Old 07-19-2009, 03:39 PM   #1
clintnz OP
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,587
KTM 640 Subframe Repair & Strengthening
I just had a crack repaired & some bracing added to the subframe on my 640 & thought I'd post up some pics.
The crack was in the rear end of the tube that the tool box mounts to. (see pic) The right side subframe rail was bent down a little, probably from a big endo I had a while back, & I think this has put stress on that tube & then it has cracked. I recently did lots of corrugated roads in outback Australia with a load on the rear rack & that was likely the final straw. Most of my gear is carried in my panniers that are mounted well forward, apart from one stretch of the Oz trip where I had 10L of gas on the back there is usually at most 7kg on the rear rack.
There was a thread over in the Oz forum about broken 640 subfames but I thought I should post this up here for the masses. There is also a pic of Loaded's similar repair efforts in this thread (scroll down) The std failure mode seems to be for the tool box tube to crack like mine, then the left side rail gives way just behind where the gusset on that side ends. So keep an eye on the end of that lil' bit of tube, especially if you carry a load on the back.
I cleaned it all up & made the gussets then got a friend who is a pro TIG man to weld it up. I just used 2mm steel. Cro Moly would have been the proper thing to use but I couldn't find any closer than the USA & several weeks delivery.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz screwed with this post 07-20-2009 at 02:16 PM
clintnz is offline   Reply With Quote
Old 07-19-2009, 05:24 PM   #2
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 780
That is some serious bracing! I have already lost my toolbox and the tubing it was bolted to, broke right off. Have had some welding done to the left side of the subframe as well. May have to look strengthening both sides at some stage.
Thanks for the post Clint.
Trev.
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 07-19-2009, 08:38 PM   #3
clintnz OP
clintnz's Avatar
Oddometer: 3,587
Trev.
I'd look at adding some bracing sooner rather than later if I was you, without the toolbox holder/brace there's a good chance she'll just crack again. I firmly believe that it is a waste of time just welding up anything that has broken under normal use - a redesign or some extra metal is required to prevent the same problem happening again.
Cheers
Clint
Old 07-21-2009, 09:56 PM   #4
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,261
Ya know, since I saw Loadedagain's subframe bracing years ago, and countless posts about bent/broken subframes I wonder if the few pounds saved by the "racing" subframe are really worth it... on a supertanker.
Thanks for the nice how-to post Clint, and thanks for bringing your link in too crazybrit.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 01-27-2010, 02:48 AM   #5
LukasM
Oddometer: 5,427
Do you guys know if the subframe on the LC4 is made of the same steel as the main frame - 25CrMo4?
Cheers
Old 10-06-2010, 10:48 PM   #6
kiwipeet
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,015
Nice work Clint
Good to know there is an expert nearby when I get my Adv
kiwipeet is offline   Reply With Quote
Old 10-18-2010, 03:20 AM   #7
overlandr
Dystopist
Oddometer: 5,926
Cheers
We really need a KTM factory mole. I bet the German fora have them.
overlandr is offline   Reply With Quote
Old 10-18-2010, 03:31 AM   #8
LukasM
Oddometer: 5,427
I actually called HQ here in Austria and managed to get through to a factory engineer a while ago. Subframe is indeed made of the same CrMo steel.
Depending on how serious you take your welding you could use a different rod and maybe pre/post heat treat the welds. Different opinion depending on who you ask, although race car guys and roll cage fabricators are probably a good source. Carroll Smith recommended to pre-heat the metal and to normalize the welds afterward in "Engineer to Win" (I think....).
Old 10-18-2010, 04:54 AM   #9
overlandr
Dystopist
Oddometer: 5,926
Thanks. Metals seem much happier with Annealling - look at some welded structure fractures and it often occurs at the edge of the weld. I gather the welding of (eg) titanium can involve a large degree of pre and post (welding) heating where access to ovens is reqd. I guess Akra would be familiar with this material.
Old 04-04-2011, 01:23 PM   #10
kiwipeet
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,015
Thumb Sweet
Sorted
Old 04-04-2011, 02:57 PM   #11
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,361
the subframe is fine and all, but i hardly see it with the 70 series in the background
2 SPOT is offline   Reply With Quote
Old 04-04-2011, 04:49 PM   #12
clintnz OP
clintnz's Avatar
Oddometer: 3,587
If a glimpse of a half disassembled 70 turns you on that much, you'll certainly enjoy the full story http://www.offroadexpress.co.nz/Foru...hp?f=18&t=2123
Cheers
Clint
Old 04-04-2011, 09:07 PM   #13
bmwktmbill
Traveler
Oddometer: 5,219
For Cromo you could braze it.
Cool it slow>?
Am I wrong?
Well anyway I have.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-05-2011, 01:50 PM   #14
clintnz OP
clintnz's Avatar
Oddometer: 3,587
Cool it slow>?
Am I wrong?
Well anyway I have.
bill
Yep, nowhere near as strong as a weld but it will work in pinch. If an oxy acetylene plant is available Cro-mo can apparently be welded quite well by a skilled hand on a torch too. From my dim memory of engineering class Cro-mo does need to be post heat treated for totally optimum weld strength, but one reason for its popularity is that just letting the weld cool slowly gets you near as dammit.
Cheers
Clint
Old 04-05-2011, 04:23 PM   #15
Wylie
Back in the saddle again
Wylie's Avatar
Oddometer: 2,234
This is a project that has been on my mind for a while now, just another reason to buy a welder!
Okay so I'm not Super Man. I'm just the jack of many trades, master of some yet to find and as the world turns that would only be for a matter of time.
Okay, screw it, stop the world I'm getting off.
Wylie is offline   Reply With Quote
Times are GMT -7.   It's 09:28 AM.
