| Welcome, lurker! Even if you don't post, the system can help you find the good stuff faster if you register. |
Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
GaStronaut
Oddometer: 370
External GPS antenna mount under GS beak
Under heavy tree cover and along rock walls I often get the "lost satellite reception" message with my Garmin SP2610.
I wanted to know whether it makes sense to mount an external GPS antenna and whether it's bad to mount in under the GS beak instead of on top of something. As I didn't find a clear and straight answer anywhere, I did my own testing tonight. * [INT] internal antenna patch only * [ON] external antenna on top of the beak * [UNDER] ext. ant. under the beak * [TOP] ext. ant. on top box Put camera on tripod with interval setting: one pic every minute. Here are the results: 1) The external antenna clearly gives me more satellites and stronger signals. 2) On or under the beak doesn't seem to make much of a difference. 3) On the top box seems weaker than under the beak. So in the garage I went and made me a bracket to fix the antenna under the beak. Looks like this: I'm happy with the result. :) I'll report back with satellite experience in the Black Forest, by the end of September. Cheers, Michel |
#2 |
Occasional Adventurer
Oddometer: 2,479
Antenna?
Michel, which external antenna are you using?
Bob Naumann - W5OV - Sachse, TX - K1300GT - IBA #19100 |
#3 |
the arched eyebrow
Oddometer: 29
Muy Sano...
I, too, would be curious which antenna you're using. Looks like the GA26C REMOTE ANTENNA WITH BNC ? You installed without the suction or magnetic mounting options, one assumes?
Elegant use of zip ties, and congratulations on admirable application of scientific method to this vital question, though your report did lack reference to the requisite consumption of cold fermented sustenance as the required ritual celebration of triumphant engineering-tude. But much can be forgiven in light of your understandable excitement at achieving such significant results. ![]() I'm curious if you tooled around the neighborhood at all while you were taking readings whether the signal strength of top-box vs under-beak would still have shown such a stark difference in reception. Were you mounting the GPS antenna unit on top of the top box, or underneath the topbox lid? Is that an OEM top box? [The endlessly deep black plastic might prove to have passive radio-jamming/shielding properties. Who knew? Perhaps all stock BMW luggage is manufactured from cast-off material from Northrop B-2 skin moldings? Might begin to explain how pricey those sidebags are...] Now of course you have-- innocently enough--taken the first step towards becoming the source for a new market demand in beak-brackets...vendor forum awaits. Z. |
#4 |
GaStronaut
Oddometer: 370
This is the antenna:
10052-05 GA 27C low profile remote automobile antenna It wasn't mounted inside the topbox, just put on top of my Touratech Zega XL box. I wonder whether the funny result could be because of the flat aluminium surface under the antenna? Cheers, Michel |
#5 | |||
Cap'n Flatulence !
As you would expect Quote:
This bit has me confused, how the hell does it even work under the beak, there is no L.o.S ??? I put my GPS under the beak as a trial and got NO sat signals at all, as I would expect..... WTF ?????????? Quote:
That's odd but not knowing the exact metodology, did you do an "up and back" to take into account Sat location ? ie depending on where the Sats where in the sky, your body could have been bloking that bit of the sky where most Sats where when the ant. was on the top box behind you... I have always thought about just behind the windscreen, on top of the plastic bit in front of the instrument cluster, or another thought was a BT GPS there, talking to the PDA on my bars but then I have never really had a problem with just "on the bars" ![]() PS Try the ext. ant. on top of your helmet |
#6 | |||
GaStronaut
Oddometer: 370
Maybe the moving clouds in the sky and the changing satellite position had something to do with it too, but it certainly didn't get better than under the beak. So that's where it's gonna stay for now. Cheers, Michel |
#7 | |
Cap'n Flatulence !
None at all and my hand was cradling the GPS, not over the antenae itself but I didn't expect there to be any signal, which is why I am totally suprised that you got any signal, put your hand over your aerial, that's esentially what your "beak" is doing. |
#8 |
Restless traveller
Oddometer: 191
I field tested an external aerial for my Garmin GPS V during a recent month-long trip on my Africa Twin. I mounted the aerial on the rear fender of my bike, under the plastic top box, and it worked fine. Good reception everywhere I would expect it, with only tunnels and really dense trees reducing the signal strength. Even when I had a large metal cable lock stored in the top box performance wasn't affected. My main concern was that the cable passed the engine with all those lovely spark plugs emitting EM interference, but I guess the cable is well enough shielded to not be affected.
Iain |
#9 |
Roamin Hands
Oddometer: 159
On top....
I did similar experiments without the camera and the antenna now sits on top of my beak. I honestly did not try under....hmmm. I think I might move it just to prove to myself that it works under there. Wow...mabe I can buy more of sigels custom aluminum work!
#10 |
Goin' South
Oddometer: 216
What degrades GPS signals
I was told recently that there are two things that can "Block" or degrade a GPS signal from reaching a receiver. Meat and Metal. Plastic, as long as it is reasonably thin, is not a big factor.
#11 | |
beta tester
Oddometer: 1,143
Nonconductors (aka dielectrics) can still cause GPS signal loss by detuning the antenna. But it takes a lot. The GS beak is pretty thin, much thinner than for example a non-metallized car windshield which causes no GPS problems.
"A voyage whose two ends were out of sight - a voyage sufficient in itself." "Master and Commander", Patrick O'BrianIBA 31991 |
#12 |
Gelande Sauté It
Oddometer: 3,044
MiGSel, great job testing! Tony's right, plastic won't couple with the antenna like a conductor (aluminum) or water bearing meat. Hmmmm, there's a joke in there somewhere......
Did the signal strength drop after the metal bracket was installed around the antenna? Dumb Question Department: when you guys did your testing, is only the external antenna pulling a signal or is the attached antenna working in parallel?
ускорение Mondo Slabo to Alabamo Last edited by CroMag : 08-09-2004 at 05:57 PM. |
#13 |
H.I.D. Positive
Oddometer: 10,137
"I understand the dilemma. Correct spelling takes time that could be spent licking the windows on the short bus." mac62 "There is just something special about a stripper with a tail" ilmostro
#14 |
a.k.a. Daniel
Oddometer: 2,411
Great testing Migsel.
I use the same external antenna for my 276C. I just stick it on the top of the tank with magnet and it stays. I completed a 2,500 mile trip to Ouray and back with no problems. The only benefit I see of having it below the beak is to keep the bike clean from attachments. I once saw an external antenna mounted on top of the beak and it looked quite cool. Why mount it below the beak?
Daniel '97 R1100GS (SOLD) '07 R1200GSA An adventure is only an inconvenience rightly understood. An inconvenience is only an adventure wrongly understood. G.K. Chesterton, British writer |
#15 | ||
GaStronaut
Oddometer: 370
![]() It looks cleaner, cable & antenna are more protected, nobody's gonna wanna steal it, no silly questions asked when I park the bike somewhere, ... |
