just checking before I try it on my brand new shock. I think there are two separate bushings, at least that what I've deduced from looking inside the bushing. If it's any help here's a couple of pics:
Old 04-02-2012, 01:06 PM   #1256
ebrabaek
Oddometer: 4,757
That should work as well.... You might need to find the right size socket if it is different than the oem.... Other than that... parts are cheap....and if somethings break.... It is the bolt as we experienced on one of the bikes.... I'd have a go at it...
Erling
Old 04-02-2012, 01:12 PM   #1257
stephen.stallebrass
Oddometer: 265
Cheers mate!
Old 04-02-2012, 04:33 PM   #1258
Indy Unlimited
Oddometer: 1,393
On Ohlins, that bushing is actually 2 piece and you can pry out each end to expose the bearing that can be pressed out with a socket and a vice. You can also put each end in the vice and rock and pull the shock to remove each bushing. Do not press out the bushings with the bearing unless they are smaller than 26 mm O.D. I think these are slightly bigger.
Current Stable:
Old 04-02-2012, 04:47 PM   #1259
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Hi all,
Anyone know the torque spec for the shock bolt? I'm thinking of checking mine finally this week. Gotta few months left on my warranty and just wanted to see what the dealio is.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 04-02-2012, 05:01 PM   #1260
picard
engage!
picard's Avatar
Oddometer: 1,284
100 nm IIRC
Times are GMT -7.   It's 07:12 PM.
