Old 10-22-2013, 07:06 AM   #1441
Sohere
Sohere's Avatar
Oddometer: 32
Originally Posted by Indy Unlimited View Post
You need the stock rubber spacer (without steel sleeve) to keep the bearing from walking off.
some people cut spacers out of pvc pipe to locate aftermarket shocks ends from walking as well.
K thanks. Is there any way to use the kit, made for the oem bmw shock, on a hyperpro rear shock?
Sohere is offline   Reply With Quote
Old 10-22-2013, 08:03 AM   #1442
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,306
You need the stock 30mm long rubber and to cut two 10mm long PVC spacers to locate the 20 mm wide HyperPro shock in the 40 mm wide gap of the stock shock. Or you can cut one spacer 10 mm long and the other 40 mm long and eliminate the rubber.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 10-22-2013, 08:05 AM   #1443
Indy Unlimited
Oddometer: 1,306
the stock shock uses a bore that is 28 mm diameter x 40 mm long
Current Stable:
Old 10-22-2013, 12:18 PM   #1444
Fré
Fré's Avatar
Oddometer: 45
That's a pity cause I recently had some hardened sleeves made that could have been usable for this application. The bolt is m12 right? Reasons for my questions is that I would like to make evrything ready before dismantling the shock bearings. Thanks.
Fré is offline   Reply With Quote
Old 10-22-2013, 01:14 PM   #1445
Indy Unlimited
Oddometer: 1,306
My sleeve works for all shocks you need different bearings for the hyperpro vs stock shock.
Current Stable:
Old 10-28-2013, 09:11 PM   #1446
GoneAgain
Huh?
GoneAgain's Avatar
Oddometer: 1,571
replaced the plugs yesterday, so had a quick look at mine..
2012 with 45,000kms..
mount tabs look fine, dont think the bolt is bent... think the shock bush is a tad worn hence the slight twist in the shock..
replaced the spark plugs and put her all back together..
GoneAgain is offline   Reply With Quote
Old 11-07-2013, 07:21 PM   #1447
husky123
Oddometer: 1,454
I just ordered my hardened rear shock bolt. How easy/difficult is it to get to the top shock bolt. I'm a new 800GS owner. Thanks.
husky123 screwed with this post 11-07-2013 at 07:56 PM
husky123 is offline   Reply With Quote
Old 11-08-2013, 02:30 AM   #1448
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,612
litteraly VERY easy. in less then 5 minutes you have it out there and that is with some time to drink beer. As long as you have a good wrench it should'nt be a problem since that bold is really tight/hard screwed in there.
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 11-08-2013, 05:14 AM   #1449
husky123
Oddometer: 1,454
Thanks Loutre, good to know.
Old 11-15-2013, 09:06 PM   #1450
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,399
The F800 isn't the only BMW that suffers from this. The photo below is from a friend's 2007 R1200GSA that's currently in my garage. The lower bolt completely snapped (4th time) and the upper was very bent. They are only M10 (these were 12.9 grade). All bikes have their flaws.
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
Camel ADV is offline   Reply With Quote
Old 11-16-2013, 12:29 AM   #1451
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,612
Do you end up building aux tanks for GSA's now?
Old 11-16-2013, 02:17 PM   #1452
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,399
No comment
Old 11-19-2013, 06:56 AM   #1453
mungus
mungus's Avatar
Oddometer: 113
It's just such a pity that BMW really let themselves down so badly when designing this area. Upper shock bolt mounts have never been a problem on any other bike I've owned, including hammered MX & Enduro bikes, racing, vintage etc. In over 40+ years of riding / racing I have never seen this fault replicated. Their 1000RR and G450X etc shows they know how to build decent bikes when they try. But apparently they couldn't be bothered with the F8GS? Even leaving the mount unchanged for years despite feedback like this being easy to find. One has to wonder if they care? Or perhaps they figure most BMW ADV buyers are pussies who barely go off the black stuff? (probably true IMHO).
It would have been so easy to build a decent (i.e. normal) top mount into the frame and use a decent bolt instead of the spindly, overly long, little piece of junk.
12 mm for a bike that has to support 300+ kg all up, and not even a decent HT bolt at that. My dirt bikes use anything from 12 to 16 mm with proper HT bolts, and never have such a long unsupported bit of bolt a'la F8GS. Just plain bollocks IMHO.
I don't even jump this bike or even carry luggage most of the time, yet it bent during its first 2,000 km of mild use. Not even real ADV work by my usual standards...
The new HT bolt I fitted plus the "Best Rest" alloy bracing block seems to have stopped it for now, but come on... This should NEVER been required.
If I ever strip this bike to the frame and remove all the computers I'm seriously considering making a proper shock mount there.
BMW - you should be ashamed of yourselves. Call this an adventure bike? Add this mount flaw to the low spec (read cheap crap) suspension and I really wish I'd bought something decent, like a KTM or the new spec 660 Tenere. Sadly I am now too deep into this heap to sell it without losing a ton of $$. But if BMW think I'll be recommending their "Adventure" bikes, they'd be mistaken.
"I did not have sexual relations with that woman"
mungus screwed with this post 11-19-2013 at 11:30 PM
mungus is offline   Reply With Quote
Old 11-19-2013, 09:01 AM   #1454
kpie
Oddometer: 146
2013 F800GS Indy Kit ?
I think Indy said he is not building a kit for the 2013 F800GS. Is this still the story or does the kit work with the '13 model? I had one on my 2011 F800GS. Sorry if this has already been addressed.
KPie
kpie is offline   Reply With Quote
Old 11-19-2013, 09:22 AM   #1455
Indy Unlimited
Oddometer: 1,306
Sorry guys but I have no more kits.
I made a batch of 1000 and they are all sold over the last 3 years.
I can't afford to make smaller batches and keep the costs affordable.
Inquires have dwindled to only 30 in the last 6 months so I can't see the risk in making another 1000 batch run.
My recommendation is to fall back to the Best Rest Products support bracket and new high grade bolt:
http://www.bestrestproducts.com/p-25...ort-wbolt.aspx
It is not the best solution but much better than the stock set up.
Thanks to all that use the Indy kit.
Current Stable:
Times are GMT -7.   It's 11:56 AM.
