Old 04-22-2013, 07:20 AM   #1426
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
Indy Kit
Pulled my rear shock yesterday while servicing the swingarm pivot and the Indy kit has kept my bolt straight. I don't do crazy jumps or anything but do weigh 220 plus gear and the stock bolt had bent slightly. Every F800GS owner I meet gets a sales pitch from me on the Indy kit.
Originally Posted by craigincali View Post
I admit I havent followed this thread at all last year. Are you guys still having problems with bent bolts / frames???
I thought Indys solution seemed pretty good.I ask because I am back in the market for another bike and doing my usual research.
Has anyone figured this out yet?
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 05-10-2013, 10:55 AM   #1427
dbh
d00d
dbh's Avatar
Oddometer: 48
Ordered my kit today - will use it with a new Elka - all should arrive in time for my birthday. Which will be spent, wrenching and riding. It's all good.
dbh is offline   Reply With Quote
Old 05-14-2013, 08:05 PM   #1428
joew_33
Oddometer: 4
F700GS - shock experiences
Have the 2013 F700GS with Indy kit installed with roller bearings and Öhlins shock. The 2013 plastic side cover is too narrow to allow me to have used the replacement bolt (the head is too fat), so I had to reuse the factory bolt which has a smaller profile head. I did use Igus spacers (I used IGlide M250 model spacers in 26 MM OD, 20 MM ID and cut to length on both sides). Thanks Indy for supporting us!! What do you recommend in terms of a replacement upper shock bolt for a 2013 model to accommodate the lack of clearance for a fat bolt head? Do you suggest I order up a bushing as posted to replace the needle bearing?
joew_33 is offline   Reply With Quote
Old 05-14-2013, 09:55 PM   #1429
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,464
Just PM me your mailing address and I will send you a new bushing in the mail.
You can use any grade bolt since my sleeve protects the bolt from seeing any bending load. The Grade 8 bolts I provide are socket head and stick out a little farther but I did not know that was an issue on the 2013. I now offer Igus spacers precut to 10 mm length as standard for aftermarket shocks.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 05-19-2013, 09:51 AM   #1430
joew_33
Oddometer: 4
Received Indy Oilite Bushing
Hi all. Just received the new Indy Oilite 20x26x20 bushing. If anyone has any photos or experience with the new bushing, please share with the collective team. Thank you.
Old 06-11-2013, 12:55 PM   #1431
dbh
d00d
dbh's Avatar
Oddometer: 48
Installed a new Elka with the Indy kit last weekend. Rides like a dream.
And it is a nice piece of kit - too bad nobody will ever see it!
I can't imagine what it would take to bend that bolt now.
Maybe the problem has not become such that BMW is considering redesigning this shock mount, but until then I heartily advise this kit as the answer.
Old 06-11-2013, 08:34 PM   #1432
gnurob
Oddometer: 87
I don't understand how this is not a massive recall and redesign.
gnurob is offline   Reply With Quote
Old 06-12-2013, 04:35 AM   #1433
Snowy
Snowy's Avatar
Oddometer: 1,922
Most owners don't bend them. I suppose it must fall within their expected warranty failure rate.
I ended up doing away with the Indy kit and going to the alloy brace job. Rally Moto or whatever it's called.
Then I employed the Schrodinger cat theory. It is both bent and straight until I take the seat off and find that it is, in fact, bent.
Then I will shrug, and utter my favourite expression "it is what it is".
Such is life.
Snowy is offline   Reply With Quote
Old 10-07-2013, 07:15 AM   #1434
gspirate
Oddometer: 81
Originally Posted by XT Traveler View Post
Just a heads up to anyone with a 2013 F800GS -- the Best RestShock Bolt Support Brace ddoes not fit the 2013 F800GS without significant modification. I have the ESA version but I doubt that it is different that the other 2013 in this respect.
I had to remove a .324" slab from a significant part of the lower portion of the brace to make it work on mine (this was not removed from the area where the shock bolt goes through or the area where it bolts to the frame but rather the area which loops under the tubular frame portion. If I had a milling machine there was probably a more elegant and less invasive approach but I didn't.
The 2013 model now has a threaded boss, a bolt, and a plastic bracket installed on the large tubular portion of the frame that the brace slips around (sorry I didn't think to take picture until I'd already made the mods and installed it -- I was a little frustrated at the time). I don't think the modification significantly alters the functionality or basic integity of the brace. I will be calling David at Best Rest later today to let him know what I found. So anyhow heads up for you 2013 owners.
Has anybody else with a 2013 confirmed/ posted any pictures of their upper mount? Im looking at purchasing 2013 model and would like to know if the using the Best Rest brace is the best option.
gspirate is offline   Reply With Quote
Old 10-09-2013, 01:31 PM   #1435
DanyalDenyo
DanyalDenyo's Avatar
Oddometer: 16
I am going to change my shock spring with a HyperPro spring so I'll have to fiddle with the famous upper shock bolt. I understand the torque value of the bolt is critical. Since I'm living in Turkey in a small town that's a problem for me because I can't find a torque wrench that's calibrated. (I don't want to buy one unless I really have to). There are decent torque wrenches I can borrow but none of them are calibrated.
I'm thinking if there's any room for over-torquing the upper bolt just to be on the safe side without damaging where the bolt goes in and if so how much is it?
I hope the knowledgeable folks in the forum will answer and better yet advise how much % more should I torque it.
DanyalDenyo is offline   Reply With Quote
Old 10-09-2013, 01:34 PM   #1436
Motoriley
Motoriley's Avatar
Oddometer: 2,686
Torque
It is a fairly big, long bolt going into steel. If you are a little over it won't strip. Intentionally over tightening won't stop the bolt from bending.
Old 10-09-2013, 01:38 PM   #1437
DanyalDenyo
Oddometer: 16
How much % do you mean by a little?
I am aware the bolt will still be vulnerable I just don't want it to be weaker than stock in case the torque wrench I am using is not accurate.
Old 10-20-2013, 08:27 AM   #1438
Sohere
Sohere's Avatar
Oddometer: 32
Installed my new hyperpro rear shock today and discovered this ...
Had the indy kit installed with a hydraulic press, though it seems the bearing got out.
Shock bolt seems to be fine ...
Sohere is offline   Reply With Quote
Old 10-20-2013, 09:37 AM   #1439
Indy Unlimited
Oddometer: 1,464
You need the stock rubber spacer (without steel sleeve) to keep the bearing from walking off.
some people cut spacers out of pvc pipe to locate aftermarket shocks ends from walking as well.
Current Stable:
Indy Unlimited screwed with this post 10-20-2013 at 05:08 PM
Old 10-21-2013, 10:17 PM   #1440
Fré
Fré's Avatar
Oddometer: 52
800GS shock bolt design flaw?
I tried to find in this post, but aint sure about it: can someone tell me exactly what is inside the stock shock? I know there is a needle bearing pressed into the upper rod eye, but the sleeve that holds the bolt, is it a straight piece part? Can someone give me the dimensions of it? I am trying to look for another option to strengthen the shock mount design. Thank you in advance!
Fré is offline   Reply With Quote
Times are GMT -7.   It's 02:59 PM.
