Old 04-05-2012, 06:17 PM   #1276
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
Eek the bolt was perfect.... I guess I am not a real rider..
BMW stock shock INDY KIT install.... great idea to drill out the rubber ....I should have read first..... I used the socket method... It was a bitch... (finding the right pitch threads and bolt around my shop was a impossible). got the rubber out and the inner steel core....the inner ring is still in...shit.... I think I will take the hack saw out tommorow morning and very carefully cut it out...
on a scale of 1 to 10 diffculty is a 8 for me not having the correct tools.
Originally Posted by lawe View Post
The post about the homemade puller was great insipration, but it was not that easy to do it like that...
I ended up taking the busing apart in place by removing the inner part first and then cutting the outer part with a hack saw to remove it. Removing the inner part is quite easy. Just drill a lot of small holes through the rubber and take it out using the homemade puller and at the end a monkey wrench.
The outer part of the busher is the tricky one. I used the hack saw carefully to cut it into two pieces. I ended up with some small scratches from the hack saw inside the holder for the bushing, but I don't care to much about that.
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 04-05-2012, 06:26 PM   #1277
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,405
I use a spark plug type 13/16" deep socket ( 27mm O.D.) to press out the entire bushing. Do not use a hacksaw. You should use a press and push it into a socket that is just push it into another socket of 1-1/16" or 27mm - 12 point style
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 04-05-2012 at 08:11 PM
Indy Unlimited is offline   Reply With Quote
Old 04-05-2012, 06:39 PM   #1278
HighTechCoonass
Oddometer: 2,493
Thumb
Thanks for the advice... I will try again INDY. 1" on one side and a 13/16" on the other? I definitely don't want to scar the surface.... 28mm od...my fricken mic is at the office...
Originally Posted by Indy Unlimited View Post
I use a 1-13/16" deep socket to press out the entire bushing. Do not use a hacksaw. You should use a press and push it out with a socket that is just under 28mm O.D.
Old 04-05-2012, 08:13 PM   #1279
Indy Unlimited
Oddometer: 1,405
1' or 1-1/16" - 12 point style deep socket to receive and 13/16" deep socket to press thru.
Current Stable:
Old 04-05-2012, 08:16 PM   #1280
HighTechCoonass
Oddometer: 2,493
Nope it did not work.... the 13/16 caused the inner race to mushroom.... and the nuts a bolt began to strip ( 4' cheater pipe) 3/4 wrenches.
It is very difficult to keep the sockets centered while tightening...
Took out the hack saw and cut two slices into the race....not going thru just enough to weaken.... then knocked it out with a screw driver.
Done... for a one man job difficulty 8 out of 10.
It would be worth and extra $30 to have a "removal" setup...
A fine threaded bolt, nut and washers
two properly sized pieces of pipe (substitute for the sockets)
Old 04-05-2012, 08:25 PM   #1281
Indy Unlimited
Oddometer: 1,405
Sorry it did not work. I have done about a dozen of them with a deep 13/16" socket that is 27mm O.D. and they all press out. The rubber from the inner bushing may have helped but I have done many on my press. I highly recommend a press to do a stock shock. Aftermarket shocks can be done with hand tools. Most bike shops can help you if you bring the shock in and ask them to press it out with a 13/16" socket
Current Stable:
Old 04-05-2012, 09:23 PM   #1282
HighTechCoonass
Oddometer: 2,493
Laugh
yeap... If i wouldnt have pushed out the rubber bushing on "phase one" it would have been easier to keep everything aligned...
It is a very nice unit Indy... I can rest easy now... I was always worried about that stinking bolt... especially since I am now out of warranty!
Ready for Utah now!!!
