Old 08-02-2009, 08:20 PM   #1
shawty950 OP
shawty950's Avatar
Oddometer: 243
990 FI remote filter modified oem fuel pump filter
Hi all,
this is my response to problems detailed/discussed in these 2 threads:-
http://www.advrider.com/forums/showthread.php?t=422042
and
http://www.advrider.com/forums/showthread.php?t=461827
Basically mine started running out of fuel, particularly when cool/cold and when rolling on throttle...sometimes during wheelies...also bumping over curbs causing stalls.
I pulled my pump apart and while all filters were dirty, my issue was not with the sock filter OR pump but the post pump paper filter.
It was severely blocked at 36,000k's and fell apart in my hands
So, what to do...buy the ktm kit...overpriced and will clog/fall apart just as quick OR do something different.
I decided to go with a modified paper( $2 ) filter post pump and an external efi car filter ($30) mounted in front and above the air box.
My thinking is that doing it this way I can replace the small $2 filter every 10,000k's and the bigger filter every 30k.
Here's what I did
- went to local shop and asked for a car efi filter that suited my requirements.
- found a carbied inline plastic/paper filter that I could cannibalize for the paper filter (the paper filter inside the plastic must be at least 35mm long and a maximum diameter of 32mm)
- 2mtrs of efi fuel line (8mm or 5/16")
- 10 efi worm drive hose clamps.
Step 1. Keep(or remove) the off centre end plate from the oem post pump filter (ppf) Its the right one in the pics above.
Get your $2 plastic filter and cut the plastic off and get the paper filter out.
Measure 26-28mm from the terminated end and mark with a pen and cut with stanley knife so you get this
Grab the OEM endcap with the off-centre hole and place on filter like this
Which looks like this when installed
Now I chose not to seal the oem plate to the new cut filter. Reason being is 3-fold
1 - Alot of sealants, while they say they are impervious to petrol are NOT and will break apart and end up in the injectors.
2 - As I am using an external filter, any fuel that bleeds under this non-sealed portion will get picked up there. (This filter is mainly for the FPR.)
3 - If I had sealed it...I would have had to use something called DEVCON, which apparently is a 2-part epoxy that sets hard enough to grind. I was then worried that I would not be able to recover the OEM end plate, with the offcentre inlet, so that it could be used with another $2 paper filter the next time.
So, here the filter I bought
Its a Daihatsu model...RYCO part # is Z520 or other ref RFF-106
I slightly bent the inlet/outlet pipes for better clearance and mounted here
So basically after that I ran 2 runs of fuel line up to the filter.
The quick disconnect on the TB side was removed and and a brass barbed joiner was installed, and then joined to the fuel line connected to the outlet from the fuel filter.
The disconnect was then put on the other fuel line (once cut to the correct length) and connected to the pump as per normal.
Here's a shot of the glove box above
Unfortunately I didn't get any decent photos of the fuel line running...but basically it follows the bottom frame rail beside the crankcase/airbox breather, with the fuel line disconnect coming out at exactly the same place as it does stock.
So, from a point of view of installing/removing the tank there is exactly no difference...it actually is hard to tell that it's been modified.
So anyways, hows it go....works great.
Shawty
shawty950 screwed with this post 10-26-2009 at 09:57 PM Reason: update
shawty950 is offline   Reply With Quote
Old 08-18-2010, 11:17 PM   #2
Vicks
gets stuck in sand
Vicks's Avatar
Oddometer: 3,204
good idea, nice work.
wonder how i missed this thread all these days
2007 KTM Adv990S - Sold, 2010 KTM530Exc-Rally and 2012 KTM Adv990
530Exc Adventurization re-build
Vicks is offline   Reply With Quote
Old 08-19-2010, 04:45 AM   #3
Hipster
Hipster's Avatar
Oddometer: 1,815
Great idea but, I wouldn't want to give up the Uni pre-air filter for this mod.
