Go Back   ADVrider > Riding > Regional Forums > New Zealand
Old 09-25-2009, 01:57 AM   #46
boxer odyssey OP
to excess and beyond
boxer odyssey's Avatar
Oddometer: 138
Newest Bit
My speedo has arrived! This is the most expensive bit I'm adding.
It's a Motoscope Tiny from Motogadget in Germany.
http://www.motogadget.com/us/frameset.html
It's a 2" classic-ish electronic speedo with a digital odo and built in idiot lights.
I chose it as it was a small all-in-one unit and, well, it damn cool!
I'm drawing up the mounting bracket at the moment and will post more when it exists.
boxer odyssey is offline   Reply With Quote
Old 09-25-2009, 03:36 AM   #47
boxer odyssey OP
Oddometer: 138
Clutch issues
I chose the clutch lever above because it uses a dog-leg lever similar to the brembo brake master and has the cable nipple to fulcrum distance is as close as I could find - 33mm as against 35mm for the BMW.
Thats all well and good but what I didn't take into account was the fact that the BMW lever has an offset fulcrum making it pull more cable than the Tommaselli one. The effect being that the new lever won't disengage the clutch, bugger.
So I have prototyped a shorter gearbox arm and a new cable mount (gearbox end) to give the cable clearance around the gearbox. And it works! although I would prefer it to take up a little further from the bar. Further development needed perhaps - I also have a brembo clutch master that matches the brake master I'm using..........
Old 09-25-2009, 06:29 AM   #48
boxer odyssey OP
Oddometer: 138
Clutch issues 2
My Bmw clutch lever draws a total of 23mm of cable and the Tommaselli lever only draws a max of 17mm. This evening I turned up a replacement bush for the Tommaselli lever with an offset hole for the pivot. I have moved the pivot by about 1mm but that was enough to draw an extra couple of mm's of cable and, with my short g/box arm, give a respectable take up point for the clutch - as far as I can tell by turning the back wheel by hand with the bike in gear and pulling the clutch lever at the same time.
I think this will do for now.I'll recheck it once the bikes running again and then finish the parts - file, sand, paint etc - but it looks promising.
This new system will at least get me going and give me more time to find a more appropriate lever so I can go back to the origional gearbox arm - hopefully!
Old 09-25-2009, 10:49 PM   #49
boxer odyssey OP
Oddometer: 138
thanks Mark S
Originally Posted by Mark_S
he's not the only one
those of us with limited mechanical skills watch in awe
please keep it coming
BTW have you seen this
Thanks for the link Mark, I'd seen images of the final bike but not spent any time on his site. Makes my project look like a weekend tart-up!
I've been spending a lot of time oogling his work. Not to my taste necessarily but he's doing the job properly and with a decent budget too! He needs to get it dirty though.
Old 09-26-2009, 01:34 AM   #50
Padmei
enamoured
Oddometer: 3,761
Wow that guy really has spent a lot of time on his project. Amazing how driven perfectionists are to get their parts just right. I was pretty happy with his original bike
I'd hate to think how many hours & dollars went into that baby.
Padmei is online now   Reply With Quote
Old 09-28-2009, 12:14 PM   #51
Eddieb
Eddieb's Avatar
Oddometer: 1,019
Thottle tube
You wouldn't have a throttle tube left over after all this that will be for sale would you? I need one for my R80.
Eddieb is offline   Reply With Quote
Old 09-28-2009, 01:12 PM   #52
boxer odyssey OP
Oddometer: 138
No sorry mate. I'm hanging on to all the bits I've removed.
You could try all the Aussie wreckers or Motobins and Motorworks in the UK or older BMW dealerships may have one kicking about. I've also had some good prices out of the US. Freight might be an issue of course.
Old 10-02-2009, 07:06 AM   #53
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 6,070
Greetings from the far off lands of the ex-colonies....
Just got "referrred" to this thread from over in the Old's Cool section, and have to add that it is just freaking !!!
I have never seen the coils mounted in the ex-airbox, that is hot stuff. I had a /2, and always loved the way the ht's came out of the block on that bike, and you have done it here! My hat is off to some very clever work.
Will keep this thread in my bookmarks, for sure...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 10-02-2009, 10:56 AM   #54
AKjeff
AKjeff's Avatar
Oddometer: 5,473
Nice looking project you have going there boxer odyssey. Your getting into more details than I'm planning on with my project. Yours will look nicely finished. I really like the rear engine cover you made and can't wait to see what else you come up with.
I'm looking forward to seeing yours on the road/in the dirt. Thanks for posting the link.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 10-02-2009, 11:39 PM   #55
boxer odyssey OP
Oddometer: 138
rear suframe
After a productive couple of days the bike is wearing a new rear subfame. I used 19mm o.d. mild steel tube with 2mm wall. The lower mount ends were salvaged from an old subframe, seen in earlier photos here, sleeved and welded on then ground smooth.
As you can see in the lower pic. I've bought an ally rear guard blank and am now gonna have to decide on the tail light etc to use so I can cut it to length.
I have taken a week off work to try and get some headway on the project so we'll see where I get! I would love to finish the electrics but there's a lot of work to do first.
I'll keep ya updated.
Old 10-02-2009, 11:59 PM   #56
Steve in NZ
scared/cheap
Steve in NZ's Avatar
Oddometer: 1,054
yo
lookin good. ya gunna ditch the front end.
whats that front wheel in the background attached to
Cheers Steve
bike = the purple pig
Steve in NZ is offline   Reply With Quote
Old 10-03-2009, 07:34 AM   #57
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
thanks to bpeckm for the reference to this thread.
you may want to go ahead and replace the stock coil. it looks like the original that is prone to cracking and leaving you stuck roadside. i learned the hard way and am now running a 10 dollar harley coil that works great.
Originally Posted by boxer odyssey
Another saturday arvo and another part fabricated for the bike. Today I made the steel mounting bracket for the rear cowl - it also holds the engine breather and the coil. After final finishing it will be powder coated and I will run an earth strap from the middle mount bolt to the coil.
bmwblake is offline   Reply With Quote
Old 10-04-2009, 08:43 PM   #58
boxer odyssey OP
Oddometer: 138
No Worries about the coil. it's the later type - not prone to failure and it's in good nick. The earlier ones with the alloy brackets were the troublesome ones I'm told. Mine has the steel bracket.
cheers - I'm off to the water cutters to collect my speedo mount now.
Old 10-07-2009, 06:06 PM   #59
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 800
Nice job for a danged Ozzie yabbo.
baldwithglasses is offline   Reply With Quote
Old 10-07-2009, 06:23 PM   #60
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,221
looks really good, mate.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Times are GMT -7.   It's 12:47 PM.
