Old 08-21-2009, 08:18 AM   #1
DolphinJohn OP
Caveman
DolphinJohn's Avatar
Oddometer: 3,938
Tire Pressure On Gravel
Just wondering if anyone has the ideal tire pressure for TKCs on an F800GS on fast gravel roads.
I'm about 185 without gear, carrying about 20 lbs luggage.
I know in soft sand about 18 psi worked pretty well for me with the Battlewings.
I'm thinking something like 23-25 on gravel.
Any thoughts?
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 08-21-2009, 04:40 PM   #2
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,715
Any thoughts?
Sure.
Oh you want to know tire pressure. My personal thoughts, the carcasses of these heavier rated tires will probably hold up to a variaty of pressures. I personally like the 20-25 range and ususally don't air them up much more unless I'm on a long stretch (500 miles) of pavement.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 08-21-2009, 06:33 PM   #3
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,970
I stopped airing down tires after a bent rim.
Originally Posted by JoelWisman
Depends on how fast you are going how far, how loaded the bike is, if there is the slightest chance of an imbeded hard edge or jump AND you don't like replacing your wheels, how good of fuel economy and range you want, and how much the bike deflecting some bothers you.
20 in the back and 15 in the front does FEEL better on a moderatly loaded bike, but a hard edge or jump can destroy your wheel at this pressure. Also heat build up in the tire on gravel is no different then on the road, if your going far fast you may not get away with it
I started h/s gravel doing 30 MPH on tires aired down to 20 PSI. I now do gravel at up to 80 MPH aired up to 42 PSI.
Lion BR is offline   Reply With Quote
Times are GMT -7.   It's 04:22 AM.
