08-19-2009, 08:08 PM
#1 |
Oddometer: 5
Fuel Pump Driver Failed on an 08 R1200GS
250 km into a weekend trip my bike wouldn't run. It would start, rev-out or idle for about 2 seconds, but wouldn't run. This happenned for about 30 starting attempts. After that all it would do is crank over, but not start. There were no warning or fault codes on the dash. BTW it was raining off-and-on all day.
![]() Thanks to BMW roadside assistance the bike was trucked to a dealer (about a 200 km tow). The dealer diagnosed the situation as a faulty fuel pump electronic controller - aka fuel pump driver - and a replacement is currently on order (2 week delivery). A little research revealed these controllers became wet due to a flawed o-ring seal. However, this situation was reported in 2005 and one might assume that this had been fixed for the 08 models. 1. Can anyone report this happenning to other 08-R1200GSs? 2. Is it possible to carry out a road-side replacement of the fuel pump electronic controller? Jim ___________________ '08 R1200GS '08 F650GS (twin) |
08-19-2009, 08:24 PM
#2 |
Talks to cats
Oddometer: 5,293
In the US it's a recent recall, number 09V319000 affecting '06-'08 R1200 GS.
#3 |
Oddometer: 1,013
Welcome to BMW ! Lol, my 07 had the upgraded o-ring and yet it leaked water, shorted out and stranded me on the freeway in Louisiana one hot summer day in rush-hour traffic.
Be warned that even the "fix" from the factory may not work. Another thread outlines the procedure for by-passing a failed controller and direct wiring the pump like on the 1150 series. That by-pass may save a lot of pain and heartache the next time it lets you down. |
08-20-2009, 01:03 PM
#4 |
Oddometer: 3,169
Get this bypass cable from a fellow forum member,in case you have future issues:
http://www.burnsmoto.com/bmw-fuel-pump-bypass-cable.php |
08-20-2009, 01:31 PM
#5 |
ATAC Kfir Hack
Oddometer: 450
If your dealer will give you the failed part you can make an emergency bypass with it very easily and then stick it in your under-seat tray, that's what I've done after being turned into a pedestrian twice.
BTW, once you have a bypass under your seat (and know how to use it) it will never fail again.
Good Judgment Comes From Experience, Experience Comes From Bad Judgment. JetSpeed screwed with this post 08-20-2009 at 02:27 PM |
08-20-2009, 01:40 PM
#6 |
Oddometer: 4,474
Anybody Contact BNW NA?
Hey has anybody actually talked to BMW NA or BMW Motorrad about how the replacement controllers will stop the water damage generated failures of the controllers?
I read the letter from Jan Urbahn from BMW NA to NHTSA. Check out his title: General Manager; Safety Enginering and Intelligent Transportation Systems! The letter is weak and doesn't specify how the controller will be modified to preclude these failures. I mean WTF....this is another absurd issue that should not be an issue.
"In Wallowas" ==================== 2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
08-20-2009, 02:02 PM
#7 |
Oddometer: 151
Mine failed last week. Dealer called today and its fixed. I love the fact that my '07 GS is being repaired, but why the hell does it keep breaking down. Fork seals, key antenna ring, rear main engine seal, two final drive seals and now this fuel pump problem. What will fail next?
08-20-2009, 02:30 PM
#8 |
ATAC Kfir Hack
Oddometer: 450
To be honest I don't believe that the fuel controller failures are due to water or corrosion, I think that the part fails due to overheating.
Good Judgment Comes From Experience, Experience Comes From Bad Judgment. |
08-20-2009, 02:43 PM
#9 | |
SWM Adventuer
Oddometer: 4,146
08-20-2009, 04:41 PM
#10 |
Oddometer: 5
"Get this bypass cable from a fellow forum member,in case you have future issues:
http://www.burnsmoto.com/bmw-fuel-pump-bypass-cable.php" Thanks for the info on the bypass cable, and thanks to all that replied. It's nice to know that I'm not alone. Also, this may explain the long delivery for the replacement fuel pump controller, i.e. high demand. The image of the failed controller shown on the page with bypass cable seams to have a lot of electronics inside. How complicated is this device? Especially if can be bypassed by a connection to the battery. Looks like its more than just a relay. Jim |
08-20-2009, 04:58 PM
#11 | |
Talks to cats
Oddometer: 5,293
I'm just parroting things I've read... I really don't have a clue as to how much of that is factual. OK, I really don't have a clue.
08-20-2009, 05:06 PM
#12 | |
Oddometer: 425
08-20-2009, 07:45 PM
#13 |
Oddometer: 151
Yeah and if you never start the bike, it'll last forever too. But WTF good is it. I certainly don't want to have to by-pass a non functioning item that shouldn't FAIL in the first place. Maybe I shouldn't be riding a BMW because I really don't want to have to jerry rig the bike in some parking lot after it crapped out again. This is my first BMW so I may not be up to speed on my obligation to study motorcycle mechanics in order to survive.
I was actually hoping to just ride the thing and enjoy it. I think I'll inquire about an extended warranty. |
08-21-2009, 02:59 AM
#14 | |
Oddometer: 425
As far as the major repairs are concerned, I've decided that when I'm negotiating the final deal on the bike, if they won't throw in the extended warranty for free, then I'm walkin'. Ya have to draw the line somewhere! |
08-21-2009, 04:48 AM
#15 |
Oddometer: 151
I wish I had that wisdom when I was buying
