Old 08-10-2009, 07:17 AM   #1
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
03 FLHPI Road King starting problem
I ride the bike once or twice a month. It's stored inside under cover. This is the third time for the same ocurrance. Switch on, wait for the computer to boot, pull in the clutch, press the start button, the lights dim and no stater movement.
First time I had the starter rebuild by a very good shop I have used many times for forklift starters here at work. Their record is 100%. At this time I also put in a new starter gear shaft bushing in the primary chain case cover, new strater relay, and new Interstate battery. All cables and grounds were cleaned and re-torqued. It started good for about three months. Same problem. Pulled the starter and sent it back to the rebuilder and they checked it twice and declared it good. Put it back in and about 6 months later same problem. This time I bought a new starter from Harley. After about 4 to 5 months of very little use same no starter problem this morning.
But my Husky fired wright up!
What y'all think? Could the battery to starter cable be bad? No visible corrosion.
Bike in question:
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 08-10-2009, 08:37 AM   #2
Murf2
Oddometer: 827
I'd check it with a meter. See if your leaking a little electricity when it's setting. As a work around, I'd put it on a battery tender. It will help even after you get the problem fixed. Good luck!
Murf2
Murf2 is offline   Reply With Quote
Old 08-10-2009, 08:51 AM   #3
FLYING EYEBALL
out of step
FLYING EYEBALL's Avatar
Oddometer: 10,553
Murf2
+1
And check out your voltage regulator.
I had my vr go on my 03 FLHPI..
as well as a couple buddies had them go on their 03's as well.
I put close to 40K on mine in less than 2 years and the only other thing I replaced was a battery. They are great machines.
Good Luck
if you keep poor...the struggle is simple
my photos http://jskustoms.smugmug.com/
save yourself some $ with my smuggy discount code qvMaWy1bTFU7c
FLYING EYEBALL is offline   Reply With Quote
Old 08-10-2009, 10:40 AM   #4
anotherguy
anotherguy's Avatar
Oddometer: 6,208
Check the right side switch pair.Power comes into the on/off switch and goes over to the starter button.Hmmmmmmm...........'03's had an issue with the main circuit breaker.Your dealer will be able to check and see if that's the problem by the VIN.Hell ya may even be able to check online.But it is a good policy to have a nice relationship with your local Harley dealer.It is a recall/service item and should cost you nada if it is indeed the problem.Eay way to see is the amperage rating.If it's still got a 40 amp breaker it's the issue.Even some of the early 50 amp breakers sucked at a black hole rating.Check it out.
Old 08-10-2009, 01:48 PM   #5
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
Thanks, I'll look into that. It is something common to three starter instalations. I have also had several broken wires in the harness where it "P Trap" bends on its way to the steer head.
And I have a stellar relationship with Mancuso HD here in Houston. They are so friendly and all smiles, while I am handing over the Visa card.
Regards
Fritzcoinc
Old 08-12-2009, 09:26 AM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,412
starter relay (NOT the solenoid)
Old 08-12-2009, 10:59 AM   #7
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
New relay was installed.
Regards
Fritzcoinc
Old 08-12-2009, 11:24 AM   #8
marshrat
marshrat's Avatar
Oddometer: 549
Do you leave it on a battery tender?
marshrat is offline   Reply With Quote
Old 08-12-2009, 11:38 AM   #9
anotherguy
anotherguy's Avatar
Oddometer: 6,208
An easy way to check the breaker is turn on the ignition switch.Oh remove the seat first. Just touch the breaker after a minute or so.be careful it may be REAL HOT.If it's HOT that is probably the issue.They get warm normally but not HOT.You'll still need to take it to the dealer to get it done under warranty but at least you'll have something to tell them.
Old 08-12-2009, 11:57 AM   #10
GARider
Wandering Thru Life
GARider's Avatar
Oddometer: 239
Sounds just like my Road King. It just doen't get riden enough to keep the battery up. Put a battery tender on it and it will start every time you want to use it.
Roger
GARider is offline   Reply With Quote
Old 08-12-2009, 03:57 PM   #11
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
[/PHP]
Nope but I will try it.
Regards
Fritzcoinc
Old 08-12-2009, 03:58 PM   #12
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
I got a new one, $6.79 at the dealer???
Will try it soon.
Thanks all.
Regards
Fritzcoinc
Old 08-17-2009, 06:39 AM   #13
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
Well it seems the breaker was bad. I guess the breaker would trip when the strater load came on and drop out the soloeniod in the starter locking everything up. Installed the new one and the bike spins up like never before. I drilled two holes in the plastic case that holds the breaker to let out water that collects there as the old breaker was corroded pretty bad on the back side. Also cleaned all the connections in the area. Thanks everybody for the advice and info.
Regards
Fritzcoinc
Old 08-17-2009, 09:02 AM   #14
anotherguy
anotherguy's Avatar
Oddometer: 6,208
Under $10 to fix a Harley?Cool.
Old 08-17-2009, 09:50 AM   #15
fritzcoinc OP
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,970
Not exactly.
Frst there was $125 to rebuild the OEM starter plus about $75 in gaskets and oil.
Second, the rebuilt starter out to re-test plus same $75 or so to re-install.
Third, a brand new Harley starter OUCH $425 OH my god, OUCH again, plus $75 or so to install.
Fourth $6.79 for breaker.
Well at least the primary chain is adjusted prefectly and the oil is really clean.
Regards
Fritzcoinc
Times are GMT -7.   It's 03:36 PM.
