Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 191 votes, 4.93 average. Display Modes
Old 02-19-2013, 08:48 AM   #2446
Rinty
Rinty's Avatar
Oddometer: 559
I think that if you install the kit, change the oil every 3 to 5,000 miles, and do a careful filter cut apart and examination each oil change, the chances of trouble are probably minimal.
Rinty is offline   Reply With Quote
Old 02-19-2013, 11:53 AM   #2447
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,516
IMHO...
IMS bearing issues, while real, are overblown. Not a reason to avoid a water cooled Porsche any more than the potential for leaking valve guides or broken head studs are reasons to avoid an air cooled Porsche...
Here is the IMS issue as I understand it:
996/997/Boxster/Caymen engines use an intermediate shaft (IMS) to drive the camshafts and oil pump. The bearing on the flywheel side is a sealed, 'lifetime lubricated' bearing packed with grease. Sometimes the bearing seals leak or fail, allowing engine oil to enter the bearing. Over time, the oil can wash out the grease from the bearing. Once the grease is gone, the oil wash alone is not enough to lubricate it and the bearing will eventually fail. Unfortunately, when it fails, it also dumps the chewed up bearing parts in the engine, which then tear things up nicely.
  • Most 996's & 997's, and all Boxsters and Caymans have the same fundamental IMS bearing design.
  • The failures in early (99-01) 996's seem to be most common.
  • 996/997 Turbo's, GT2's, GT3's *do not* use the same engine design and do not have the IMS bearing issues.
  • 1%-2% failure rate seems to be the number many experts use, though the guys who helped design the upgraded bearings (flat6 innovations) and some forums might convince you it is a much higher failure rate.
  • Costs for repair if a catastrophic failure occurs have also gone way down... Initially it meant a new factory crate engine. Now rebuild parts and/or used engines are available making repair costs on par with air-cooled porsche failures (leaky valve guides, broken head studs, leaking front main O-rings, etc).
There is a ton of advice out there on how to best prevent failures... some of the suggestions I've read below that seem valid:
  • Avoid low mile early cars. A garage-queen 1999 996 with 5,000 miles on it is not a score.
  • Don't go the recommended 10K miles between oil changes.
  • Don't use the factory recommended Mobil 1 0W-40. Use a top quality ester based synthetic 5W-40 with high ZDDP. (Honestly, I don't see how either of the two oil recommendations could help prevent seal failure/washout of the IMS bearing, but they seem like good advice anyway).
  • Inspect the oil filter for metal. You are looking for magnetic (ferrous) metal which might have come from the bearing, not tiny specs of aluminum which are semi-common. You can also drop the oil pan to do a more thorough investigation. This is probably the only PPI inspection item that will give you any idea of a IMS bearing issue (other than the engine sounding like it is full of marbles, of course).
  • Use oil analysis like blackstone labs to look for iron/steel in the oil, showing possible of bearing deterioration.
  • Replace the factory bearing with a ceramic bearing. LN Engineering sells a bearing kit for about $700, but others have sourced a top quality off-the-shelf ceramic bearing for 1/10'th the cost, though it does require some additional steps.
  • Replace the factory bearing immediately if you are paranoid, but definitely any/every time you have the transmission out for any reason (eg: clutch, RMS leak).
  • Note that the latest Porsche IMS bearing design (most 997's for example), have a better bearing design and lower failure rate, but they also can not be replaced without splitting the cases!
  • You can also install the LN Engineering 'guardian'. About $400 and a relatively easy install (replace oil drain plug, install warning light/buzzer in place of blank switch on dash, run wires). This is an early warning system that constantly looks for magnetic metal in the oil, presumably indicating a bearing that is beginning to fail, and fires off a warning light and buzzer. If the warning goes off, you'll still need to replace the IMS bearing as well as thoroughly flush the oil, but presumably you'll save yourself an engine rebuild. If you are paranoid about IMS failure, but don't see any other reason to drop the tranny (high mile clutch, leaking RMS for example), this seems like a good way to go.
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb screwed with this post 02-19-2013 at 12:29 PM
pfb is offline   Reply With Quote
Old 02-19-2013, 10:09 PM   #2448
allonsye
("lets go!")
allonsye's Avatar
Oddometer: 879
Such lovely music
ahhhhh those lovely porsche boxsters......so visceral indeed.
