Old 08-02-2009, 03:29 AM   #16
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Originally Posted by Hank.SD
Something like this...
http://www.dan-marc.com/79-afc11112.html
12 Volt Multi Fuel Shut Off Valve
Item# 79-AFC11112
Regular price: $29.87
Sale price: $25.65
Availability: Usually ships in 2-3 business days.
That's a great find, thanks!
ktm950se
ktm950se is offline   Reply With Quote
Old 08-02-2009, 02:43 PM   #17
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,698
Originally Posted by FINNDIAN
I like the idea of a vacuum pump as they almost never seem to fail.
Would mounting the pump high on the bike help the hydrolock problem.
These pumps seem to have some resistance to free flow.
Strange the needle and seats in the carb don't prevent a hyrolock. The fuel should run out the carb overflows before into the engine if the needle and seat aren't doing their job.
Mounting high will not help hydrolock -it will syphon just like any other system unless you are way high. And high will promote vapor lock - thats when it IS high enough.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 08-02-2009, 04:16 PM   #18
crofrog
Oddometer: 1,455
The carbs on a 950 are mikuni bst40's not Keihin.
crofrog is offline   Reply With Quote
Old 08-02-2009, 05:25 PM   #19
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,271
ktm950se
I haven't ordered that or the pump yet, but they are both on the must-do list this winter. I've only got 7500 on the stocker, so I'm not concerned yet but I do want to upgrade to something around 10K. I really like the idea of a vacuum pump much better than switching to a Facet.
Let us know how it works out if you try that shut-off! If I'm the guinea pig first, I'll certainly report back.
Hank.SD is online now   Reply With Quote
Old 08-02-2009, 07:44 PM   #20
MT950 OP
"OLD" Adventurer
Oddometer: 246
Posted thead!
This is why I posted this thead!!!! I plan on installing a Vac. fuel pump, and wanted some feed-back. Keep the Questions/info. comeing!! It seems I am not the only one looking for more info. Seem's the way to go, but all info./input is helpfull !! Thanks!!
MT950 is offline   Reply With Quote
Old 08-03-2009, 12:27 PM   #21
jackr
2008 KTM 950 SE
Oddometer: 226
I didn't realize KTM used two different carbs on the 950's. The carbs on my 2008 SE are Keihin CVRD 43's. So this brings up another question, is it the Mikuni's or Keihin's that are hydro locking?
jackr is offline   Reply With Quote
Old 08-03-2009, 02:11 PM   #22
crofrog
Oddometer: 1,455
Well shit. My bad this is some false information on my part.
I had more than one person tell me it was a BST40.
Went and looked at the bike and you are correct sir.
Old 08-04-2009, 07:46 PM   #23
rusty43
cruzincariboucountry
rusty43's Avatar
Oddometer: 334
Just got back from 9000km trip with Alternate Cycle kit on an '05 and '06 950. I installed the kits on both bikes and the '05 had no issues but mine would vapour lock occasionally afterwaiting in construction zones. I moved the suction line from between the cylinders and put it on the left side of the engine, no more vapour lock. I've done the flapendectomy on mine and haven't shut off the fuel petcock yet and have had no hydrolock. I use only one outlet from the pump, mainly because it makes the install job so much easier. Leave the airbox installed and drill the mounting holes in three stages starting with a really small bit and you can get the holes exactly where you want them.
rusty43 is offline   Reply With Quote
Old 08-04-2009, 08:08 PM   #24
SDS
introverted excavator
SDS's Avatar
Oddometer: 932
I've been running the round Mikuni pump for 6-7k miles. I'd actually forgotten about it until I took the seat off Sunday. No problems riding on the highway, and FS roads. I never switch the petcock off. Every now and then it'll puff some white smoke when starting, but other than that it works fine.
SDS is offline   Reply With Quote
Old 08-05-2009, 12:36 PM   #25
jackr
2008 KTM 950 SE
Oddometer: 226
It looks like a flapendectomy may be the answer to the hydrolock problem. Has anyone had a vacuum pump problem with hydrolock on an SE? Has anyone taken the gas cap of an SE apart to see if its restricted?
Old 08-05-2009, 02:35 PM   #26
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,454
In my experience I've found that Vacuum pumps really suck.
Seth S
Seth S is offline   Reply With Quote
Old 08-05-2009, 04:07 PM   #27
kennyd
kennyd
Oddometer: 231
se gas cap
there is no flap or valve on the SE! but it still is possible to flow fuel thru if the tank is full from the (HEAD) simple gravity! it takes over 24 hours to be a problem if your floats are sealing. so just turn off the petcocks when you you are parked overnite!!! takes about 10 seconds!!!
kennyd is offline   Reply With Quote
Old 08-06-2009, 12:34 PM   #28
jackr
2008 KTM 950 SE
Oddometer: 226
10 seconds or not, I hate turning off petcocks. I had about 5 gallons of gas (HEAD) above the Keihin carb on my Harley, and it never leaked past the floats. Whats up with these KTM Keihin carbs?
Old 08-06-2009, 12:41 PM   #29
mookymoo
Mookish Mook
Oddometer: 4,389
boom boom
mookymoo is offline   Reply With Quote
Old 08-06-2009, 12:46 PM   #30
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,308
I have mine for 3000 miles and have no problems with it ,i use a snowmobile mikuni pump from a 1000cc machine
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Times are GMT -7.   It's 07:36 AM.
