Old 08-21-2009, 12:54 AM   #1
zoo mob OP
Oddometer: 329
Walk me through an Airhead valve adjustment.
I'm trying to sort out all of the basic maintenance issues that need attention with my new '87 R80rt. Next on the list is a valve adjustment. I've looked at the Clymer, but its pretty confusing, my only experience with valve adjustment comes from Honda SOHC 4's which are set up quite a bit differently. Is there a how-to somewhere online, or could someone do a super quick write up on it? Thanks a million.
zoo mob is offline   Reply With Quote
Old 08-21-2009, 01:34 AM   #2
PaulRS
Dutch fool
Oddometer: 811
In short.
-Remove both valve covers and sparkplugs.
-Remove black rubber plug from the inspection hole on the left of the engine, next to the oil dipstick.
-Turn the engine over by hand until 'OT' (tdc) shows in the hole.
-One cylinder will be at the end of compression stroke with both valves closed and ready to be adjusted.
-The other cylinder is then at the end of the exhaust stroke with both valves slightly open, to adjust this side, rotate the cranck one full turn.
Quick enough?
Paul.
PaulRS is offline   Reply With Quote
Old 08-21-2009, 04:56 AM   #3
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
fill out your user profile. Some of the gang are probably very close to you.
It's not difficult, but it can be a whole lot easier to have another airhead swing by and talk you through several things.
datchew is offline   Reply With Quote
Old 08-21-2009, 05:33 AM   #4
hank0614
TurtleGuy
Oddometer: 15
Try this link. It applies to /5's and earlier airheads but is valid for later bikes as well. Your valve spec's may vary, check the manual, but the technique is applicable to all air cooled beamers. It is very thorough and Duane is always clear in his explanations.
http://w6rec.com/duane/bmw/
Hank '72 R60/5 "Schildkroete"
'95 K75S "Shall Remain Nameless"
hank0614 is offline   Reply With Quote
Old 08-21-2009, 05:35 AM   #5
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,251
"quite simple really"
almost feeling guilty doing this
(hope you enjoy reading)
http://bmwmotorcycletech.info/setvalves.htm
should be a breeze after your SOHC4 experience
Renner is offline   Reply With Quote
Old 08-21-2009, 05:58 AM   #6
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
just one warning if you're new to airheads.
If you re-torque the heads, be SURE to use a very good torque wrench that you trust to be calibrated and stay around 25 ft-lbs or less.
You don't want to deal with a pulled cylinder stud.
Old 08-21-2009, 06:14 AM   #7
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,760
Don't forget the end float on the rockers while you're in there - 0.05mm
Rob Farmer is offline   Reply With Quote
Old 08-21-2009, 06:36 AM   #8
sharkojoints
is a bit slow sometimes..
Oddometer: 72
...and this is the specific page you're after:
http://w6rec.com/duane/bmw/valve/index.htm
Although he talks about the /5, your bike is much the same. Handy photos too. Even an idiot like me could understand it.
I find Duane a hell of a lot easier to understand than the Snowbum site. If you have the time and can cope with the headache inducing capitals and coloured highlighting then there is a lot of wisdom on Snowbum's site, but that's a pretty big 'if'.
sharkojoints is offline   Reply With Quote
Old 08-21-2009, 11:47 AM   #9
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
This might help
Zoo:
Click on my link below for my R100 maintenance and then zoom down to post 119-120 to start. Lots of pics and shows how I learned. Might help a bit.
Tom
Infracaninophile is offline   Reply With Quote
Old 08-22-2009, 11:35 AM   #10
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,635
How do you adjust that, though? Another washer spacer deal?
EDIT: Oh, never seen this page on Duane's site:
crazydrummerdude is offline   Reply With Quote
Old 08-22-2009, 01:07 PM   #11
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,760
WTF!!
Old 08-22-2009, 03:55 PM   #12
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Duane's site has a whole lot of neat information, but bear in mind that it's not always correct.
Not knocking the guy, he's been around a long time and is a great reference for some old stuff and I'm grateful he has taken the trouble to put all that stuff on his site.
I just wouldn't regard information on everything with the same confidence as I would from somebody like Oak or Snowbum or Anton or Vech.
Old 08-22-2009, 10:39 PM   #13
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Rob, are those aluminum pillow blocks? If so, do they really help in quieting down the valve train? I happen to have a set for a 70s airhead which I haven't installed. Need more inspiration from a good testimonial
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 08-23-2009, 10:25 AM   #14
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,635
WTF!!
You took the... letters.. right out of my.. fingers.
Old 08-23-2009, 10:53 AM   #15
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
WTF!!
So? it doesnt take much pressure to get the clearance right. you arent removing old plumbing or anything. Knowing of Duane, it was just for illustration and would just expect that someone would wrap the channel locks in tape.
dead
Chopperman is offline   Reply With Quote
Times are GMT -7.   It's 06:59 PM.