Non-Turbo 911 RSR
911 GT3
"A good traveller has no fixed plans and is not intent on arriving" Lao Tzu (570-490 BC)
Current:
02' GS1150R
06' 650 Vstrom
allonsye screwed with this post 02-19-2013 at 10:20 PM
allonsye is offline   Reply With Quote
Old 02-19-2013, 10:19 PM   #2449
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,974
Originally Posted by pfb View Post
IMHO...
This should be a sticky .
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 02-20-2013, 03:46 AM   #2450
dlearl476
Two-bit Throttle Bum
dlearl476's Avatar
Oddometer: 24,690
IMHO...
[*]Don't go the recommended 10K miles between oil changes.
[*]Don't use the factory recommended Mobil 1 0W-40.
Had the same "discussion" with the tech for my new (to me) Smart car over the same oil. Finally ended it by saying "Just because Exxon-Mobile gives Maclaren-Mercedes a million dollars worth or R&D and oil every year doesn't mean it's the best oil to run in my car.
Besides, it's a French car, it needs Frenchie oil. It's Motul 8100 X-cess 5W-40 changed every 5K for me.
"When the power of love overcomes the love of power, the world will know peace" - Jimi Hendrix
Politics is the gentle art of getting votes from the poor and campaign funds from the rich by promising to protect each from the other. -- Oscar Ameringer
dlearl476 is online now   Reply With Quote
Old 02-21-2013, 06:11 AM   #2451
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,314
No go on the Cayman: the seat wouldn't go back far enough to accommodate my 36" inseam.
Back to the 996 hunt I guess.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 02-21-2013, 07:02 AM   #2452
68deluxe
68deluxe's Avatar
Oddometer: 14,662
Originally Posted by SRG View Post
They are very nice cars. If you are spending that kind of coin -
Get a PPI before you buy from a good indy mechanic near you (ask/join PCA locals). Negotiate w/ indy that you are going to have them replace the IMS bearing w/ the LN aftermarket one as soon as you buy the car and never worry about it again. With a new clutch and RMS this should cost around $2k. Just bite the bullet and do it.
I have an '01 Boxster that's been great and I enjoy the hell out of if every time I drive it.
I wish I had kept my 2001 Boxster (base), I had macho-man fever and traded it for a 2006 997S. What a pile of shit.
2004 KTM 250SX
68deluxe is offline   Reply With Quote
Old 02-21-2013, 07:09 AM   #2453
68deluxe
68deluxe's Avatar
Oddometer: 14,662
Try a Boxster, if that does not work I heard the BMW Z4 has a little more leg room. You could also try an after-market seat such as Recaro , might move back another inch or 2.
2004 KTM 250SX
Old 02-21-2013, 08:48 AM   #2454
Rinty
Rinty's Avatar
Oddometer: 559
You may want to check to see whether you can move the seat rails back one bolt hole. This is possible in some earlier air cooled Porsches.
Old 02-22-2013, 08:35 AM   #2455
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,314
I don't think there's a way to buy more legroom in that Cayman when the seat is pushed right against the firewall (or whatever it's called) and I still feel confined.
Thanks for mentioning the Boxster, but it doesn't really do it for me. All my favorite Porsches have been coupes.
-Chris
Old 02-22-2013, 09:18 AM   #2456
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,473
I don't think I've ever heard anyone describe a Porsche that way. What are the issues you have with it?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 02-22-2013, 10:59 AM   #2457
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
You've obviously never neet anyone with a 944.
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 02-22-2013, 11:54 AM   #2458
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,096
Eh......you mean the guys that bought a $500 neglected 25 year old car and expected it to be trouble free?
I've personally seen many 300k mile plus 944/951/968. Just take care of them and they are great cars.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 02-22-2013, 12:00 PM   #2459
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Nope not those, the well taken care of money pits.
Old 02-22-2013, 12:58 PM   #2460
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,096
Talking
I have yet to find one that is any different than any other 25 year old fast German car
You're buying into the myth
02 KTM 520 EXC
04 KTM 351 EXC
Thread Tools
Times are GMT -7.   It's 04:22 PM.