Hipster is offline   Reply With Quote
Old 08-19-2010, 06:38 AM   #4
shawty950 OP
shawty950's Avatar
Oddometer: 243
Another way...
The placement of the filter in front of the snorkel was not my first choice. Originally, I was going to mount it behind the battery where, on a 950, the original pump goes. The only reason I didn't, was that the filter I bought, was just that little bit too large, to fit between the bashplate and the battery box/underside of the motor.
So, if you were able to find a smaller diameter in-line car efi filter then you could do it where I originally wanted to and still keep the pre-filter.
I will actually search for a smaller dia one next time and run it that way...I was just in a hurry as it was my daily ride and didn't have the time to take it back and search for a smaller one.
Shawty
Old 08-19-2010, 08:18 AM   #5
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,072
You can go with one of these as well, stainless filter element and there are a number of different angles you can get the inlets bits for (screw on parts to attache the fuel line too).
And it is smaller in diameter.
http://www.summitracing.com/parts/SUM-230101/
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 08-19-2010, 11:44 AM   #6
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,419
You should really run a 10 micron filter post fuel pump/pre injectors...
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 08-21-2010, 10:59 PM   #7
lrd2sea
Turned orange,...
lrd2sea's Avatar
Oddometer: 46
My filter after 5,000 miles (Started feeling problems from 3,000 miles).
Unfortunately, the new parts was not readily available. I had to wash it and reuse it. Here's how it looked afterwards,...
The bike has been running well since, till next time...
LRD2SEA
09 990 SM
09 F 650 GS twin (Sold)
lrd2sea is offline   Reply With Quote
Old 07-04-2011, 09:21 AM   #8
Faststage1
mmmm muuuud
Faststage1's Avatar
Oddometer: 140
Here's a new twist on an old great idea. I chose to install a small fuel filter inside the airbox, thus eliminating the need for an additional hole. This fix cost me $11.00. I did re-use the teabag filter after a thorough cleaning in multiple cleaners. The one that appeared to work the best was the Electrical Contact Cleaner.
The parts included:
3ft of 5/16in automotive fuel line
(1) generic fuel filter
(1) 5/16in barded butt connector
(4) 1/2" gear clamps.
(1) small zap strap
Some important points to note, I zap strapped the setup to one of the clips at the rear of the air box so that it eliminated the chance of interfering with the throttle linkage. Also I ground the sharp corners off the clips so they wouldn't puncture the gas line.
I'm still hoping some resourceful soul will find a low cost replacement for the teabag filter.
2014 KTM 500EXC
Faststage1 is offline   Reply With Quote
Old 07-04-2011, 10:02 AM   #9
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,419
Originally Posted by Faststage1 View Post
Here's a new twist on an old great idea...
So... you replaced a 10 micron high pressure filter with an 80 micron filter that's designed for 5psi, and now you've got it running inside your airbox at 51 psi?
Might I make a suggestion... don't ride your bike. It's a bomb!
~ Ken
Old 07-04-2011, 11:05 AM   #10
dmn0507
dmn0507's Avatar
Oddometer: 353
+1
did the same, but with a fuel filter for a FI car
http://www.advrider.com/forums/showp...&postcount=138
dmn0507 is offline   Reply With Quote
Old 07-05-2011, 12:06 AM   #11
Autostream
Autostream's Avatar
Oddometer: 5,833
What he said, might last a week, might last a month, might last for long enough to forget about it, but you are WAY exceeding the design pressure of that filter and it simply is not fine enough for injection systems.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 07-05-2011, 12:06 PM   #12
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
on top of that... the universal 5/16 fuel hose is not designed to hold 51PSI, it too is low pressure stuff like the fuel filter that you installed.... the real EFI fuel hose is thicker and designed to handle the pressures.
anyone have a light.. I can't find my matches...
FYI, IMO, don't start/ride the bike as configured.... you most likely will not enjoy the outcome of high pressure gasoline being sprayed all over a hot engine in a location that would be almost impossible to access to extinguish.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Times are GMT -7.   It's 08:16 PM.
