Old 10-14-2011, 06:37 PM   #121
GB
Mod Squad
GB's Avatar
Oddometer: 56,367
Originally Posted by prometheus rising View Post
yes, there is a strip of glue reputed to be able to withstand 185 degrees, you attach this to the grip and wrap the rest around then velcro the 2 ends together
i can pop mine off and post some pics if you want to see them ) there are no pics on the beemerbuddie site as of today)
Pics would be appreciated. I ordered a set.
Old 10-14-2011, 09:13 PM   #122
bmwgsrider
bmwgsrider's Avatar
Oddometer: 297
Here is a picture of what couple folks been talking about:
bmwgsrider is offline   Reply With Quote
Old 10-17-2011, 10:28 AM   #123
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
Originally Posted by Hikertash View Post
Ok, so I googled What a Grip to find out where to buy it and was horribly surprised that it's also used by r'itards on their penis to keep it from turtling so they can look bigger when going "commando" in jeans, etc.
Wow, I did NOT need to know that...
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 10-17-2011, 10:52 AM   #124
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,348
Mods: please don't punt the entire thread to Vendors. There is some useful info in here that doesn't pertain to the ongoing transactions. Please consider moving only the relevant posts to Vendors.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 10-17-2011, 10:54 AM   #125
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Agree. Please split the thread into two. One for skinny grips and one for beemer buddies. Cross linked...?
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 10-17-2011, 11:56 AM   #126
JohnnieBoy
JohnnieBoy's Avatar
Oddometer: 115
Right? WTF?
John Hopkins
2011 F800GS
2009 FJR1300A
2003 XR650R
San Diego. CA
JohnnieBoy is offline   Reply With Quote
Old 10-17-2011, 11:56 AM   #127
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
bahaha
I'm sure the original poster had no idea
EJ_92606 is offline   Reply With Quote
Old 10-17-2011, 03:39 PM   #128
stealthman_1
Oddometer: 41
I just got a lot dumber spending 5 minutes on that site. I will never look at lists of people's 'equipment' in their signatures the same way again.
stealthman_1 is offline   Reply With Quote
Old 10-17-2011, 04:38 PM   #129
GB
Mod Squad
GB's Avatar
Oddometer: 56,367
Beemer Buddies group buy thread is now here:
http://advrider.com/forums/showthrea...7#post17096317
Old 10-17-2011, 04:49 PM   #130
'Flagger
'Flagger's Avatar
Oddometer: 2,348
Thanx, boss!
- B
Old 10-17-2011, 05:04 PM   #131
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Good move...
Old 10-17-2011, 05:09 PM   #132
danrider
Oddometer: 3
Originally Posted by Gangplank View Post
So I got my F8GS about 3 or 4 weeks ago. I've put about 1900 miles on it so far and I have very few complaints. One thing that did bug me was the size of the grips. Having ridden BMW's for years I really liked the fatter grips on my F650's dakar heated grips. They were the ones with repetitive ridges or discs... whatever you want to call them.
Anyway, the F8GS has these really skinny grips. They seem more like street grips than dual sport grips. Been thinking about a solution but you can't just change grips because the rubber grip is bonded to the inner heated grip element. So....
I had thought about a set of foam covers I saw on a thread around here, but didn't think they would last and more importantly didn't like the look. Also thought about making a set of neoprene skins but figured I would loose too much heat output from the headed grips and it wouldn't be inexpensive or all that easy to do.
Then riding along the other day I came up with a solution. I stopped by the local dirt bike shop and found a set of these:
Renthal Soft Compound dirt bike grips (diamond pattern)
Seemed like they were thin and streatchy enough...
Here are a few shot of what they looked like before I cut them up:
figured I could just cut the ends off and streatch the remaining tube over the existing BMW skinny F8 grips.
Here is what they look like cut and installed on the bike:
Look pretty good if you ask me. And the price is CBOA approved at $24 all said and done. In the end I had to buy two sets of grips because motorcycle grips come in two different thicknesses - one for the throttle side (thin grip) and one for the clutch side (thick grip). I wound up using the two throttle side grips. A bit of simple green and they slid right not. Took a ride and tested the heated grips. They are definitely thicker than the stock grips. These things are cushy and sticky!!! The heated grips work perfectly too!
Note: I used the soft compound grips, and they are pretty definitely on the thick side. I have big hands so they work perfect for me as the thin grips cramped my hands. These come in soft, medium and hard = light grey, dark grey and black. There are other options out there that might work but these were simple and easy. The mediums might work, in fact the off side grips I still have might work if someone worked at it enough. (anyone want to try send me a PM....) I will probably peel the grip condoms back and spray some hairspray on tomorrow just to make sure they stay put where I need em.
Oh, right one other thing. Once installed they are about the same thickness or circumfrence as the outter most ridge or grip end. Maybe slightly smaller. This is perfect for me as I often find my hands resting against the outside of the grips. now they ride right up on that ridge and I don't even notice. Nice!
Have you found that the grips are also absorbing the vibrations?
Dan
danrider is offline   Reply With Quote
Old 10-17-2011, 05:14 PM   #133
Gangplank OP
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Dan
Not sure I would notice. I don't find the 800 all that vibey compared to my old F650 Dakar single. It is a little more than my GSXR-750 trackbike but that bike is smooth as butter.
I guess I'd say yes they absorb a little but not a so much that you would look to it as a solution... not that there is a solution if you feel vibration is a problem.
Old 10-20-2011, 11:56 AM   #134
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,419
Funny this just came up, I was about to start a thread . . . might still.
I had never thought of my 800GS as a "buzzy" bike, but over the last couple of months it seems it has become more and more buzzy to the point it puts my hands to sleep.
I'm going to try a set of Renthal Gel Rallye grips to see if they help but I wonder if anyone has found any other solution to buzzy grips??
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 10-20-2011, 02:26 PM   #135
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Ya I found a solution....R1200GS
I had the F800ST and it is a buzzy engine. The grip puppies help, but hands still fall asleep after an hour. It was annoying and not the main reason why I switched out to the 1200, but I must say, even without grip puppies, my hands never fall asleep on the 1200.
Times are GMT -7.   It's 12:14 AM.
