Old 10-08-2012, 10:22 PM   #1336
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,371
Hey Lukas,
The only solution for the new WP shocks using a 25mm O.D. bearing is to use a self lubricating bushing or bore out the shock mount to 26 mm bore. I will provide the bushing for people without access to a mill.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 10-09-2012, 08:23 PM   #1337
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 2,066
Is there some trick to removing that plastic cover over the top of the shock? I've taken those 4 nuts off and a bunch of other plastic pieces but I can just barely move that cover.
Thanks in advance.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Shawnee Bill is offline   Reply With Quote
Old 10-09-2012, 10:08 PM   #1338
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,457
Thanks in advance.
There are 2 torx screws on the sides where the fairings attach.
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
'09 BMW F800GS, '14 KTM 1190 ADV-R
Camel ADV is offline   Reply With Quote
Old 10-10-2012, 05:49 AM   #1339
ebrabaek
Oddometer: 4,745
Thanks in advance.
Ha ha.... I feel your pain...... Don't ask me why....
Erling
Old 10-10-2012, 06:37 AM   #1340
Indy Unlimited
Oddometer: 1,371
It has been a while but I think there are black cable ties from the main wiring that need to be cut off.and replaced later when you reinstall the plastic shock mount cover.
Current Stable:
Old 10-10-2012, 09:01 AM   #1341
xboxer
Oddometer: 36
I have a buddy with an F800GS, trying to help him prepare a little for this bent bolt problem. Been diggin' for 10 pages or so, 80 to go and I'm completely burned out.
Can't find a pic or a link or ANYTHING about the Indy Unlimited brace. Indy, are you trying to keep these things all for yourself? SHARE bro!
xboxer is offline   Reply With Quote
Old 10-10-2012, 09:57 AM   #1342
Indy Unlimited
Oddometer: 1,371
First 10 pictures show kits being installed
http://s1208.beta.photobucket.com/us...y/BMW%20F800GS
Current Stable:
Old 10-10-2012, 03:38 PM   #1343
SDDinNH
Ridgerunner
SDDinNH's Avatar
Oddometer: 100
I'm coming up on a rear shock change this winter on my 658, but I haven't finalized my decision yet. I'm kind of leaning toward a Wilbers. Is the Indy kit a "one size" fits all, or does it have to be ordered for a specific shock?
Steve
2013 R1200 GSW
One out of four people is insane - check your three best friends - if they seem normal then it must be you!
SDDinNH is offline   Reply With Quote
Old 10-10-2012, 09:26 PM   #1344
Indy Unlimited
Oddometer: 1,371
Indy kit is shock specific. Wilbers is covered. Just confirm which shock you plan to buy when you order the kit.
Current Stable:
Old 10-14-2012, 06:13 PM   #1345
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
I'm curious if the 2013 has the same upper shock mount design as the 2012 and earlier models?
Old 10-15-2012, 11:05 AM   #1346
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
I thought you sold your F800 and went with the orange Kool-aid. You cant come here anymore.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 10-15-2012, 02:20 PM   #1347
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Yes, and I have to say I am thoroughly enjoying the orange Kool-Aid as well! Though from my experience with my 990 R so far, no Kool-Aid has been necessary to convince me...The bike speaks for itself! Suspension, power, lightness, stability, well-thought-out design features, etc...Just curious though. Having owned my F8 for 3 years I am still mentally invested in that bike....and the thing that bothered me most aside from the front fork inadequacies was that stinkin' upper shock mount design. Just wondering if BMW finally addressed it.
Old 10-15-2012, 05:29 PM   #1348
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,938
Y'all still talking about this?
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 10-17-2012, 04:04 PM   #1349
DolphinJohn
Caveman
Oddometer: 3,938
Originally Posted by FredRydr View Post
Sure! Inmates come and go in the thread, and newcomers who are considering an aftermarket rear shock need to know.
Fred
True. I haven't been in this section in a while. My stock OEM bolt and shock have held up well, 16,000 miles.
My Ride Reports
Old 10-20-2012, 07:57 PM   #1350
PatrickM
Oddometer: 363
Looks like the 2013 design is the same as the prior years.
Untitled
Untitled
And since I don't have a socket or anything large enough for the bushing and stuff to go through - aborting.
Someone asked previously... Basically pop the seat, remove two of the fairing torx (T25), the 4 bolt heads w/ washers (8mm) and 4 zip ties that are holding the wiring harness down. There's a round doo-hickey that gets removed, as does the connect with the two wires. The other end of the two wire connector is removed with a screw driver pressing a release lever to the outside from the center (directly under the oval portion that connects, allows it to slide towards the front of the bike). Slide the plastic thing towards the rear and attack the large bolt with a T55. At some point it'll slip and the shock will tighten against bolt. Lean some weight against the rear (I was on a center stand) and the bolt will wiggle loose.
And now back to 100NM... Sigh.
PatrickM is offline   Reply With Quote
Times are GMT -7.   It's 09:22 AM.
