Old 03-17-2010, 10:56 AM   #76
cug
Oddometer: 3,469
Smallest Topcase for Givi Base Plate
Question for all the top case junkies here ...
I have a F800GS with SW Motech Aluminum rack and Givi Adapter plate on that. Normally I use a Maxia E52 top case.
Now, for about 80% of my rides, that top case is WAY too big. My question now is, what is the smallest top case that fits a Givi Monokey base plate?
Thanks for hints!
cug is online now   Reply With Quote
Old 05-29-2010, 10:59 AM   #77
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,100
zero case for top case...added drawer pulls for tie downs...
The F800gs Snatchy Throttle Fix Boost your Beamer...BMW efi GS Power Controller - l Now the Juice NEW!TheJUICE
HighTechCoonass is offline   Reply With Quote
Old 05-29-2010, 11:10 AM   #78
Adventure boy
Adventure boy's Avatar
Oddometer: 402
Heres Mine
Live a little Love a little Ride a lot
Adventure boy is offline   Reply With Quote
Old 05-29-2010, 12:49 PM   #79
planethopper
Oddometer: 20
Originally Posted by teleiosGS
Nice!! I have the same laptop with the same stealy sticker:) Still touring but in a different direction.
planethopper is offline   Reply With Quote
Old 05-29-2010, 05:38 PM   #80
DSjunky
Runnin On Empty
DSjunky's Avatar
Oddometer: 57
Wicked BMW Factory Case's
We have the BMW factory top case and panniers on the little woman's F650GS twin. They are slick as snot. On or off in seconds, lockable, width adjustable, and become mini suitcases for easy carrying.
What's all the hub-bub about cases?
Get Motorrad and be done.
"Shes a brick and I'm drowning slowly. Off the coast and I'm headed nowhere."
BMW F650GS - 800 twin, Yamaha's: XT225, TTR225 (x2), and TTR125ES.
DSjunky is offline   Reply With Quote
Old 05-30-2010, 04:42 AM   #81
Wildman
Man of Kent
Wildman's Avatar
Oddometer: 16,069
Top case is fine but don't drop the bike with those panniers on.
"Every county of England, every country of Europe and every (part of every other inhabited) continent of the Earth" ... 80% complete!
Counties: 39 of 39 - done!
Countries: 36 of 42; last up, Portugal, next up, Iceland
Continents: 5 of 19; last up, North America (USA), next up, Central America (Cuba)
Wildman is online now   Reply With Quote
Old 05-30-2010, 04:45 AM   #82
Catskill
tree hugger
Catskill's Avatar
Oddometer: 1,783
I thought the same thing about my side cases...then my F800gs fell over from a total stand still while not even on and the hinges of the left expanded case shattered like rock candy. They are not durable at all and I have no doubt after seeing the damage from a fall standing still that they will destroy them selves in a real crash... I still use the right one and I do love the convenience of taking it on and off but when I get the money to buy replacement ones I will be looking for more a more durable brand.
STOP the land grab
If we stuff the duck with chocolate, does that make him a fudge packer?
Catskill is offline   Reply With Quote
Old 05-30-2010, 02:30 PM   #83
DSjunky
Runnin On Empty
DSjunky's Avatar
Oddometer: 57
Note taken. She has dumped it twice, but the cases were not expanded. No damage was done other than minor scratches. I presume that they were not designed to be crash bars, but if they are fragile then thats not right either.
Old 06-07-2010, 10:30 AM   #84
Harry Swan
One more time
Harry Swan's Avatar
Oddometer: 1,073
Do I need more support ...
Okay, I've got a fairly good sized Storm Case made by Hardigg mounted on a Jesse quick release on a Jesse F8 rack and it weighs in at 29 lb. total! My question is to those who have mounted Pelican cases and the like ... do I need a complementary supporting plate inside the case with that weight?
Without getting into the actual contents be advised it's equipment I need to carry to those places really less traveled. If not need I'm tired of traveling without equipment germane to my interests.
This is the same plate/rack system mounted to a smaller Pelican case for reference
http://hsswan.smugmug.com/Other/GS/6...75189471_fRavR
It's not too late
Harry Swan is offline   Reply With Quote
Old 06-07-2010, 02:05 PM   #85
Catskill
tree hugger
Catskill's Avatar
Oddometer: 1,783
I should clarify that the case hinge shattered because it was expanded. They are not designed to withstand impact while expanded. It also kind of bent itself inward and the rubber piece that's supposed to keep water out came off its seam. My husband was able to get it to a point where I can use it but had to choose expanded or unexpanded after that.
STOP the land grab
Old 06-07-2010, 03:17 PM   #86
GeckoRider
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 412
Caribou rack and pelican 36 liter cases top and side. Probably go for some soft water proof saddlebags if only running longer trips off road, but most my solo touring the hard cases make the most sense.
http://cariboucases.com/store/?name=...=i&item=000159
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, throttle Rocker, Airhawk seatpad, Pivot Pegs, Renthal grips, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
Wishing for farkles; If/when I can ride offroad better- suspension, rims.
GeckoRider is offline   Reply With Quote
Old 06-08-2010, 02:53 PM   #87
JRWooden
Oddometer: 3,441
Harry:
I'd either use some big "fender washers", or if not too much trouble find a plate of aluminum that fits the "flat" part of the inside of the case, mark the holes and then bold thru it for extra strength.
Old 06-08-2010, 02:55 PM   #88
JRWooden
Oddometer: 3,441
The BMW cases are made of "thermoplastic" resin -- the kind that softens with heat and then hardens again when cool.
If the case is distorted (not broken into pieces) you may be heat it (with something like a hair dryer on high) and soften the plastic enough to get it back into better shape...
Old 06-08-2010, 06:43 PM   #89
Harry Swan
One more time
Harry Swan's Avatar
Oddometer: 1,073
Originally Posted by JRWooden
Harry:
Thanks, I think you're right. I am using 1 1/2" fender washers on the inside now but I think I should invest in some aluminum to be safe....
It's not too late
Old 06-11-2010, 08:26 AM   #90
Catskill
tree hugger
Catskill's Avatar
Oddometer: 1,783
Good advice. That's exactly what my husband did to jerry rig it back together. I can not expand or contract the case but, for now, it works to just open and close the outside.
STOP the land grab
Times are GMT -7.   It's 11:37 PM.
