Old 08-25-2009, 11:55 AM   #121
tmex
tmex's Avatar
Oddometer: 2,039
Originally Posted by ]I)Money
I don't think I was very clear. I called it a red herring because the original bending happened with the stock shock in place. My opinion is that, once bent, the mount is pretty likely to bend again, even with a theoretically better shock in place.
True. Unfortunately John does not have that part documented photographically. I were a dealer, I might be inclined to be skeptical.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 08-25-2009, 12:04 PM   #122
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
I'm working on mileage and dates. I have quite a few bent bolts. I believe the dealer has the original. This photo isn't very easy to interpret. Viewing the stock shock in person shows much more.
I will admit to not categorically documenting things the way I should have. Hell, this thing started out as just another motorcycle for me.
johngil is offline   Reply With Quote
Old 08-25-2009, 12:15 PM   #123
tmex
tmex's Avatar
Oddometer: 2,039
Eh?
I know exactly what you mean. I am beginning to have some doubts developing as well. I am in denial at the moment. BTW, I talked to two dealers today, and neither one is giving me warranty coverage on the grenaded wheel bearing. At this point I just want to bring my bike home so I am not arguing.
Old 08-25-2009, 12:27 PM   #124
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,588
Wtf?? (On them not covering it, I read your post about it grnading.)
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 08-25-2009, 12:37 PM   #125
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,739
Bruno, did yours bend as well ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-25-2009, 12:56 PM   #126
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,961
Yes, Frank. It did. The top one and the bottom one.
Bruno T . is offline   Reply With Quote
Old 08-25-2009, 12:58 PM   #127
DockingPilot
Oddometer: 9,739
Holy flip !
Same outcome as John ?
Frank Reinbold
Old 08-25-2009, 01:20 PM   #128
itsatdm
itsatdm's Avatar
Oddometer: 4,938
I think the shock mount not being torqued adequately from the factory is a distinct possibility. Thats based on enough reported cases of improper torque values being applied to rear sprockets, clutches and steering head bearings. I am not an engineer so I will reserve judgement on the strength of the design, though intuitively I still have trouble with two bushings butted together at 74ft# will adequately prevent the bolt from bending. How much that supported bolt load is spread over both mounts is also open to question. One look at the mounting flanges makes it obvious which one is expected to receive the most load. I am sure BMW studied how much the "lever" effect of the left mounting flange will multiply the amount of force being applied to the crossmember, at least I hope so.
Old 08-25-2009, 01:27 PM   #129
DockingPilot
Oddometer: 9,739
Of course! The same dept who studied how to design the BMW final drive
Frank Reinbold
Old 08-25-2009, 01:35 PM   #130
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,961
Holy flip !
I couldn't source a replacement Ohlins or a factory shock down there. I had to have my factory shock shipped down to me so that i could proceed with my ride.
Since i couldn't locate a new upper bolt quickly enough, we straightened the one i had. We put it all back together with the Sachs shock and straightened upper bolt, rode it like that for approximately 3,000 miles without incident.
The straightened bolt did not deform again until it was replaced by a new one upon my return home.
Since then it's been ridden another 4,000 miles, including several dual sport rides, without incident. I last checked both bolts about a week ago, with a dial indicator and V block.
Old 08-25-2009, 05:19 PM   #131
guzzimike
guzzimike's Avatar
Oddometer: 1,401
Hope this is not taken as a rude question, but John & Bruno, how much do you guys weigh? And what weight of luggage would be typical?
Armageddon Was Yesterday, Today We Have a Problem
East is East & West is West 2008
http://www.advrider.com/forums/ad.php?t=400050
A Long Weekend 2009
http://www.advrider.com/forums/showthread.php?t=523893
All the Way to Nowhere & Back Again. 2010
http://www.advrider.com/forums/showthread.php?t=619683
Save 5 bucks on your Smugmug, use my discount code
hQo9Atub1N9jg
guzzimike is offline   Reply With Quote
Old 08-25-2009, 05:35 PM   #132
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,801
With tools, water, extra fuel, etc. and my petite ass I'm @ 240-260 pounds combined.
Loaded for a longer trip and panniers full of clothes and beer the bike weighed in @ 560 pounds. That isn't typical for me, and I sure as hell wouldn't be tearing it up w/ that kind of weight in the dirt.
Old 08-25-2009, 06:50 PM   #133
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,961
I weigh 190.
Weight had little to do with my particular failure, i hit a pretty substantial G-out at speed which caused my shock to bottom. Ohlins replaced my shock saying that they had "determined the cause of the failure".
The replacement shock was built with a higher rate spring.
I thought that Ohlins handled the situation very well. They could very easily have refused to warranty my shock based on the fact that they cannot build a product that will withstand any and all possible loads.
I'm not sure whether my Ohlins shock that failed was built with a correct rate spring, maybe it was, maybe not. I did provide all of the pertinent information required (weight, etc.) when i ordered it.
Let's say, arguendo, that my shock was built with a lower than adequate rate spring. I'm not sure that even a higher rate spring would have prevented the failure. It most likely would have helped, but who knows whether or not it would have prevented it.
Old 08-25-2009, 07:58 PM   #134
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,588
Originally Posted by Bruno T .
I weigh 190.
When your bolt bent, did the mounts bend too?
Semper Fi
Old 08-26-2009, 04:37 AM   #135
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,778
Originally Posted by JoelWisman
Don't ask how this happened, in short it was not intentional and passenger has still not forgiven me.
Still sleeping on the couch?
The point is that one doesn't have to dismiss their sense of decency and diplomacy to make a point. - Luap
I think people who are that bad at lying are probably too stupid to be taken seriously. - #18
You're a slut. But you're cute, so it's ok. - MayQueen
RedUly is offline   Reply With Quote
Times are GMT -7.   It's 01:24 AM.
