Old 08-05-2012, 10:49 AM   #1
rutard OP
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
Hot Wet Jugs
I've got a '95 R1100 GS w. 97K on the clock. A couple months ago I repainted the head covers, and switched to Mobil 1. When replacing the covers, I noticed that one of the valve-cover-stud-holes (term?) was close to stripped. I decided against Heli-Coiling / Case-Saving as it was holding well enough.
Now I'm getting a leak between the block and the right jug (so it appears, baby powder test forthcoming). The valve cover seal appears to be dry. My gut says it's one of 3 causes:
1. Switching from Dino to Synth
2. Bad Block-Jug sealant
3. Loose Block-Jug bolts
How easy is it to tighten the bolts holding the jugs to the case? I have access to a BMW OEM Manual. Anyone know what these bolts are called?
My current plan is to tighten the bolts. If leak persists, then switch back to Dino. If leak still persists, clean and re-seal Jug-Case gap. This sound reasonable?
PICs
rutard is offline   Reply With Quote
Old 08-05-2012, 11:05 AM   #2
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,982
First, I believe you need to determine the source of the leak with accuracy.
Next, was the 600 mile retorque performed on the engine?
If so, you need to replace the seals/gaskets at the source of the leak.
Can you tell us your reason for deciding to switch to synthetic engine oil? Also, what viscosity did you choose?
BTW, Helicoils or Timeserts are a common repair for the OHV cover female threaded holes.
def is online now   Reply With Quote
Old 08-11-2012, 04:53 PM   #3
rutard OP
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
I've ridden, cleaned off, ridden, cleaned off, etc. The leak is from the forward seal (it is crumbling) between the Case and the Jug:
The bike has almost 100k. I'm the third owner. I am not sure about the 600mi retorque. I'd love to check the torque at the least. How is the retorque done?
I chose 15w40 Mobil 1. There was a sale at Autozone. It was first oil change since I bought the bike, and wasn't sure what was in it before.
I'm planning on doing the helicoils the next time I have the OHV covers off.
Old 08-12-2012, 05:35 PM   #4
rutard OP
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
Trying to stop the leak before hitting the road tomorrow night. Anyone know how to retorque bolts? Could this be done w bike on lying on the left side, so I don't have to drain oil?
Are there any other solutions (ie JB Weld, high temp silicone sealant, etc.) that would allow me to wait until winter to open her up?
Old 08-12-2012, 05:40 PM   #5
Gezerbike
Hey Rocky...........
Gezerbike's Avatar
Oddometer: 3,532
I seriously doubt that re torquing the jug will solve your issue.
___________________________________________
Mike
2012 R 1200 GS RALLYE
Gezerbike is offline   Reply With Quote
Old 08-12-2012, 06:22 PM   #6
bikecat
bikecat's Avatar
Oddometer: 1,115
You can try re-torquing and re-evaluate the leak. That is the cheapest and least tedious method. You can do this with the bike upright, you will lose some oil but it is only a matter of topping off.
If that does not work, then the cylinder/block gasket will have to be replaced.
bikecat is offline   Reply With Quote
Old 08-12-2012, 06:47 PM   #7
Shortguy on BMW
Shortguy on BMW's Avatar
Oddometer: 127
Fix it later. Keep your oil level above min. in your ride. More damage won't be done since it isnt on the compression side. I believe they all do that eventually. If you strip your head bolts your ride won't happen.
Shortguy on BMW is offline   Reply With Quote
Old 08-13-2012, 10:09 AM   #8
rutard OP
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
Oil Tampon
Shortguy, Geezerbike, and Bikecat - Thanks for your input!!!
I think I'm going to leave it be, and continue to monitor.
However, I would like to decrease the amount of oil getting burnt off the Cat and Header pipes (it get's a bit noxious in traffic).
I was thinking of making some Oil Tampons out of something like THIS (using some locking wire to hold against seal). Is this stupid? Will it light my leg on fire?
Old 08-13-2012, 02:50 PM   #9
Gezerbike
Gezerbike's Avatar
Oddometer: 3,532
I think you'd be risking the possibility of a fire with those.
Mike
Old 08-14-2012, 04:14 PM   #10
bdarling
Weatherman
bdarling's Avatar
Oddometer: 421
Sage advice here. I dug into my '95 to fix the exact same leak and ended up doing the job 3 times due to stripped threads in the case. Maybe I got a bad case, but the thread let go before I got 90 degrees of preload on the head stud. I just decided to live with the leak until I get bored of riding...
Also, use Hondabond to seal the case/jug...ultra gray is for idiots (like me).
SoCal Dual Sport - http://www.socaldualsport.com
bdarling is offline   Reply With Quote
Old 08-14-2012, 04:49 PM   #11
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,050
I also had to replace head gaskets, and reseal one cylinder on an early 1100gs
and , I too did not torque the head bolts to the full amount, it just felt like too much.
in fact, I never did the 600 mile retorque either.
that was a couple of years and several thousand miles ago, no leaks.
fingers are crossed!
its daunting initially, but not hard once you actually get into the job
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is online now   Reply With Quote
Old 08-15-2012, 07:08 AM   #12
rpm100
Oddometer: 9
Btdt
My guess is you probably have a stripped cylinder stud. Had one go on my 95; my riding partner ending up doing all of his on his 95. Seems like the torque recommended is too much; we would get one done and when we did the last 90 degree, one or more would often strip.
We got pretty good at pulling and re-installing the cylinders by the time we did them all. Ultimately inserts, rather than helicoils, seemed the best solution.
We lightened up on the torque a bit and all seems well (knock wood).
Good luck with it.
Rick Matisak
Cleveland, Ohio
2000 K1200LT
1995 R1100GS
1978 R100/7
rpm100 is offline   Reply With Quote
Old 08-15-2012, 07:52 AM   #13
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,243
Definitely a leak where the cylinder hits the case. Odds are strong that you have a bad stud, usually it is the lower left one:
Helicoil is what I used, timserts are fine too.
IMHO NOT fully torqueing the studs is asking for trouble down the road. The torquing process is not the reason they pull out. That is likely heat cycles and stress. If you have any doubt about the strength of the threads in the case, simply helicoil all of them while you are there.
Jim
Old 08-15-2012, 03:13 PM   #14
JimVonBaden
"Cool" Aid!
Oddometer: 52,243
Originally Posted by vintagerider View Post
According to Ted Porter the 95 1100 had an assembly issue where the studs were not run in all the way at the factory. It takes skill to do the helicoil correctly on these. Great bike, worth refurbishing.
Could be, I have heard that before.
The helicoil wasn't that hard, though I have done a few since then, it was not bad then.
JiM
Old 08-16-2012, 06:57 AM   #15
rutard OP
Magnanimous Madcap
rutard's Avatar
Oddometer: 326
Jim, Vintage, Mouthfull, RPM, and Bdarling, Thanks for taking the time to respond!
I'm keeping my fingers crossed that the threads in the case are good, but it sounds like I shouldn't hold my breath.
A header bolts is stripped on each side, so I'm gonna have to tackle that in order to get at the seals and inspect the threads. Arrrrgh. I haven't been able to find any good threads on that, but I've got some time.
Times are GMT -7.   It's 04:45 PM.