Old 04-06-2012, 10:40 AM   #1283
stephen.stallebrass
stephen.stallebrass's Avatar
Oddometer: 266
Fitted my Indy kit & Ohlins shock today... It really was easy! I used the socket trick to get the Indy race bearing into the upper shock mount and then swapped out the old shock for the new one. Not taken it out yet as I twisted my bloody ankle in the garden afterwards, which is throbbing, plus I need to set the sag, preload & rebound? That'll have to wait until 2mora. Thanks for all the great advice on this thread. I was gonna take some pictures as a tutorial, but there really is no need, it's so easy.
www.AdventureVagabond.com Mongolia & Siberia 2012: Adventure Moto Madness
stephen.stallebrass is offline   Reply With Quote
Old 04-09-2012, 06:56 AM   #1284
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I left the Elka lip and ran slightly off center. Zero problems.
johngil is offline   Reply With Quote
Old 04-09-2012, 07:16 AM   #1285
Indy Unlimited
Oddometer: 1,405
Thanks John,
I prefer that we use a wider bearing but for those that don't want to remove the step but want to look centered I have a narrower bearing option that is the same width as the spherical bearings the aftermarket companies use.
Current Stable:
Old 04-22-2012, 04:29 PM   #1286
skamikazee
Noviço
skamikazee's Avatar
Oddometer: 245
Here's my EVIL-BUSHER-EXORCISM setup:
Why oh why didn't i read the whole topic before spending the whole morning trying to remove the damn thing.
skamikazee is offline   Reply With Quote
Old 04-22-2012, 04:32 PM   #1287
ebrabaek
Oddometer: 4,763
Erling
Old 04-22-2012, 05:07 PM   #1288
Indy Unlimited
Oddometer: 1,405
I dont recommend that technique on a stock shock. You need a 1- 13/16" deep socket or a metal cylinder that is 27 diameter or larger but smaller than 28 mm diameter and a receiving deep socket that has room for a 28 mm diameter bushing to fit in it. You will need to use a hydraulic press and at least 1 ton (1000 kg) of force to get it to budge.
Sorry if that was not clear in earlier posts. Aftermarket shocks are a breeze.
Current Stable:
Indy Unlimited screwed with this post 04-23-2012 at 11:47 AM
Old 04-23-2012, 03:28 AM   #1289
skamikazee
Noviço
skamikazee's Avatar
Oddometer: 245
I dont recommend that technique on a stock shock. You need a 13/16" deep socket or a metal cylinder that is 27 diameter or larger but smaller than 28 mm diameter and a receiving deep socket that has room for a 28 mm diameter bushing to fit in it. You will need to use a hydraulic press and at least 1 ton (1000 kg) of force to get it to budge.
It did work for me, the 30mm Socket is large enough to allow the bushing to slide inside without touching the socket, the stock spacer and screw are just the right size to pull the damn thing with a large thick washer to push the thing, once halfway through, a 27mm deep socket and a hammer slowly got it out.
It wasn't easy, but it worked. Still, if only i'd spend less time looking at pretty pictures and more time reading the threads........
....I would definitely taken the shock out and ask someone to press it out.
...great workout though
F800GS - Nellie the Elephant
Old 04-23-2012, 05:36 AM   #1290
Snowy
Oddometer: 1,838
With the Ohlins shock pressing the bearing out was the easiest part of the operation. The rest was not difficult.
I went with Indys kit and the Ralle Moto brace combo as per JohnGil.
Using it for 2 up trail and dirt road riding I have just installed the 3rd new rear spring. It now has the same as the picture above with the 84/200. I think this is around the 21kg/mm mark.
It works the best yet. With a revalve it doesn't bottom out like it did previously. It takes a fair hit to bottom now, even with a big load on. I would rate the current rear end set up as as close as I could hope to get considering the lack of adjustability with the Ohlins.
The bottoming is what was doing the majority of the damage to the shock bolts.
So, in Aus dollars, that's $1460 for the shock, and a further $800 in rebuilds and springs, plus another $250 in shock bolts and kits to fix shock bolts.
Ohlins here appears to have no idea whatsoever about what spring rates to use. I was very specific about what I was going to use it for and the exact weights it would carry. Their recommended spring was some 5kg/mm lighter than what I ended up with.
I didn't use the O-rings that came with the Indy kit. I made some alloy spacers and used a smaller section O-ring with the alloy spacers. I'll post some pics for Indy when I can. In appreciation for a solution that works.
Snowy is offline   Reply With Quote
Times are GMT -7.   It's 01:30 PM.
