Old 08-03-2009, 09:25 PM   #1
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,795
Cush Drive Inserts- service life?
I've never owned a bike w/ a cush drive setup.
At 8,000 miles, the rubbers are pretty much toast. They are almost in two pieces.
Is this normal. Bike is a BMW 800 GS.
johngil is online now   Reply With Quote
Old 08-03-2009, 10:04 PM   #2
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
At 10,6XX miles, one of mine was in two pieces.
FWIW, I lube them when reinstalling so they can move and compress easier. Not sure if it actually does anything or if its just peace of mind.
bxr140 is offline   Reply With Quote
Old 08-03-2009, 10:38 PM   #3
Bayner
Oddometer: 1,523
My KTM had an actual spec for the amount you could move the sprocket before the hub moved, but I'll be damned if I can remember what it was... maybe I'll go look if I have the digital manual still.
Bayner is offline   Reply With Quote
Old 08-03-2009, 10:44 PM   #4
Bayner
Oddometer: 1,523
Laugh
Okay, here we go. (Was a 38 tooth rear sprocket IIRC so 6 mm may be acceptable on the 800. I changed mine out when they started to look ratty, which was around 14k kms.)
"Checking the shock absorption rubbers in the rear hub *
LC4 models have a damped rear wheel hub. For this purpose, the engine
power is conveyed from the rear sprocket via 6 shock absorption rubbers
to the rear wheel. These 6 absorption rubbers wear with increasing
operation time, and should be checked for wear whenever the rear wheel is
dismounted.
For this purpose, lie the rear wheel on a work bench with the rear sprocket
upwards, and put the wheel spindle in the hub. Now hold the rear wheel
firmly and try to turn the rear sprocket. The rear sprocket may not turn
more than maximum 5 mm (0,2 in) measured on the outside. If the play in
the chain wheel is larger, all 6 shock absorption rubbers are to be replaced.
Check the shock absorption rubbers for signs of damage and dirt.
! CAUTION !
IF THE SHOCK ABSORPTION RUBBERS ARE NOT REPLACED IN GOOD TIME, THE REAR
SPROCKET CARRIER AND THE REAR HUB WILL BE DAMAGED. ALLWAYS REPLACE ALL
6 ABSORPTION RUBBERS, NEVER SINGLE RUBBERS."
Old 08-03-2009, 11:03 PM   #5
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,795
Thanks for posting that.
Mine need replacing for sure.
Old 08-04-2009, 08:57 AM   #6
Kawidad
Kawidad's Avatar
Oddometer: 4,766
Wow, that's weird. The cush drive rubbers should last almost forever, at least they do on most Japanese bikes.......
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 08-04-2009, 09:08 AM   #7
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 544
V Strom specs are 20,000 miles. Some people say after 2 rear tires. Mine are in very good shape at 16,000 miles. They will be replaced at 18,000 to 20,000 miles. If there is any slop they should be replaced. Slop to death of the rubber I think is pretty quick. This should be a proactive not a reactive service.
If you worn out a set at 8,000 miles. How many tires did you wear out? If the answer was at least 2 then you should be replacing them more often. I paid I think $42.00 with shipping(it may have been a bit more). I think this is absurd amount of money...sin isn't cheap.
Les
Obsessive compulsiveness always trumps good sense.
lesman is offline   Reply With Quote
Old 08-04-2009, 09:14 AM   #8
johngil OP
Reseda, CA
johngil's Avatar
Oddometer: 3,795
Les
On my third set of tires.
Old 08-04-2009, 09:36 AM   #9
nr552
nr552's Avatar
Oddometer: 301
44.5k mine on my wee in a little over 3 years, and the cush is still cush on my bike. I do a lot of commuting though... maybe that helps.
On my DR350->435s I had years ago, it would tear through the cush drive about every 7500 miles due to a lot of off road riding (figure spin and grip of the tire puts a lot of wear on the cush).
nr552 is offline   Reply With Quote
Old 08-04-2009, 09:39 AM   #10
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 984
Silicone spray is a good lube for installing cush rubbers. Silicone grease will stay in place better and possibly improve the wear factor that reduces their size over time. Do not use anything petroleum based. Cheapskates can use inner tube strips or sheet aluminum, depending on the amount of free play, to shim the old rubbers.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 08-04-2009, 12:30 PM   #11
westnash
Oddometer: 3,246
Aren't these there more for noise reduction than anything else? Many aftermarket sprockets don't have them and it doesn't seem to matter.
westnash is offline   Reply With Quote
Old 08-04-2009, 01:58 PM   #12
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Its to absorb the impact transmitted back through the chain to the transmission when you get on/off the throttle.
Old 08-04-2009, 10:45 PM   #13
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,277
you're thinking of the rubber on oem counter sprockets. this does reduce some chain noise, but i'd guess aftermarket does not use because of cost.
this thread is about the rubber inserts inside the rear wheel cush drives
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 08-05-2009, 06:53 PM   #14
cba191
wanna buy a monkey?
cba191's Avatar
Oddometer: 704
my dealer replaced mine at 10,500 miles when the mounted my shinko 705s. the bonus was that they did it at no charge!
cba191 is offline   Reply With Quote
Old 08-05-2009, 07:20 PM   #15
lesman
lesman's Avatar
Oddometer: 544
You definitely drive fast.I'm pissed when my rear tire starts looking worn at 6000 miles and needs replacing at 7500-8000 miles. I may ride fast but I don't ride hard.I've been a driveshaft and belt guy for 20 years. I'm still not enamored with chains and cushdrive dampers. After 18 months it only annoys me.
I enjoy the flexibility of a chain. Modern chains don't break especially with me as a driver.
Les
Times are GMT -7.   It's 08:25 AM.
